Oil Cooler and EGR Cooler Replacement - TheDieselGarage.com
Thread Details Posted by smknf250, this thread has received 6 replies and been viewed 4460 times.
Old 06-13-2010, 01:44 AM   #1
smknf250
My truck has been puking for a while and I had the coolant tested and it seems the gaskets are ok, (hopefully). My questions is who has replaced just there oil cooler and EGR cooler and problem is solved? Also what if I replace the two of them and then my problem is still there? Can I just do gaskets then or will I be replacing the oil cooler and EGR cooler again? Just trying to do the right thing and save as much money as possible. By the way my coolant is dirty so I know a coolant flush and coolant filter needs to be installed. Just trying to do things in the right order. THANKS! for the help.
smknf250 is offline   Reply With Quote
Old 06-13-2010, 04:19 PM   #2
Lubbockguy1979
illadvised and dangerous
Lubbockguy1979's Avatar
Send a message via Yahoo to Lubbockguy1979
I had a puking issue with the last 6.0 I had. I had the oil cooler replaced under warranty and that solved the problem for about 30k then shw started puking again.
2006 f250 4x4
crewcab lariat
auto elec tcase
soon to have
isspro egt/boost/trans/fuel
as well as pretty much
everything else
Lubbockguy1979 is offline   Reply With Quote
Old 06-13-2010, 07:07 PM   #3
smknf250
Yeah I am thinking that might be a fix for now. But I don't want to find out it is the headgaskets and have to do egr and oil cooler twice. Does anyone have a video or instructions on replacing the oil cooler?
Old 06-16-2010, 12:18 AM   #4
offroadinginaz
I Bleed BLUE!
You only have to replace the EGR and Oil Coolers if they are bad. If you replace them now then do HGs in the near future you don't have to replace then again UNLESS they are bad again. You could buy a Bullet Proof EGR cooler which is a better design and has a lifetime warranty.
A few Fords
offroadinginaz is offline   Reply With Quote
Old 06-16-2010, 01:32 PM   #5
dfuser
Supporting Vendor
Couple of things to note:
Oil cooler gets clogged with sand casting that floats in the coolant.
Oil cooler feeds the EGR cooler coolant, so when the oil cooler gets clogged, EGR cooler starves for coolant.
Remedies:
Oil cooler service kit
Coolant filter Kit
Upgraded EGR cooler or By pass kit
Call or PM me for any questions.
05/2009 F350 2WD CC DUALLY EBONY (Inside/Out) dropped 3/5 on 305/45-22 - dubbed "Cat Woman"
dfuser is offline   Reply With Quote
Old 06-16-2010, 09:58 PM   #6
International350
International350's Avatar
aw man, i just started a thread on oil cooler service kit and now ran across this. Are the service kits easy to use and where to get them?
2004 F-350 CC LB King Ranch. Under the Hood SCT w/Innovative street tunes by Eric, Hot FICM tuned by Power Hungary, custom built 4" intake with huge afe filter, Intake elbow, 3"down pipe to 5" straight piped stack, EGR block off, Zoodad Mod, CCV mod, Complete EGR delete, The Big 3 cable upgrade w/ batts under cab, Autometer pillar guages, Boost, Trans, EGT. APR studs sitting in box ready for install
Suspension 2.5inch leveling kit. Stock King Ranch 18" rims with 33inch Nitto A/T.
Truck is now pushing 134K miles an running strong.
International350 is offline   Reply With Quote
Old 06-16-2010, 10:35 PM   #7
Lubbockguy1979
One thing to note if you do a oil cooler and are wanting studs. Or if you are doing studs only. You will be at the point that adding new head gaskets and studs is not a lot of added labor. It is highly reccomended to replace the oil cooler if you do studs.
2006 f250 4x4
crewcab lariat
auto elec tcase
soon to have
everything else
oil cooler replacement? outlaw6oh 2003-2007 6.0L Power Stroke 9 10-21-2009 02:09 AM
LLY Exhaust Gas Recirculation Valve Cooler Replacement ripmf666 GM Spec Info 0 12-28-2008 12:14 PM
Van Charged Air Cooler Hoses/Pipes Replacement (Inlet) ripmf666 GM Spec Info 0 12-28-2008 10:50 AM
Van Charged Air Cooler Hoses/Pipes Replacement (Outlet) ripmf666 GM Spec Info 0 12-28-2008 10:49 AM
Replacement for stock tranny cooler? USAFdieselman 1994-2003 7.3L Power Stroke 4 06-06-2007 12:34 PM
