N14 cummins no start. - TheDieselGarage.com
Thread Details Posted by budtoh3zo, this thread has received 13 replies and been viewed 16943 times.
post #1 of 14 (permalink) Old 06-02-2010, 01:13 AM Thread Starter
I got a 1992 freightshaker that we are trying to get running, Its been down for a few years and well we got some ideas for it if we can get going again. The guys that last ran it thougt the ECM was shot. Im wondering how you can test it? thanks.
2006 yamaha Vmax
2003 suzuki 1000 GSX-R
1993 F-250 460
Near GP alberta.
CC#58
budtoh3zo is offline
post #2 of 14 (permalink) Old 06-02-2010, 01:17 AM
SledMan's Avatar
Try timing sensor first. Alot cheaper than the ECM.
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks:1980 KW Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. 2003 Pete EXHD. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3025 squirts. 800 cam. Acert twins via custom mount. ARP head bolts.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline
post #3 of 14 (permalink) Old 06-02-2010, 01:22 AM Thread Starter
anyway to test the timing sensor? also were is it located at?
2006 yamaha Vmax
1993 F-250 460
Near GP alberta.
CC#58
post #4 of 14 (permalink) Old 06-02-2010, 01:45 AM
SledMan's Avatar
It's screwed into the timing cover, to the right of the oil pump. Two wires with a plug. You can use an ohm meter and touch the two wires with it unplugged. Spin the motor over and you should see resistance change. It's a crude way to check, but it does work.
SledMan is offline
The Following User Says Thank You to SledMan For this addition to TDG:
budtoh3zo (06-02-2010)
post #5 of 14 (permalink) Old 06-02-2010, 11:33 AM
when you first turn the key on the yellow "check engine"light should come on for a few seconds then turn off.this will at least let you know if the ecm is gettimg power and ground.
QUALITYTRUCK is offline
The Following User Says Thank You to QUALITYTRUCK For this addition to TDG:
budtoh3zo (06-03-2010)
post #6 of 14 (permalink) Old 06-02-2010, 01:24 PM
Super Moderator
John_G's Avatar
The most common things are power and ground connections in the battery as suggested and a bad fuel solenoid (can turn screw to get running).
The Ftls also used Kysor shut down computers installed in the center fuse panel and they are notorious for failing preventing the engine from running or keeping the fan on all the time.
I vote for LIBERTY!
John_G is offline
The Following User Says Thank You to John_G For this addition to TDG:
post #7 of 14 (permalink) Old 06-02-2010, 03:56 PM
PGM
Fleet Owner
PGM's Avatar
Yup, Spot on, see if the ECM is even powering up before you waste your time checking sensors.
94 Kenworth K100E Detroit 470hp.
94 Kenworth T650 Cat 3406C 425hp.
96 International S3600 N14 460hp.
09 Sterling LT9513 MBE4000 450hp.
08 Sterling LT9513 Detroit 575hp.
07 Sterling LT9513 Detroit 500hp.
07 Sterling LT9513 MBE4000 450hp.
07 Freightliner Columbia 120 Cat C15 550hp.
06 Sterling LT9513 ISM 425hp.
05 Sterling LT9513 ISM 425hp.
04 Sterling LT9513 ISM 425hp.
04 Sterling LT9513 Detroit 500hp.
03 Sterling AT9513 Detroit 470hp.
___________________________
PGM is offline
The Following User Says Thank You to PGM For this addition to TDG:
post #8 of 14 (permalink) Old 06-02-2010, 06:26 PM
There is a three wire plug, in front of the left side motor mount the outside wires are power and the inside is ground. I use a headlight bulb to test the circuit. First thing I would do is clean the Battery connections, and grounds to the motor, from the starter. Put the battery's on charge, it is best to do them singly, with a regulated charger. Then if the check engine light goes out in the 5 seconds as stated take a test light and see if you have power to the fuel solinoid. Tug on the wire they they will break and stay attached by the shrink tube, and have voltage to the solinoid but not enough amperage to keep the solinoid open. If all that is OK you need a fuel pressure gauge on the Top compucheck fitting above the fuel solinoid, if the engine cranks at above,195 RPM, and you get above 75 lbs going quickly to 140ish PSI it should start. Just a thought.
Johnp3 is offline
The Following User Says Thank You to Johnp3 For this addition to TDG:
post #9 of 14 (permalink) Old 06-03-2010, 02:43 AM Thread Starter
Well ECM problem for sure then, the check engine light does not come on at all. Have to start tearing into the wiring. Thanks for the help guys. It will be awhile till i get back to it.
2006 yamaha Vmax
1993 F-250 460
Near GP alberta.
CC#58
post #10 of 14 (permalink) Old 06-03-2010, 03:23 AM
Many of them also have a ground fuse, going from the top rear mount bolt to the block. if that is blown and the ECM mounting is not clean. you could have that problem also. Just a thought!
Johnp3 is offline
Human Verification
Strange Cold start/no start/start changexlt 2003-2007 6.0L Power Stroke 7 12-23-2008 09:00 PM
1994 Cummins Hard Start story & questions ash_flat_diesel 5.9L Cummins 12 Valve (1994-1998.5) 6 03-12-2007 02:34 AM
Hard cold start/surge idle Cummins 855 50Peterbilt Medium and Heavy Duty 9 01-04-2007 04:32 PM
91 cummins remote start ramthisny 5.9L Cummins (Pre 1994) 1 12-30-2006 04:54 PM
