peterbilt wiring scematic - TheDieselGarage.com
Thread Details Posted by acegreaser, this thread has received 7 replies and been viewed 68808 times.
post #1 of 8 (permalink) Old 01-30-2010, 02:15 PM Thread Starter
I need the wiring scematic for a 2005 357 with cat c13.Need schematics for cab and chasis and engine showing all info.Tried 2 different dealerships and they have emailed me the wrong ones each time.Working on clutch fan and is not getting signal from ecm to shut fan off.ECM keeps saying ac high pressure switch is on.Checked wiring with ohm meter to the switch and fan solenoid.No broken wires.Changed both ac switches and charged ac at dealers recomendation knowing that wasn't the problem.If any body could help i would much appriciate it.I think the driver in the ecm might have gone bad i have a test ECM but i don't want to plug in until i have correct schematics.Thanks.
acegreaser is offline
post #2 of 8 (permalink) Old 01-30-2010, 02:22 PM
379Longhood's Avatar
Try www.supermiller.com look on the right side of the page and down to schematics (this link came from 359Kool just passing it along)
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline
The Following User Says Thank You to 379Longhood For this addition to TDG:
pullingtrucker (02-01-2010)
post #3 of 8 (permalink) Old 01-31-2010, 02:40 AM
PB SHOP FOREMAN
domniman2002's Avatar
just go in and put the ecm in test mode....connect it and see if the fan shuts off...it sounds like an ecm problem. pin 11 is the driver for the fan. this is how we check it. we have ran into this a couple of times. need to go into the parameters and check fan run time and change if needed. there is fuse in the fuse box that is marked aux fan and if the fuse is blown this will also keep the fan on. jump the high pressure switch with a paperclip on the harness side and see if the fan status will read off......
SHOP FOREMAN FOR PETERBILT IN THE GREAT STATE OF TENNESSEE.....28YRS JOURNEYMAN TECH
domniman2002 is offline
post #4 of 8 (permalink) Old 01-31-2010, 01:31 PM Thread Starter
Thanks for the help and link for schematics.I found a third pressure switch that was missing on the discharge hose from the compressor.The plug was taped up in the harness by the compressor.I jumped the plug and the fan shut off.Thanks again for the help.
post #5 of 8 (permalink) Old 01-31-2010, 01:36 PM
Great link 379Longhood. Do you know of a link to KW info???...
black_dog106 is offline
post #6 of 8 (permalink) Old 01-31-2010, 11:44 PM
Haven't seen any KW links, But I would guess that the electric system should be similar I always get KW parts from the pete dealers here. Sorry it took so long to reply I got caught up in the DRAWMA abt manifolds
JD 820 black dash
Last edited by 379Longhood; 01-31-2010 at 11:45 PM. Reason: Link between brain and keyboard is questionable
post #7 of 8 (permalink) Old 02-01-2010, 02:35 PM
Wanna be door swinger
pullingtrucker's Avatar
Send a message via Yahoo to pullingtrucker
Thank you to you and 359Kool. I found a few schematics that I've been wanting for a while. Now I only need the CAT repair manual with a wiring schematic for my MXS. Thanks again guys.
'06 379 Peterbilt with a C-15 MXS 550hp, 200gph FASS, high flow mufflers, fuel harness, shimmed fuel pump, crankshaft balancer, Bully Dog Big Rig downloader, Bully Dog exhuast manifold, Spinner II bypass filter , a big Detroit Radiator, custom built Lipe clutch, Schaeffer's synthetics in all boxes, and a 18 speed tranny.
'06 53' Utility 3000R with a Carrier unit hanging on the nose. Just a plain trailer with little frills.
Ridin Dirty Club #12
pullingtrucker is offline
post #8 of 8 (permalink) Old 02-14-2010, 04:56 AM
nice ...... good find Thanks
absolutediesel is offline
Human Verification
Peterbilt Emblem cumminsdieselfreak General Ford Truck and Excursion 9 02-19-2011 05:47 AM
Need wiring scematic 1993 L8000 Ford acesneights1 Medium and Heavy Duty 4 02-08-2009 02:23 PM
Bad AZZ Peterbilt fordt The Parking Lot 18 10-13-2007 05:21 PM
Wiring remote start/alarm, anyone have wiring diagrams? kjdavis 1994-2003 7.3L Power Stroke 3 06-23-2007 12:13 AM
New Peterbilt 389/388 Pics prenn Medium and Heavy Duty 11 04-07-2006 02:11 AM
