Big Cam III - PT320 to Formula 400 - TheDieselGarage.com
Thread Details Posted by 6V-92TTA, this thread has received 70 replies and been viewed 24343 times.
post #1 of 71 (permalink) Old 12-13-2009, 10:09 AM Thread Starter
On a BC3, what needs to be changed to convert a PT320 or NTC-350 to 400HP?
Is the turbo different? Are the injectors bigger? Or is it just a matter of cranking up the pump?
Thanks.
6V-92TTA is offline
post #2 of 71 (permalink) Old 12-13-2009, 12:28 PM
Call your cummins dealer, give him the cpl on engine tag, and they should be able to tell you what you need to change it. I changed a bc 3, 300 hp to 400 hp, i did full inframe with new cpl, new turbo rebuilt injectors and pump to correct specs.
FRANKIE
FRANKIE is offline
post #3 of 71 (permalink) Old 12-13-2009, 02:41 PM
The other guy
Thanks.
Your 350 will change over much easier to the 400. Have a CPL?
ynot is offline
post #4 of 71 (permalink) Old 12-14-2009, 05:26 AM Thread Starter
I don't have a cpl, I'm looking at trucks on ebay. What is the difference between a 350 & a 400 then? Do they have different injectors or turbo?
Thanks.
6V-92TTA is offline
post #5 of 71 (permalink) Old 12-14-2009, 06:28 AM
SmokinCAT's Avatar
I think for the most part it is timing, turbos would mostly be the same until the later model years. The injectors could be different, but without the CPL# it is a long shot on guessing correctly.
Cody.
4.11 SQHP rockwells
SmokinCAT is offline
post #6 of 71 (permalink) Old 12-14-2009, 12:33 PM Thread Starter
Where do you find out what cpl has what parts?
6V-92TTA is offline
post #7 of 71 (permalink) Old 12-14-2009, 04:18 PM
SledMan's Avatar
If you don't have the CPL, get the serial number stamped in the block, on the drivers side, towards the rear. It's a 7 digit number...and call Cummins and they can get you the CPL.
SledMan is offline
post #8 of 71 (permalink) Old 12-15-2009, 02:33 AM
SmokinCAT's Avatar
Cummins, and that is if they will work with you, no matter what if you get a choice go with the 400.
Cody.
4.11 SQHP rockwells
post #9 of 71 (permalink) Old 12-15-2009, 09:01 PM
The NTC was a terrible piece of **** they were hard to start Smoked white, forever, They were one step below a 444. To find out what parts came with which CPL Complete Parts List we had a book, It tells you which heads kits injectors turbo Cam most everything If you have the CPL of what you have and what you want and go to Cummins they can tell you whether you old parts are a core, and prices. They may not be as helpful over the phone. Just a thought!
Johnp3 is offline
post #10 of 71 (permalink) Old 12-16-2009, 12:25 AM
SmokinCAT's Avatar
You do know that the NTC moniker covers small cams all the way up to the BC3, it seems to me that anything after the 676cpl BC4 would be considered junk, which arent considered NTCs. Hard to say that a motor that is capable of 6.5MPG is a POS even if it does smoke a bit when its cold.
Cody.
4.11 SQHP rockwells
The Following User Says Thank You to SmokinCAT For this addition to TDG:
359kool (12-17-2009)
Human Verification
stanadyne performance formula bigbucks8 2008-2010 6.4L Power Stroke 6 01-31-2009 12:03 AM
Is There a Formula to Calculate Optimum Gear Ratio? ralphinnj 2003-2007 6.0L Power Stroke 12 01-04-2008 04:17 PM
Standyne Lubricity Formula-Thoughts?? GOPDiesel 2003-2007 6.0L Power Stroke 30 12-11-2007 06:44 PM
Formula 1 camshafts Jetpilot Dodge Performance Forum 45 12-21-2005 04:47 AM
Easy Formula biavaperformance Road Kill, Bench Racing 0 08-03-2005 09:44 PM
