wheelbase - TheDieselGarage.com
Thread Details Posted by sexytrkr, this thread has received 19 replies and been viewed 3334 times.
post #1 of 20 (permalink) Old 03-22-2009, 12:16 AM Thread Starter
truckn'
sexytrkr's Avatar
Send a message via AIM to sexytrkr
wheelbase
how do they measure the wheelbase of a truck? I know its from the center of the wheel on the front axle, but at what point on the rear? I thought it was the middle of the two axles, but im not sure. Thanks!
2014 T800W 600hpISX15 18spd yanking a 2003 XL specialized 110HD with the cheater neck.
93 peterbilt 379ex hood. 3046B 18spd (in time out, broken crankshaft)
Lonestar Diesel club #9
sexytrkr is offline
post #2 of 20 (permalink) Old 03-22-2009, 12:56 AM
Wanna be door swinger
pullingtrucker's Avatar
Send a message via Yahoo to pullingtrucker
The wheel base is measured from the center of the front (steer axle) to the center of the rear drive axle.
'06 379 Peterbilt with a C-15 MXS 550hp, 200gph FASS, high flow mufflers, fuel harness, shimmed fuel pump, crankshaft balancer, Bully Dog Big Rig downloader, Bully Dog exhuast manifold, Spinner II bypass filter , a big Detroit Radiator, custom built Lipe clutch, Schaeffer's synthetics in all boxes, and a 18 speed tranny.
'06 53' Utility 3000R with a Carrier unit hanging on the nose. Just a plain trailer with little frills.
Ridin Dirty Club #12
pullingtrucker is offline
post #3 of 20 (permalink) Old 03-22-2009, 01:02 AM Thread Starter
truckn'
sexytrkr's Avatar
ok, thanks. I'll bust out the measuring tape when i get to the house. I cant seem to find the WB printed anywhere.
sexytrkr is offline
post #4 of 20 (permalink) Old 03-22-2009, 05:23 AM
hispeed428's Avatar
I would have to disagree.I'm in Canada where if you wanna be legal the max wheelbase is 244".Thats measured from the center of steer axle to center of rear turning group which would be the center of the rear tandems.
07 379 Pete,C15 625HP,18 speed,8" stacks with Rod Pickett Y-pipe,Super 40 rears 3:58's
hispeed428 is offline
post #5 of 20 (permalink) Old 03-22-2009, 12:08 PM
I know that Ohio has us measure they way I stated for permits...many other states do also. Never been to Canada since they don't like my truck (271" wb and a 53' trailer).
post #6 of 20 (permalink) Old 03-22-2009, 01:47 PM
9 Axle's Avatar
The "Spec" WB is from the center of the front, (group with tandem steer) to the center of the rear axle or group of axles, center of tandem, center axle on tridem. The states want the dimensions of all axle groups for permit requirments. Jus' tryin' to help.
9 Axle is offline
post #7 of 20 (permalink) Old 03-22-2009, 09:26 PM
hispeed428's Avatar
A "SPEC 244 WB" 3 axle tractor with 54" tandem spread measures out like this,217"s from center of steer axle to center of frt drive, 54" from frt drive to rear drive.
post #8 of 20 (permalink) Old 03-22-2009, 11:54 PM
9 Axle's Avatar
That might be 218". From the C/L of the steer to the C/L of the front driver.
Add 26", (1/2 of the normal tandem spread, 60" in Canada) & you have a 244" W.B.
9 Axle is offline
post #9 of 20 (permalink) Old 03-23-2009, 02:54 AM
hispeed428's Avatar
Yeah,just goin by what I have.You can spec a 52",54",or a 60" spread tandem
post #10 of 20 (permalink) Old 03-23-2009, 03:01 AM
9 Axle's Avatar
52" seems to be the accepted standard in the states, 54 is extremely rare, & 60" is used extensively above the 49'th & in the states for heavy haul.
9 Axle is offline
Human Verification
Shorting a lowpro and wheelbase Caesium Medium and Heavy Duty 5 04-16-2008 10:44 PM
Detailed specs on 08 wheelbase? extremetruck 2008-2010 6.4L Power Stroke 1 09-10-2007 03:49 AM
