3406B Governor problems at low idle - TheDieselGarage.com
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by turbo8781, this thread has received 19 replies and been viewed 3979 times.
Old 08-08-2010, 03:57 AM   #1
turbo8781
turbo8781's Avatar
I have a 4MG that has always had no power at an idle, or what I call "load starting power".
Almost like the gov is not sensing the load when you let the clutch out. If you don't drive it like a toyota you'll kill it every time even in 1st and that with 4.33 gears.
Its always started hard unless you tap the throttle befor you crank. I can't help but think that the two are related.
The gov has been rebiult and I raised the idle to 750 rpm and it didn't change a thing.
Its realy starting to bug me now because this job that I'm on now we have to stop and then take off loaded on 15% grade.
Any help would be greatfull.
turbo8781 is offline   Reply With Quote
Old 08-08-2010, 04:37 AM   #2
SledMan
SledMan's Avatar
I would say the race where the governor weights ride has worn holes in it....not letting the weights operate correctly. Also worn throttle shaft in housing possible. Any number of things...have to pull it apart and find the trouble. AFRC another possibility. The bore could be worn in the AFRC not letting the piston move freely.
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks: 1979 Kenworth W900A reg hood, 1980 Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3026 squirts. 800 cam. Acert twins via custom mount. ARP head bolts. 856 to the tires via Antrim Dyno.. with the tuned file.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline   Reply With Quote
Old 08-09-2010, 11:38 PM   #3
black_dog106
Little off thread here, but GREAT avatar turbo8781...
black_dog106 is offline   Reply With Quote
Old 08-10-2010, 01:29 AM   #4
turbo8781
turbo8781's Avatar
Thanks
Old 08-10-2010, 01:42 AM   #5
turbo8781
turbo8781's Avatar
Thanks for the reply Sledman. The gov section has been gon thru twice in the last couple months onec by me, and the problem didn't go away. So I thaught maybe I missed something so i took it to the cat stealer and let them go thru it and all they did was say everything looked good they also put all my fuel settings back to stock (without asking) and charged me for it, and when I raised holy hell about it they siad they would never let a truck leave there shop turned up that high and if you don't like it don't come back.
Now back to the point, isn't it the "wavy washers" that have a lot to do with idle?.
It seems like I read something about adding an extra wavy washer in one of Tony's posts but I can't remember.
Old 08-10-2010, 03:05 AM   #6
SledMan
SledMan's Avatar
The washers do nothing for idle. Tony includes it in performance mods, but it does not do anything to idle, except maybe raise it one or two.
As far as fuel settings go, just turn 'em back out.
Old 08-11-2010, 12:57 AM   #7
Johnp3
I would test the power and grounds to the shut down solinoid, back to the battery, moving the wiring around. Also check it for travel. The timming advance, I would also remove that cheaking that the Quad rings are intact, and it is operating properly. Just a thought!
1988 ford van fresh overhaul, 1991 nissan pick-up 1993 Caprice 2000 GMC S10 Blaser 2007 nbs 3500 GMC 4x4 crew-cab long box 17 inch single wheels Duramax Alison. BW turnover Ball. Furakawa FL35 loader. Retired, HD mechanic, worked on engines all my life. Fabricator welder. electrician. in the process of finishing my new shop. Live in Rock Creek B.C. Wife has a fruit stand.
Johnp3 is offline   Reply With Quote
Old 08-11-2010, 01:54 AM   #8
379Longhood
379Longhood's Avatar
It might not be called this but isn't there an idle buffer screw?? the other thought that goes thru my head is maybe the jake screw is too tight and is taking the lowside of the governor out of the picture(not sure I worded that right either)
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline   Reply With Quote
Old 08-11-2010, 02:37 AM   #9
SledMan
SledMan's Avatar
I believe if timing was not operating enough to cause slow rev up, he would have skipping and white/grey smoke. May be wrong though....
Old 08-11-2010, 02:46 AM   #10
379Longhood
Just had another thought , since it is relativly easy pull the shut off solinoid and try it with out it, shouldn't be the problem but it is an easy test
JD 820 black dash
idle problems 03RescueDiesel 2003-2007 6.0L Power Stroke 1 06-16-2009 03:10 AM
tps Problems high idle, dead pedal, blowsmoke 5.9L Cummins (1998.5-2002) 7 04-03-2007 12:44 AM
3406B high idle adjustment ???? midmofarmer Heavy Duty 5 12-14-2006 02:12 PM
Do all 6.0L have idle problems? jmcholden 2003-2007 6.0L Power Stroke 38 10-07-2006 10:48 PM
Upfitter switches for high idle. Problems.. BogginF350 General Ford Truck and Excursion 7 07-05-2006 02:15 PM
