Alcohol to airbrakes - TheDieselGarage.com
Thread Details Posted by timark80, this thread has received 23 replies and been viewed 6311 times.
post #1 of 24 (permalink) Old 03-30-2010, 03:32 AM Thread Starter
Where do you pour the rubbing alcohol into the airbrake system?
timark80 is offline
post #2 of 24 (permalink) Old 03-30-2010, 03:37 AM
bushpilot's Avatar
try this...
http://lmgtfy.com/?q=alcohol+air+brakes
Don R.
Truck Audio,
bushpilot is offline
post #3 of 24 (permalink) Old 03-30-2010, 02:19 PM
truckn'
sexytrkr's Avatar
Send a message via AIM to sexytrkr
supposidly your suppost to take the airline off the air compressor (after draining your air first) and pour some in there, or into your glad hands...but ive never had to use anything like that. all of my airdryers allways worked fine.
2014 T800W 600hpISX15 18spd yanking a 2003 XL specialized 110HD with the cheater neck.
93 peterbilt 379ex hood. 3046B 18spd (in time out, broken crankshaft)
Lonestar Diesel club #9
sexytrkr is offline
post #4 of 24 (permalink) Old 03-30-2010, 02:30 PM
Administrator
fordt's Avatar
Images: 5
I have always heard pour into the glad hands.
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
post #5 of 24 (permalink) Old 03-30-2010, 02:38 PM
SmokinCAT's Avatar
It would be glad hands to get it in the trailer, and the line on the compressor for the truck system,
Cody.
4.11 SQHP rockwells
SmokinCAT is offline
post #6 of 24 (permalink) Old 03-30-2010, 02:41 PM
Red glad hand only! Do not pour it in the blue side. That's a dead end into the valve and has nowhere to escape. However unless the system is frozen (truck or trailer) it isn't going to do anything.
Jfaulkner is offline
post #7 of 24 (permalink) Old 03-30-2010, 03:00 PM
Administrator
fordt's Avatar
Images: 5
I live in Florida, we don't need to think too much about it anyways.
-Wayne
fordt is offline
post #8 of 24 (permalink) Old 03-30-2010, 03:02 PM
SmokinCAT's Avatar
I was going to add that winter is almost over in most of the states.
Cody.
4.11 SQHP rockwells
post #9 of 24 (permalink) Old 03-30-2010, 04:15 PM
379Longhood's Avatar
If you need to put Air brake antifreeze in your truck system do it after the air drier , it will turn the desicant pack to mush if you put it in before. only use straight alcohol in emergengies because it dries the seals out. Air brake antifreeze has lubricants added to prevent this.
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline
post #10 of 24 (permalink) Old 03-30-2010, 10:40 PM
My folks winter in Fl. They had colder weather a few days this winter than we had......
black_dog106 is offline
Human Verification
The Power of Alcohol Bouncer The Parking Lot 6 01-05-2010 09:57 PM
Question:elec. brake cont. on FL70 w/airbrakes timark80 Medium and Heavy Duty 8 02-12-2009 01:18 AM
? on wiring elec.brake controller to a FL 70 w/airbrakes timark80 Towing and Hauling 3 02-03-2009 10:59 PM
Water vs Alcohol Tech Guy The Parking Lot 3 05-08-2006 06:33 PM
Favorite Non-Alcohol Drink bigdraft The Parking Lot 30 02-10-2006 02:41 PM
