855 cummins - TheDieselGarage.com
Thread Details Posted by cat power, this thread has received 22 replies and been viewed 32564 times.
post #1 of 23 (permalink) Old 02-03-2009, 03:42 AM Thread Starter
smokin duramax
cat power's Avatar
855 cummins
How would i go about getting another 50 to 100 hp out of my 855 ... cuz haulin that d9 can be a pain in the *** when im full of dirt.
04 lb7 chevy 2500 Duramax Ext.CSB 4x4 6 speed
Engine : PPE 425 hp chip, Head stud kit, studded mains, dual cp3s, FASS, ATS Aurora 3000 & 5000 , and 5 inch straight pipe.
Transmission : zf6 , dual disc clutch , atlas II transfer case (daily driver)
88 s10 on a 1 ton frame , 350 .30 over 3/4 cam , afr 200cc heads , 800cfm thunder eldbrok , 14 bolt rear dana 60 front , np 205 with a munci m21 4speed tranny . 527 gears. dual radiaters sittin on 44s. ( TOY )
1987 CASE 1455B track loader / crawler loader
1997 CASE 1845C skid steer / bobcat
1990 CASE 580K 4x4 , turbo Backhoe
1968 CAT D9G dozer NEW WIDE TRACKS
1985 CAT D4H dozer High track
1993 CASE 1288 Track hoe / Excavator
1984 CAT D6D dozer
1987 GMC General tri axle dump , 855 cummins pump turned up, 4.88s 9 spd.
1986 GMC BRIGADIER single axle , 6v92 detroit pump turned up, 5.57s 9spd. custom goose neck, tool/welding Bed
1988 chevy C70 CC single dump , 8.3 cummins , 100# fuel plate 9 speed , 6.57s
1990 PETE 375 Dump quad axle , 3406B cat (dumpin the fuel ) , 18spd. 5.13s
2003 Chevy C5500 CC 4x4 duramax , 208wb. 6spd. 4.56s , long flatbed goose neck
300hp ppe chip , Fass, head studs , Aurora 3000, dual disc clutch , 5" straight pipe
cat power is offline
post #2 of 23 (permalink) Old 02-03-2009, 04:41 AM
bmoeller's Avatar
The right way would be to change the button in the fuel pump and/or put in different orifices in the injectors.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 23 (permalink) Old 02-04-2009, 01:01 AM
The other guy
ynot is offline
post #4 of 23 (permalink) Old 02-04-2009, 02:16 AM
You have to put the injector on a test bench or injector comparrter to change the metering orfice and i dought any one has them any more. You cant just change oriffices with out looking at the out put. If you did you would have it runing so rough. Change the button to like a 22 and then try it. If it is a new style throdle shaft the back the screw out about 5 turns under the steel ball. You dont get much change with the throdle shaft. If it is a old style throdle shaft then you have to remove the shaft and on the inside of the shaft take out a screw and add some very small shims to open the hole in the shaft. The smaller the button size the more prssure you get.7 is the smallest and then there is a 10.12.15.17, and on up.depending on how much pressure you want you may have to go to a larger gear pump like a one inche. You dont want to adjust the screws on the side of the throdle shaft as many want to because they do not set rpm. If it is a AFC pump them on the side behind the throdle lever will be a set screw with a allen head that sets the no air on the AFC. you can adjust it to get the responce you want on take off but will not increase HP. If you go too far it will smoke on gear changes or if you go the other way too far the pedal will be slow on acceloration .Shims in the back on the big spring controls the high rpm but no need going crazy on high rpm. You can raise the top rpm but it will not increase the power at mid range verses not raising the top rpm. If that dont get you enough power then i know were you can get a higher flow injector for around 50 dollares exchange for a ptd. or top stop.
theakerstwo is offline
post #5 of 23 (permalink) Old 02-04-2009, 04:40 AM
The other guy
Not meant
Not meant for you, as I've seen 5, 7, 10, etc being the smallest button mentioned that there is. Actaully, the smallest is a "00". I have three. They are called (obviously) double otts, and are pure race.
