codes po678, po676, po674, po672 - TheDieselGarage.com
Thread Details Posted by JoeDirte, this thread has received 2 replies and been viewed 9664 times.
Old 06-27-2010, 02:14 AM   #1
JoeDirte
Hi Guys, My ses light came on and pulled codes po678, po676, po674, po672. The truck runs fine and sounds fine. I'm assuming the harness came loose. I took a look at the left side cover and see the harness on top of the valve cover. That's the one, right? I also see a smaller cover on top of the valve cover. Does part of the harness run through that? I've read guys using a zip tie to hold the harness under the valve cover. Anything else to check?
2000 F250 Supercab 2wd, 6spd, DP Tuner, Southbend conFE, MBRP 4" turbo back straight pipe. DIY intake.
JoeDirte is offline   Reply With Quote
Old 06-27-2010, 12:52 PM   #2
plainredtruck
plainredtruck's Avatar
Images: 11
That is your glow plugs on those cylinders.
Could be the harness is loose or the GPR is bad or the plugs are toast or . . .
See this thread for codes - http://www.thedieselgarage.com/forum...read.php?t=762
and this one - http://www.thedieselgarage.com/forum...ad.php?t=16268
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline   Reply With Quote
Old 08-22-2010, 10:31 AM   #3
JoeDirte
I replaced the vc gasket and uvch. Since those didn't do the trick, I bought the motorcraft DY876 gp module. A 10 minute swap and so far the SES light did not come back on. I saved the old vc gasket and the old uvch in case I ever need it in the future.
Help With Codes cattech05 5.9L Cummins (2003-2007.5) 3 03-11-2010 04:00 PM
codes buckslayr 2008-2010 6.4L Engine Tuner Forum 1 05-02-2009 09:09 PM
Codes cwise09 2003-2007 6.0L Power Stroke 5 02-27-2008 07:39 AM
Getting two codes... CSIPSD 1994-2003 7.3L Power Stroke 3 12-07-2007 07:36 PM
codes joker 1994-2003 7.3L Power Stroke 2 11-10-2006 12:17 PM
