4x4 Will not disengage - TheDieselGarage.com
TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise
Go Back   TheDieselGarage.com > Ford Diesel & Truck Discussions > 2008-2010 6.4L Power Stroke
Thread Details Posted by AZPOWERSTROKE, this thread has received 6 replies and been viewed 1197 times.
TheDieselGarage.com is the premier Forum on the internet. Registered Users do not see the above ads.
Thread Tools Display Modes
Old 11-29-2012, 09:23 AM   #1
AZPOWERSTROKE
I have a 2008 F250 CC SRW 6.4L diesel with the ESOF. the 4X4 would NOT DISENGAGE. Dash light reading "4X4 HIGH" just stays on, I've tried a multiple of logical remedies, like fuses, locking/unlocking hubs, checking for proper vacuum functions, and even disconnected both batteries for an entire night to see if the ECU would reprogram, and NOTHING!! Geez I'm sweating some bullets here. I'm getting the usual skips and hops you get when your 4X4 is engaged. I even threw it in reversed to see if it would disengage, but NADA. One thing for sure is, I dont hear the T-case motor actuating. I drive Ford's all day at work and I'm pretty used to the noises, kinks and clanks these trucks make. Anyone out there ever experience this and found a solution? I've seen a lot of folks here have issues with their 4X4's not engaging.... mine will not disengage.. Thanks in advance for any help..
AZPOWERSTROKE is offline   Reply With Quote
Old 11-29-2012, 06:25 PM   #2
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
what did you have in it in 4wd for? A friend of my pulled his 01 7.3 and the 4wd would not unlock. We ended up unlocking the hubs and putting the truck in reverse on a bit of a hill and it came out.
__________________
"Only accurate rifles are interesting" -Townsend Whelen
2012 Ram 2500 Crew Cab Big Horn
6.7L 68RFE 4wd
Yeah its stock.
Edge Insight CTS / Line-X / Access Bed Cover
B&W Turnover Ball / Companion Hitch
Pac Brake Air Bags
On Board Air
2010 John Deere 2305
2010 Jeep Wrangler JK Unlimited Rubicon
2015 Keystone Impact 311 Toyhauler
9-11-2001 NEVER FORGET
neeltburn is offline   Reply With Quote
Old 11-29-2012, 11:53 PM   #3
AZPOWERSTROKE
I went out to the range. Just some regular ol' flat ground desert dirt you find out here in AZ. I tried the reverse trick also and nothing.
Old 11-30-2012, 04:35 AM   #4
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
I hate to say it but my guess is the actuator has gone out. Sorry Im not more help but that is where I would look next.
__________________
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Old 11-30-2012, 08:46 AM   #5
AZPOWERSTROKE
Yup. I think it has as well. Hey no sweat man. Some advise is better than none right. I'll update the thread once I pinpoint the issue and solve this mystery.
Old 12-01-2012, 12:16 AM   #6
Weld engineer
Weld engineer's Avatar
Wil it go into 4Lo? Maybe the switch is messed up. I think you can disconnect the vacuum lines to get the hubs to unlock but not 100% sure on the newer versions. The 04's are not too hard to remove. At least to get out of 4x4.
__________________
Early 2004 F-250 4x4 CC 6.0
2nd owner, ARP studs 1 at a time, Egr delete, Cat delete, BD intercooler hoses, Blue spring, MC filters, Sinister coolant filter, Exhaust manifold gaskets, WARN lockouts, Gold coolant, zoodad mod, autometer boost gauge, high idle mod, Scangauge 2, SCT X3 tuner from MKM, autometer fuel pressure gauge, Archoil 6200 in the fuel, FICM by Ed w/ATLAS40, autometer pyro gauge,'08 Alum Rear Diff cover, 5w-40 Rotella T6 w/ Archoil 9100 in it, zert in the slip joint, harpooned fuel tank, 6.4 banjos
Not a diesel mechanic in real life but I play one on the Internet
Weld engineer is offline   Reply With Quote
Old 12-01-2012, 02:24 AM   #7
AZPOWERSTROKE
The actual 4X4 selector switch is good. I took it off and took it to work with me and tested it on a truck from work. I'll try the vacuum module and locking and unlocking the hubs. Lets see what happens.
The Following User Says Thank You to AZPOWERSTROKE For this addition to TDG:
Weld engineer (12-01-2012)
Forum Jump
auto doorlock disengage n-r-zigs 5.9L Cummins (2003-2007.5) 1 03-21-2009 03:17 PM
Overdive disengage button doesn't work coreystroke02 1994-2003 7.3L Power Stroke 2 11-01-2007 09:18 PM
help!! clutch wont disengage??? mc2028 1994-2003 7.3L Power Stroke 11 02-22-2006 11:46 PM
New To Site? Need Help? TDG Specials
Powered by vBulletin®
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
DTO Garage vBulletin Plugins by Drive Thru Online, Inc.
vB.Sponsors
vBCredits v1.4 Copyright ©2007 - 2008, PixelFX Studios
