3 Wire Fuel temp Mod, 3406E - TheDieselGarage.com
Thread Details Posted by KET19, this thread has received 35 replies and been viewed 52283 times.
post #1 of 36 (permalink) Old 03-08-2010, 01:07 AM Thread Starter
KET19's Avatar
I know,, i have read many times that the fuel temp mod has been written about many times,, however,, i could not find a drop dead way that workrd or did not have a problem.. So.
Here is what i did, using a Prolink 9000 in the data mode i read the fuel temp as it was ,, un modified,, 42deg..
Long story short, here is what i did.
Run to Radio Shack and buy a 5 pac of 150 ohm resistors... Go to the truck and Skin back the oarnge and white wire,,, leave the black wire alone,,, take 3 of the newly purchased 150 ohm resistors out of the packet and hook them together in a Series,, (3 in a row) solder them,, now take one end and wrap it into the oarnge wire,, and the other end on the white wire.. Solder,, wrap it up = Done..
Here is what you have accomplished,, the ECM will see a fuel temp of 160deg with no trouble codes,, this is reading the actual fuel temp readings on the Pro Link !! The changes ar every consistant and i have experimented with the 100 ohm and 150 ohm resistors. Note* if you just unplug the sensor the ECM will see 86deg.
If this has been done before ,, my apologys for wasting your time . The only post i could find was one where *dont quote me on this* cut the one wire and hook the other 2 together and then a resistor,, did not work at all !!
This i figured up.
Best to ya all !!
Last edited by KET19; 03-08-2010 at 01:13 AM. Reason: Type o,, and now i cant find it
KET19 is offline
The Following 3 Users Say Thank You to KET19 For this addition to TDG:
bojoe (03-09-2010), Les2 (03-08-2010), Lmackattack (03-08-2010)
post #2 of 36 (permalink) Old 03-08-2010, 01:56 AM
I was wondering how to do that with the 3 wire....Thanks!
Dumb question, thought you wanted the ECM to read the temps as cooler so it would dump more fuel to heat it up?
Les2 is offline
post #3 of 36 (permalink) Old 03-08-2010, 02:13 AM Thread Starter
KET19's Avatar
I understand what you are saying, but,, your thinking Gas motor. When I started messing with this mod I made the fuel temp read 0, zero. So I polish dyno"d it and got a 21 lb boost read out cause that confused me too, but I read on this site that,, Cats will put more fuel to a Hot, fuel condition, and I know for a fact thata certain % of HP is lost for every deg above 122 ??? I have slept since then and do not know the exact no"s.. When I got the fuel temp to the 160 mark it was 26 on the boost rite quick,,, a marked improvement.
KET19 is offline
The Following User Says Thank You to KET19 For this addition to TDG:
post #4 of 36 (permalink) Old 03-08-2010, 04:16 AM
The other guy
More fuel output hot, as the fuel is thinner requiring more delivery (solenoid duration). Max sendor temp is 162*. After fuel reaches that actual temp there is no gain from the shunt stick (theoretically)...
ynot is offline
The Following 4 Users Say Thank You to ynot For this addition to TDG:
bojoe (03-09-2010), french277 (08-24-2010), Les2 (03-08-2010), Lmackattack (03-08-2010)
post #5 of 36 (permalink) Old 03-08-2010, 08:06 PM
Highway to Hell
Lmackattack's Avatar
QUESTION...CAN We use a single 450 ohm resistor or do we need the three 150 ohms?
1978 MACK RS700L
285 HP @2100 RPM 1080 TORQUE. @1200 RPM
2 STICK 6 SPEED, 4.17 REARS ON 34K CAMELBACK SPRINGS,206"WB, 4" STRAIGHT STACKS BLOWING BLACK,
OH...AND A FEW TWISTS OF THE FUEL SCREWS ....THANKS AGAIN... FJH!
Lmackattack is offline
post #6 of 36 (permalink) Old 03-08-2010, 08:16 PM Thread Starter
KET19's Avatar
Well sir,, good luck finding a 450. But yes you could. The fuel shiming is something I have yet to do and will have to search out the procedure on here somewhere.
KET19 is offline
post #7 of 36 (permalink) Old 03-09-2010, 01:25 AM
Highway to Hell
sounds like you went looking for one.... I will see if any of my computer geek friends have a lead on them.... thanks for all this good info!
1978 MACK RS700L
post #8 of 36 (permalink) Old 03-09-2010, 03:45 PM
Found one.
Jfaulkner is offline
The Following User Says Thank You to Jfaulkner For this addition to TDG:
Lmackattack (03-09-2010)
post #9 of 36 (permalink) Old 03-10-2010, 01:46 AM
At 42 degrees the ECM sees 160 degree fuel tempature, That gives you an increase in power for how long, and until what outside tempature. On a unit that has driven for say 5 hours how much extra HP do you get. I would think that the ECM would read that fuel tempature as out of range and go to the default setting. I have been wrong before but this seems like a fantasy fix.
Johnp3 is offline
post #10 of 36 (permalink) Old 03-10-2010, 02:05 AM
You see an increase in power until the fuel reaches 160* or above. As far as how long you see the increase that all depends on how big your fuel tanks are and how hot the outside temp is. It does work, that's why the fuel temp sensor is there in the first place, to compensate for the loss of power due to hot fuel. This mod just makes the ECM thing the fuel is always hot. Other resistor values have been tried but I think anything over 170* or so causes a check engine light and no added fuel flow.
I believe someone said this mod adds somewhere around 40-50hp and like 80 ftlb tq, dyno tested.
Human Verification
3406e restricter fitting in fuel return swaan Medium and Heavy Duty 35 12-29-2009 04:38 AM
Wanted: '96/'97 Fuel Bowl/FPR/Wire Harness hheynow Ford Parts wanted 0 11-16-2009 01:36 AM
fuel temp sensor? ehopp88ss 6.5L Diesel Engine 2 10-24-2009 11:12 PM
3406e fuel starvation CAT379 Medium and Heavy Duty 5 06-02-2009 03:59 AM
wire cut to bottom of fuel filter? highland 1994-2003 7.3L Power Stroke 6 04-16-2008 02:08 PM
