How to remove Turbo - TheDieselGarage.com
Thread Details Posted by Fixinitmyself, this thread has received 12 replies and been viewed 18115 times.
Old 07-21-2010, 05:53 AM   #1
Fixinitmyself
How to remove Turbo
OK Experts.... whats the trick to get the turbo out? I can get the three bolts and two V-Band clamps loose but I can't figure out how to wiggle it out.
I suppose if the body was raised or the rear of the engine lowered there would be more clearance. So whats the trick?
2003 F250 6.0L Crew Cab
All factory stock. 187k miles.
Its Just A Machine and Machines can be fixed!
Fixinitmyself is offline   Reply With Quote
Old 07-21-2010, 11:55 AM   #2
brentos
I Wanna Go Fast!
brentos's Avatar
if your having that much trouble take off the alternator and oil fill tube...pick up the turbo off the pedistal then roll it out the hole where the alternator was..
Just another 6leaker Thanks to RCD
http://www.youtube.com/watch?v=tzVhcfZN3jw
brentos is offline   Reply With Quote
The Following User Says Thank You to brentos For this addition to TDG:
bismic (07-22-2010)
Old 07-21-2010, 12:08 PM   #3
harry6.0
harry6.0's Avatar
It rolls right out towards the alternator. Make sure you have the wiring harness cover unclipped on top of the firewall and zip tie it up out of the way to one of the wiper arms and loosen the coolant reservoir and disconnect the small hoses and put the reservoir off to the side. And of course make sure both the intake and cold air tubes are removed off the turbo and the oil feed line and vgt actuator connector. Another suggestion, when you go to put it back in, use new larger 13mm head 8.8 grade bolts with lock washers and anti-seize on the threads, makes future extraction problem free as the stock 10mm head bolts can round off easily when rusted in place. Harry
Jan 03' built 6.0/F250cc4wd trqsft/SCT-tuned by KEM-Performance/Garrett Powermax vg-turbo/blue spring mod/gauges=egt+boost+fuel+SG2/exhaust/airaid intake/DR 4.5 lift/dual bilsteins/315's/greasable ball joints/powerstop/smittybuilt/kc lights/high idle mod/roll-n-lock/T5-Rotella 10w30 with (Archoil AR9100 in the oil) and (AR6200 in the fuel)http://www.archoilspokane.com/
harry6.0 is offline   Reply With Quote
The Following User Says Thank You to harry6.0 For this addition to TDG:
bismic (07-22-2010)
Old 07-21-2010, 12:09 PM   #4
harry6.0
harry6.0's Avatar
Ya beat me to it Brent, your suggestion is correct also. Harry
Old 07-21-2010, 01:54 PM   #5
boggerman
Senior Member, on a stick
boggerman's Avatar
You also have to loosen the exhaust up pipes from the manifolds enough to let the Y-pipe rock back out of the way. This means removing the V-band clamp from the EGR cooler as well. The exhaust is probably the biggest PITA of the whole project. My turbo is out right now and I snapped three of the bolts off getting the exhaust loose.
'05 F350 Amarillo CCSB FX4, Skyjacker 2" coils, 18x9 Moto Metal 951's, 305/65-18 BFG AT K/O's, Bilsteins, Skyjacker dual stabilizers
SCT XCAL3 from Elite Diesel, AEM Brute Force Dry Flow, semi-Zoodad, Steveracer mod, CCV reroute, RCD EGR delete, Autometer Ultralites on the A-pillar
MBRP Turbo-back.
Can you keep up?!?!
Well punk, can ya??
boggerman is offline   Reply With Quote
Old 07-21-2010, 06:58 PM   #6
w_huisman
w_huisman
w_huisman's Avatar
See the attached excerpt from the Ford Workshop manual. They're instructions for a 2006, so there may be slight differences from your 2003.
A couple of tricks include:
Use a floor jack to lift the downpipe up off of the turbo.
