3406b cat injector removal - TheDieselGarage.com
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by jcarter8968, this thread has received 15 replies and been viewed 17390 times.
Old 07-18-2010, 05:19 PM   #1
jcarter8968
can anyone tell me how to get the injectors out after you pull the lines off it has a blot in it but the injector doesn't come out i need to replace the leaking seals, we dont want to damage anything and need to know if anything else is keeping them from coming out, thanks.
jcarter8968 is offline   Reply With Quote
Old 07-18-2010, 05:27 PM   #2
ynot
The other guy
Remove the two hole spanner nut and and use a removed cross-over line and two heal bars and blocks and slide them out. You'll need to replace the seals, screws, carbon dam seal and washer (and don't forget to buy the little plastic carbon dam installer from Cat while your there, or barrow one)
ynot is offline   Reply With Quote
Old 07-18-2010, 05:30 PM   #3
pete352
you need the cat puller it is a tube and bolt set up that screws into nozzle to pull them straight so don't bend them
pete352 is offline   Reply With Quote
Old 07-18-2010, 05:37 PM   #4
pete352
sorry tony, must have been posting at same time.never have tried that trick.
always been scared of bending one.
Old 07-18-2010, 06:28 PM   #5
ynot
The other guy
Works fine, but the tool is always better. I just bought the head and used a cut-off maxi-can stud with two angle iron up-rights welded to a cross top. Better than OEM and $15. A slide hammer is best with the same adapter, but cannot re-install them (it pulls the tip loose)...
Old 07-18-2010, 07:20 PM   #6
jcarter8968
ok I dont think I was clear enough, the leak is at the side if the head where the line screws into what i thought was the injector, it has a keeper bolt at the bottom and the part thats leaking has a nut about 3/4 wrench size, is this the injector in the side of the head or is it under the valve cover? i thought this was the injector since the line from the pump scews onto it, ifit is the injector we tried turning the socket on it but it felt like it was connected to something else, so we didnt force it not wanting to damage another line if there was one connected to this area up in the head.bottom line is do we have to take off the valve covers to get to the injectors or is that it on the side of the head? Thanks
Old 07-18-2010, 07:43 PM   #7
SledMan
SledMan's Avatar
That's an adapter mounted in the head. It has an inner injector line connected inside the head. if you are leaking oil there, replace the o-ring. If fuel is leaking, the inner line is either loose or cracked. Somtimes when you loosen either inner or outer, the older adapters will spin inside the keeper. The newer have a solid adapter to prevent this.
Pull the valve covers to hold the inner line while loosening. A 7/8 wrench on the inner line...3/4 on the outside.
You will have to pull the covers to do any of this...unless the outer line(s) are cracked or leaking. If it has a Jake, it'll have to come off too. No big deal.
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks: 1979 Kenworth W900A reg hood, 1980 Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3026 squirts. 800 cam. Acert twins via custom mount. ARP head bolts. 856 to the tires via Antrim Dyno.. with the tuned file.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline   Reply With Quote
Old 07-18-2010, 08:13 PM   #8
ynot
The other guy
4P1396 for the updated non-leakers
Old 07-18-2010, 08:23 PM   #9
jcarter8968
Ok now i'm getting the picture, it's leaking fuel down the side of the head not real bad but i thought it was an injector leaking and bought new seals for the injectors, so is there a seal there that is easy to get to or is it a complete tear down, what about the jakes do they need adjusting after you pull them off or can you just reinstall them and tourque it all down? 3 of them are leaking the truck sat 4 years before i got it and i've replaced a lot of dried out and roten lines and such so i figure this is just another part of it, i just want to get the leak stopped it runs great, thanks.
Old 07-18-2010, 08:37 PM   #10
ynot
The other guy
Do all six if you can, and can be done with Jakes on but it sux. And no, just bolt em back on no adjustment...
1988 3406b Injector pump diagram rharveysr Heavy Duty 7 01-10-2010 02:55 AM
3406B Injector??? Les2 Heavy Duty 9 02-05-2009 04:12 PM
injector removal 7.3stroker 5.9L Cummins (1998.5-2002) 9 01-24-2008 01:08 AM
Injector removal sstockton 1994-2003 7.3L Power Stroke 9 03-29-2007 03:42 AM
Help-cat 3406b Fuel Inj-pump Removal From Engine Front Drve Cover omarcano5 Heavy Duty 4 03-04-2007 02:47 AM
