1994 Chevy 6.5 K3500 - TheDieselGarage.com
Go Back   TheDieselGarage.com > GM Diesel & Truck Discussion > 6.5L Diesel Engine
Thread Details Posted by retired09, this thread has received 16 replies and been viewed 11311 times.
Old 07-12-2010, 08:02 PM   #1
retired09
Unhappy 1994 Chevy 6.5 K3500
Please help. Truck bought from brother and going to pull 27 ft camper with it. Engine runs fine when not hooked to camper. Transmission shifts fine. Looses power when pulling camper. and tranny trys not shifting into high gear. Almost like starving for fuel. Bought new PMD and remote mounted it but still have several diagonistic codes coming up. 78- wastegate fault, 35-injection pulse error, 18- pump cam pulse error, 85- undefined ratio (trans. related) , and 87- high ratio ( trans related ) Can someone tell me what parts I need to buy to get truck running right? fuel lift pump workink fine steady flow of fuel coming from bleed line. Possible oil pressure switch messing up. Thanks...
retired09 is offline   Reply With Quote
Old 07-13-2010, 01:09 AM   #2
acesneights1
acesneights1's Avatar
I won't waste time posting. It won't be long before Mikey the troll comes around. Your probably in Limp Mode, and your waste gate system is not working. Various reasons for it. Check your PM.
1986 CUCV....M1008 6.2 NV4500 5 spd
Raptor 100 LP. Serp belt conversion. 5 inch redneck master exhaust. DB2831 IP. Dmax fan. Humvee waterpump.
1981 AM General M35A2c
Lee's Auto Ranch In Ellington CT SUCKS !!
acesneights1 is offline   Reply With Quote
The Following User Says Thank You to acesneights1 For this addition to TDG:
retired09 (07-13-2010)
Old 08-04-2010, 06:57 PM   #3
retired09
Question 1994 Chevy k3500
Where is output vehicle speed sensor located? Thanks...
Old 12-19-2010, 12:52 PM   #4
retired09
Thanks for all you guys help. Problem was injector pump. Mech installed new pump and truck runs like new with full power. Block heater went out. Is there alternate method of heating block without changing heater and draining block and radiator? Its 25 degrees here and truck starts cold. Two guys said they plug in old electric blanket under hood. This sounds dangerous. Any thoughts? Thanks
Old 12-20-2010, 05:57 AM   #5
GM Guy
Man. Trans 2wd Enthusiast
There is the option of a magnetic oil pan heater, or an epoxy on oil pan heater, and having the trickle charger on low to keep the batteries warmer, both of which help it start better than dead cold, but are by no means a replacement for the block heater.
I would say to replace it, but do as you please, i hate working in the open winter weather, and I am sure you dont either.
99 Chev C3500 6.5L NV4500 14 bolt 2wd 4.10 130K White Ext, Gray Int. RC159.5" WB DRW Chassis Cab with utility box Runs Great, building up
96 GMC C2500HD 6.5L NV4500 14 bolt 2wd 3.73 240K White Ext, Blue Int. ECLB 155.5"WB SRW Pickup runs bad, getting motor right now
95 GMC C2500HD 6.5L NV4500 14 bolt 2wd 4.10 135K White Ext, Grey Int. RC 131.5"WB SRW Pickup with utility box runs strong, yet huffs on 1 hole
95 Chev C3500HD 6.5L NV4500 D80 2wd 5.13 132K White Ext, Grey Int. RC 159.5"WB DRW Chassis Cab with flatbed bad heads, needs motor re-do
94 GMC C2500HD 6.5L 4L80E 14 bolt 2wd 3.73 300K White Ext, Blue Int. Suburban needs engine
91 GMC C1500, 6.2L SM465 10 bolt 2wd 3.42 59K Red Ext, Red Int. RCLB 131.5"WB SRW Pickup needs injectors, oil cooler lines
91 Chev C1500 4.3L 5LM60 10 bolt 2wd 3.42 ??K White Ext, Red Int. RCLB 131.5"WB SRW Pickup needs...alot
Dad's:
98 GMC C3500 5.7L Vortec NV4500 208K down right now, needs head gaskets (dex cool claims another set! )
92 GMC C3500HD 6.5L Turbo NV4500 160K needs exhaust system and oil cooler lines
93 GMC C3500HD 6.5L Turbo 4L80E 260K had a crate 6.5L sometime
All above are 159.5" C&C, 10'-12' flatbed, Summit white, RC, SL trim, 2wd
96 GMC C2500HD SL ECLB 6.5L 5spd 2wd. 215K (sold to dad, ran good for a bit, started missing at idle, had blowby since purchase
84 Pete 362 COE, 300 BCIII RTOO 13 spd Fuller (3 OD ratios, hard to find) Single axle tractor, air seats, cab, suspension, OEM twin 200 gallon tanks.