Use a pry bar to gently pop the turbo up off of the oil return tube.
Leave the oil supply line connected to the turbo, and instead loosen it on the other end to avoid gasket replacement.
As others have said, once its popped up off the oil return tube, just roll it out towards the alternator.
http://thumb15.webshots.net/t/75/75/8/60/86/2734860860046140835zjSXvY_th.jpg
2006 F250 6.0 Lariat
cc sb 4x4 auto 70k, coolant filter, Insight + analog FP gauge. VXCF9H7 strategy
All else stock.
w_huisman is offline   Reply With Quote
The Following User Says Thank You to w_huisman For this addition to TDG:
bismic (07-22-2010)
Old 07-21-2010, 09:53 PM   #7
brentos
I Wanna Go Fast!
brentos's Avatar
thats a first if i do say so..egr clamp sure but up pipes no
Old 07-22-2010, 01:54 AM   #8
Fixinitmyself
Thanks for all the advice. I got it off.... finally!
So this is what I did:
To get to the 10mm bolt on rear of turbo I put a floor jack under the rear of tranny. Dropped the rear cross member out. Disconnected exhaust pipe at first joint near the tranny. Remove V-band clamp on turbo outlet. Backed the down pipe away from turbo. The exhaust pipe wouldn't move far enough back if the cross member was still in place. Then the rear bolt was accessible.
I then climbed up on top and applied alot of elbo grease and the turbo came free. Rolled out just like you said.
Now for the intake manifold.. I'm headed to the HPOP.
More on that later....
Old 07-22-2010, 01:55 AM   #9
silver6.0
silver6.0's Avatar
The way I do it:
1. Pull the the air box and horn, 2 8mm clamps, 2 connectors
2. Remove the 2 8mm bolts on the degas and pull it foward, this allows you to move the harness underneath the degas bottle bracket and pull it on top of it.
3. Remove the 3 push pins holding the plastic harness shield attached to the wiper cowl, this allows you to pull it foward and flip it out of your way(hold it out of your way with a zip tie or something)
4. Remove the cold side intercooler pipe, 2 11mm clamps
5. Remove the 3 10mm turbo bolts, 2 in front 1 behind
6. Remove the 2 exhaust clamps, 2 11mm bolts. An air hammer works wonders here. They're always seized to the pipes. IMO this can be the hardest part if you don't know what your doing
7.Remove the vgt connector
8. Your home free at this point, get yourself a pry bar or a big screw driver and pry the turbo off the pedistal. Once its loose ease it up and foward over the alternator.
06 f350 CCLB SRW. Performance: IDP SCT x-race, Swamps 58v PHP tuned FICM, 4" Straight pipe, Airdog II, TSD Fuel Sump, Direct solenoid from GOGO Diesel, Zoodad mod, S&B Filter, AIS stage 1 water injection, edge insight, ISSPRO guages, FP,LPOP,HPOP,Boost, Arp's, deleted
silver6.0 is offline   Reply With Quote
Old 07-22-2010, 02:05 AM   #10
silver6.0
silver6.0's Avatar
Make sure you look in the cracks between the head and the intake with a flash light before you pull it. Sure would suck to have to replace a piston because the jack*ss before you dropped a 10mm nut in there..
How difficult to remove turbo dssmith 2003-2007 6.0L Power Stroke 11 02-22-2008 03:19 AM
any suggestions on easiest way to remove clamp from turbo to y pipe? barry1me 2003-2007 6.0L Power Stroke 5 09-19-2007 12:55 PM
how to remove turbo?? mattsn 2003-2007 6.0L Power Stroke 10 07-01-2007 05:02 AM
How do you remove the clamps on the turbo? rickou812 2003-2007 6.0L Power Stroke 17 02-11-2006 05:27 PM
I just posted in the tech section how to remove and reinstall the Turbo PSDPlayer 2003-2007 6.0L Power Stroke 0 09-30-2005 07:24 PM