Choosing a 22 without knowing his pump spec is kinda strange tho, unless I missed another post saying what is in it. I look at the number it has, go down three and use the shaft screw for the rest...T
ynot is offline
post #6 of 23 (permalink) Old 02-04-2009, 05:21 AM
M123KT-450's Avatar
Just pull the spring out the injector pump give it a good tug and pop it back in. . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
post #7 of 23 (permalink) Old 02-04-2009, 11:20 AM
SmokinCAT's Avatar
Originally Posted by ynot View Post
Not meant
You wanna get rid of one of those "00" buttons. I havent ever heard of one, or ever seen one for sale. I think it would go nicely in my pump for the old BC1 that I have set up for pullin.
Cody.
4.11 SQHP rockwells
SmokinCAT is offline
post #8 of 23 (permalink) Old 02-04-2009, 05:31 PM
The other guy
How bout just make one. Get any button you can, weld the fuel bowl completely shut, file it back to pure flat, drop it in. Use only for short bursts and watch the pyro on the pull (you'll have to screw the shaft screw out about 6 turns also) . I'm kinda hangin on to these, as they have the OEM "00" stamp on them, which are now collector items I heard...T
ynot is offline
post #9 of 23 (permalink) Old 02-04-2009, 09:42 PM
SmokinCAT's Avatar
I have always wondered about doing that. I understand about them being collecters items, and if they are that easy to make then I wont have much trouble. Could you give us a little insight to what the button actually does. Thanks Tony.
Cody.
4.11 SQHP rockwells
post #10 of 23 (permalink) Old 02-05-2009, 01:11 AM
The other guy
ANYTHING FOR YOU, BUD!!!!!!!!!!! The “button” (i.e. regulator plunger) acts as a pressure plunger, or regulator, just like the ones in an oil pump or fuel pump or whatever. The dif is the way it works. A Cummins PT (pressure timed) pump relies on increasing pressure to feed more fuel at a faster rate to the injectors. The more fuel, the faster the “pop” time of the injector. When the fuel cavity is full in the injector, the cam will pop it at a given rate according to when it’s “full” of fuel. The higher the rail (fuel) pressure, the faster it fills, the faster it will “pop” and unload during the cam stroke cycle on the injector lobe. At idle you may have 3 to 8psi rail pressure, hence a very slow pop (almost slobber), hence it only idles at as close to 19*BTDC as possible. Full load you will have 165 to 210psi (stock depending on CPL) with much more available with tinkering. More rpm’s, more fuel, fills much faster, pops much earlier from cam stroke to unload the injector at somewhere around 26.5 to 31* (in theory).
The plunger, as stated earlier, in a pressure plunger with a barely rounded head. The bigger the number of the button, the bigger the recess hole in the plunger. The bigger the recess, the faster and easier it can be pushed in to hold the rail to the desired steady state of pressure. On the flip side, the smaller the recess, the more pressure the pump has to build to push the plunger back against the idle spring, thereby by-passing it back into the main cavity of the T-pump inlet to start over again.
Not sure if that all made since, but in essence, the smaller the recess orifice, the higher the rail pressure by compensation. The bigger the recess, the easier to unload, hence the lower rail pressure.
All this has worked efficiently enough to make them go for 50 years or so, but the variables in the original design are the cause of the quirks they've had since genesis, the main one being that PT pumps are RPM sensitive, not load sensitive. That means on a PT at 1/4 throttle you can hit 2200rpm, so PTO capability is close to non-existant. On a scroll or sleeve metered pump they are load sensitive, so 1/4 throttle is always 1100rpm(+/-), and if a PTO is added, it fuels more by servo and/or bellcrank to keep it there (which is obviously prefered).
Hope that helped. Be cool bro!!…T
Last edited by ynot; 02-05-2009 at 02:10 AM. Reason: brain fart again. stunk too. Had my springs backwards in my head...
ynot is offline
The Following 2 Users Say Thank You to ynot For this addition to TDG:
DieselPower (02-07-2009), SmokinCAT (02-05-2009)
Human Verification
89 cummins value firehillbilly 5.9L Cummins (Pre 1994) 4 02-04-2008 04:18 AM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Diesel Conversion 0 05-23-2007 06:29 AM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Whats Been Sold 0 05-23-2007 06:29 AM
pix of a 12V cummins in an S10 nevrenufhp Diesel Conversion 17 04-01-2007 04:20 AM
350 Cummins? ocmechanx Medium and Heavy Duty 2 03-30-2006 05:38 PM
