"Low Oil Pressure" at low RPM, okay other wise??? - TheDieselGarage.com
Thread Details Posted by Levi'sford, this thread has received 7 replies and been viewed 8494 times.
Old 08-15-2010, 08:02 AM   #1
Levi'sford
Levi'sford's Avatar
I'm loosing oil pressure when at idle or low RPM's. Stopped at a stop light and got a "low oil pressure" on guage cluster. Pulled over and checked oil. It was a bit low (not sure why, no leaks, never has used oil before!). Added about 3 qts (all I had), and re-checked, maybe filled a bit high. Started truck and oil pressure guage came up to normal pressure. After a few seconds guage dropped and "low oil pressure" again. Needed to get home, midnight, storm coming, and wife is due any day now. This was our last date night for a while! Anyway upon accerlerating guage came up to normal range, and everything seemed to be running fine. Turned into sub division and when let up on accelerator pressure drops and I get the trouble messege. Rev it a bit and it comes right up??? I'm just under 64k miles and was going to change my oil tomorrow. I will for sure as I think I over filled it a bit. Two weeks ago today engine light came on which resulted in a new EGR valve and Oil cooler. Or at least I think that's what they did. I have a hard time telling what they did for sure based on the paper work they give you. Any ideas???
On a bright side I think this just convinced my wife I need a new 11'!
2006 F350 Lariat FX4, 6.0L, Auto, 3.73LS, 295/65 20 Nitto Trail Grappler on stock 08' wheels powder coated black w/ leveling kit, Line X bed liner, Ride Rite Air Bags, B&W Turnover Ball, Weather Guard Tool Box, MBRP 4" stainless turbo back exhaust, Gearhead Tuned SCT x3 and Atlas40 FCIM, Powermax Turbo w/ billet Wicked Wheel 2, ARP studs w/ machined heads, Ford gaskets, updated SCT fittings, Bullet Proof Diesel EGR, Oil Cooler, 58v 6 phase FCIM, DC Power 185 Alt., BPD water pump, S&B Intake, Coolant Filter, Air Dog II, Strictly Diesel Regulated Return, Edge CTS monitor, WPE ported intake, Mishimoto Intercooler and Radiator, Custom Royalty Core Grill. Ranch Hand bull nose front bumper, Legend rear bumper, wheel to wheel running boards, Rigid Lights on front and rear. , ARCHOIL in fuel and oil. Also use RevX Winter during cold months. Out of money for now!
Levi'sford is offline   Reply With Quote
Old 08-15-2010, 06:46 PM   #2
Levi'sford
Levi'sford's Avatar
Bump.
Also do you think it's okay to drive it 70 miles to the dealer?
Old 08-15-2010, 08:22 PM   #3
Fixinitmyself
Sounds similar to a problem I created with aftermarket oil filters. In the bottom of the oil filter housing there is a drain plug that opens when the filter is removed. If this plug is leaking you wont build engine oil pressure.
You can pull the oil filter and look into the housing with a flashlight. Way in the bottom at about the 2 o'clock position is a little button looking thing about the size of a nickel. Grab this gently with long nose pliers and make sure it operates freely up and down.
The idea is that the filter pushes this valve closed and it opens when the filter is removed.
FYI.. The gauge on the dash is a glorified idiot light. It is controlled by a pressure switch that makes at about 7 psi. The gauge will read either Zero or Normal. I installed a mechanical oil pressure gauge just so I could tell what the pressure really is.
Regarding understanding the repair ticket. Read it over real good and if you don't undersatnd something make them explain it until you are satisfied. Also its a good idea to always ask that all the "Bad" parts be shown to you. There is no excuse for the shop not to show you the bad parts.
I hope you have a backup vehicle cuase sure enough when the time comes the truck wont start or worse it will quit on the way to the hospital. Congrats on the new arrival!!!
2003 F250 6.0L Crew Cab
All factory stock. 187k miles.
Its Just A Machine and Machines can be fixed!
Fixinitmyself is offline   Reply With Quote
Old 08-16-2010, 02:15 AM   #4
Levi'sford
Levi'sford's Avatar
I will check that valve. Our 04' had that happen because of an aftermarket filter. My truck has only seen Motorcraft filters all the way around. Also, great thread about your truck. Very impressive. I wish I had your ability to trouble shoot, but most of all patience. I love working on my truck, and the maint. is fun, but just not enough hours in the day anymore. Even under Ford's warantee by the time I drive it to the dealer (about 70 miles south), leave it for who knows how long, and then pick it up I'm out a day and a half at least. Oh well, hopefully it's nothing major, and as you say, it's a machine, it can be fixed! I will say the Ford dealer in Pueblo, CO on HWY 50 has a great deisel mech. If you break down around here ask for Pete, great guy.
Do you think it's safe to drive the truck the 70 miles?
Old 08-16-2010, 02:56 AM   #5
Fixinitmyself
I would trust the idiot gauge as far as I can push the truck. If your oil pressure is truely low then you run the risk of damaging the engine. If you don't put a real gauge on it to know for sure then I would not drive it.
A $300 tow bill is cheaper than a new engine.
I got a great tow bar I made for my truck. It has come in handy recently.
Old 08-16-2010, 04:05 AM   #6
SamW
the gauge shows low pressure when you have less them 4 psi. engine needs at least 12 I believe is spec for the lpop gauge. most show 25 at idle and anywhere betweek 55 and 75 psi when running. just a thought but mabye you have a bad leak on the high pressure side, draining the low pressure system? low pressure pumps rarely go out. you have any oil dilution issues with fuel or coolant? mine was getting down to 10 psi when I had injectors leaking fuel. barely ran but that was with 5 qts fuel in the oil pan
2006 F250 CCSB
Thanks to Innovative and FCDP
SamW is offline   Reply With Quote
Old 08-16-2010, 09:51 PM   #7
bismic
If you are using 3 quarts of oil in between oil changes, and you do not see any leaks, then I would think you are burning it and something within the engine is wrong IMO. I assume it is not going into the coolant ....
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
bismic is offline   Reply With Quote
Old 08-17-2010, 03:19 AM   #8
Levi'sford
Levi'sford's Avatar
Thank you for all the info. All of those ideas crossed my mind. I was lucky... only a sending unit... $180, and three hours later it's fixed, which is good casue I have haul a load of trees tomorrow. I don't think it used any oil. I was having a hard time seeing the dip stick, poor light at 12:30 at night. When I changed the oil today there seemed to be more in the oil pan than normal. Thanks again guys.
MBRP 5", 6", 7" and 8" Diameter 18" Long Exhaust Tips dfuser Supporting Vendors Forum 0 08-14-2010 11:08 AM
The "New Diesel Emissions" prevent the use of a "Jacobs" (jake brake) HARLEY6LF250SDU General Diesel 4 01-17-2009 02:53 PM
What should "normal" Oil Pressure be? probablecause 6.5L Diesel Engine 2 04-17-2007 12:54 AM
What should "normal" Oil Pressure be? probablecause 6.2L Diesel Engine 1 04-16-2007 03:20 AM
NBA Headlines Ford: A new No. 1 contender<img src="http://espn.go.com/i/in.gif" width="11" height="11" hspace=4 border="0" alt="Insider"> RSS Feeder The Parking Lot 0 06-09-2006 07:00 AM
