2004 International 4300 dt466 - TheDieselGarage.com
Thread Details Posted by Frankiep02, this thread has received 3 replies and been viewed 20395 times.
post #1 of 4 (permalink) Old 12-26-2008, 01:20 PM Thread Starter
Exclamation 2004 International 4300 dt466
Hi everyone,
I just found the site the other day and thought I might be able to find an answer here.
My problem : 2004 International 4300 with 235k+ on the motor, Oil is dissapearing. No visible leaks or anything . Someone suggested it could be the compressor?
Problem 2: " Check A/C " light is on. I have no clue how to get it to turn off.
I think theres a way to check the trouble codes with the steering wheel buttons.
If anyone can help me out , let me know
Thanks,
Frank
Frankiep02 is offline
post #2 of 4 (permalink) Old 12-26-2008, 03:34 PM
Super Moderator
John_G's Avatar
Frank,
Does your 2004 4300 have a 2004 emissions (EGR) engine, or the pre-EGR DT? That's very important to the solution.
My guess from afar is that you have a pre-04 DT (non-EGR) engine and that one of the injector o-rings has failed allowing oil to leak into the fuel system.
EASY check, open the tank and see what color the fuel is. If it's greenish/amberish it's OK, but if it's brownish/blackish, well you have an injector o-ring leaking.
The "check A/C light" has many causes. Common ones include: Loss of charge, corroded terminals at the refrigerant temp sensors (two small sensors in the A/C piping on the RH side of the cowl under the hood right near the hood bumper), or a programming problem in the body controller that tripped the system off from high head pressure (common with a viscous fan drive and hot, humid days - this is fixable with a quick reflash).
By far the most common are the temp sensor terminals corroding and low charge.
I vote for LIBERTY!
John_G is offline
post #3 of 4 (permalink) Old 12-26-2008, 07:07 PM Thread Starter
Thanks for the input I will look into the things you suggested.
As far as the reflash, how can it be done if you know the steps ill give it a try.
Thanks,
Frank
post #4 of 4 (permalink) Old 01-01-2009, 02:31 PM
TDG Mafia # 81
Horsehaulin's Avatar
Does your truck have air ride or brakes?
Horsehaulin is offline
Human Verification
Old or New DT466 better? Todd Frampton Medium and Heavy Duty 8 06-25-2011 02:34 PM
Help! 87 IH dt466 haulinhazmat Medium and Heavy Duty 13 01-03-2009 02:35 AM
04 Freightliner M2 Vs. 03 Int. 4300 Curbguy Medium and Heavy Duty 10 12-30-2008 08:53 PM
Need a service manual for a 95 DT466 richarr9 Medium and Heavy Duty 8 12-27-2008 10:09 PM
1999-2004 to 2005-2006 Headlight Swap weareweird69 1994-2003 7.3L Power Stroke 6 12-24-2008 04:59 PM
