N14 coolant filter shut off - TheDieselGarage.com
Thread Details Posted by 378Pete, this thread has received 4 replies and been viewed 2469 times.
Old 08-03-2010, 02:29 AM   #1
378Pete
378Pete's Avatar
I've got an n14 and can't get the coolant filter shut off to turn. I had a 1/2" breaker bar on it, wd40'd it but still won't turn. I didn't lean on it too hard for fear of breaking it and/or the filter housing.
Anyone got some tricks to try? Does the oil/coolant filter housing have to come off? How much coolant would run out if I didn't shut it off while changing it? TIA.
378Pete is offline   Reply With Quote
Old 08-03-2010, 02:47 AM   #2
cow doc
they all stick at the shut off, just pre charge the new filter and stick it on. if ya do it fast you wont lose a qt or so.
cow doc is offline   Reply With Quote
Old 08-03-2010, 05:04 AM   #3
378Pete
378Pete's Avatar
Ok thanks. Just got the truck a month ago and didn't want to fubar anything.
Old 08-03-2010, 06:17 PM   #4
ynot
The other guy
Cheap to replace if you have a big pan to catch all the A/F!! Use Nevrsieze instead of grease on the orings, and turn it every month, regardless
ynot is offline   Reply With Quote
Old 08-05-2010, 12:39 AM   #5
Johnp3
They can be a "B" to get out, I have a 3/8 inch lag screw that I use, I drill it to i/4 inch, after you have drained the coolant then I have an adapter, that goes on my slide hammer.you want to drill as far as you can, use the new valve as a depth guide, polish the housing, with a small flapper wheel. I have one of those welded onto a rod to get access. I use gear oil, on the "O" rings and as ynot said never seize on the outer section. Never acid was the engine, and it will be fine, turning it once a week when you grease the truck, works for me.
Easier way is to get a shop vacuum and have someone relieve the preasure. You do not hold it on solid but just enough to control the leakage.
Just a thought!
1988 ford van fresh overhaul, 1991 nissan pick-up 1993 Caprice 2000 GMC S10 Blaser 2007 nbs 3500 GMC 4x4 crew-cab long box 17 inch single wheels Duramax Alison. BW turnover Ball. Furakawa FL35 loader. Retired, HD mechanic, worked on engines all my life. Fabricator welder. electrician. in the process of finishing my new shop. Live in Rock Creek B.C. Wife has a fruit stand.
Johnp3 is offline   Reply With Quote
coolant filter? cumminsracer2010 6.7L Cummins (2007.5-2011) 2 04-09-2010 02:03 AM
coolant filter 05harley_6.0 Supporting Vendors Forum 4 06-14-2009 02:47 AM
coolant filter stacks 2003-2007 6.0L Power Stroke 20 04-14-2008 05:48 PM
Coolant filter King0581 1994-2003 7.3L Power Stroke 7 04-14-2008 12:53 AM
coolant filter kit bootcamp Supporting Vendors Forum 5 09-26-2007 02:31 AM