74 Pete 352 COE, cat, 13spd TS, B&H grain truck
90 Marmon 57P long hood conventional, 60"flattop, 12.7L60 Series, 13 spd fuller, TS tractor
76 Marmon COE 8V92T 13spd fuller, TS B&H grain truck
95 IHC 9600 COE M11, 10 spd, SA tractor.
GM Guy is offline   Reply With Quote
Old 02-06-2011, 05:15 AM   #6
tswcountrymuscle
ChevyMeat
Hey guys im new here. I have an 94 k3500 dually 4x4 with the nv4500 and 6.5TD. I have the usual problems with it that ive heard from others. Hard starting. Idles very rough. hesitates. hickups when under a hard pull at times and is weaker than it should be. It has 195k on it. I put a new pmd with "heat sink" and relocated it on top of the intake. It didnt change a thing. I have a steady flow of fuel from the water drain. What else could it be? The pump? Injectors? Any help and advice would be appreciated.
tswcountrymuscle is offline   Reply With Quote
Old 02-06-2011, 10:15 AM   #7
racer55
racer55's Avatar
It would be best and more polite to start your own new thread describing your problem in detail.
Jumping in on someone elses thread is considered thread stealing and is frowned upon.You will get more help that way.
2005 Chev K3500 CCLB
racer55 is offline   Reply With Quote
Old 02-06-2011, 08:03 PM   #8
tswcountrymuscle
ChevyMeat
sorry bout that. ur right. im new and dont see the link to start a new thread. Again I apologize.
Old 05-27-2012, 02:17 PM   #9
retired09
Hello guys.. I was helping a buddy to pickup a small dozer. I had his dual axle heavy duty trailer hooked to my 1 ton diesel. when trying to wench dozer onto trailer it wouldnt move. It was out of gear but tracks were stuck from rust from setting up. He told me to pull up and see if we could break tracks loose. I told him I should drop trailer then hook to dozer and try moving it but he said my truck should move dozer a little even with trailer hooked up. Well...I tryed pulling up attached to wench on dozer and transmission started making grinding noise like it was trying to come out of gear. I was in reg drive and not 4 wheel. I couldnt move dozer so we unhooked wench. I took his trailer back to his house and dropped it off. When put truck into reverse, it wouldnt move and started making grinding noise like before. Put truck in 4 wheel drive and it backed up like normal. Only goes into reverse in 4 wheel drive and not reg drive. When driving down hwy with no trailer, when let off accelerator, trans makes that grinding noise but when push on accelerator it stops and drives fine. Any idea what could be problem with trans? My buddy says the trans linkage could be out of adjustment a little. Know this is long winded post but need little help. Thanks...
Old 05-27-2012, 04:27 PM   #10
hillbilli
Combat Trucker
hillbilli's Avatar
Did you ever get those trans codes straightened out when you started this thread in 2010? Im not an expert on trans, but i know grinding is bad and no reverse is usually a sign of a dead/dieing trans. Might have been a good idea to put the truck in 4low before trying to budge the dozer to take the strain off the trans.
07 Ram 2500 5.9 Megacab
96 k2500 Extcab 6.5TD vin F NV4500 3.73 245k miles
07 Hemi Durango
03 Ram 2500 (Gone but not forgotten)
hillbilli is offline   Reply With Quote
1994 Chevy Silverado C1500 6.5L diesel ehopp88ss Vehicles For Sale 5 09-07-2011 01:38 PM
1994 chevy blazzer cummins conversion hickabilly 5.9L Cummins (Pre 1994) 3 12-13-2009 01:30 AM
lift pump failure 1994 Chevy 6.5 turbo Hutchy2 6.5L Diesel Engine 7 11-11-2009 12:36 AM
1994 chevy 1500 4X4 j0hndeere4320 Whats Been Sold 0 01-23-2008 05:07 PM
1994 Chevy S10 Regular Cab ZR2 Grnkawi Whats Been Sold 0 01-22-2007 10:27 PM
