The KTA 600 VS The 3408 Cat - Page 9 - TheDieselGarage.com
Thread Details Posted by LOG HAULER, this thread has received 143 replies and been viewed 73805 times.
Poll: What would you take the KTA 600 or the 3408 Cat
This poll will close on 02-03-2037 at 09:55 PM
Be advised that this is a public poll: other users can see the choice(s) you selected.
Poll Options
Old 10-11-2010, 10:30 PM   #81
Pope54x
Originally Posted by LOG HAULER View Post
Looks like the Cat gets owned!!!
Every one of my Cats will blow your poor white trash big cams off the highway! The most famous motor of all time is the 3408 cat! Ever heard of Monfort? They named the left lane on I-80 Monfort lane after them and they ran 1693 Cats and they would not be passed or out pulled!
Pope54x is offline   Reply With Quote
Old 10-11-2010, 11:47 PM   #82
Mr. Haney
Mr. Haney's Avatar
Evidently you don't know the difference between a Cummins KTA 600 and a Cummins Big Cam 400. Turn the fuel to a Big Cam 400 and crack the block around the head bolt holes...........turn the fuel up on a KTA 600 and hold on, you're going for a ride. I'm not saying that either the 3408 or the KTA were better back than compared to the motors of today.......the C-15/C-16 will out do both of them on the road today with the fuel cranked to them.
Both the 3408 and the KTA had problems when pushed hard, but with the right parts that are available now, I'd take the KTA over the 3408 if power was the only thing I wanted to build. If reliability and fuel mileage was in the equation along with power and street-ability...........the C-16 is my choice
Mr. Haney is offline   Reply With Quote
Old 10-12-2010, 02:32 AM   #83
SmokinCAT
SmokinCAT's Avatar
I wanna see the day you turn that thing into a sled puller and go after Dave Greek and all them guys to see what a hot caterpillar will do against them guys.
I know I have seen barnetts truck give them a run for their money on the right track, but I think your truck would surprise them. I know the KT we pull with is the best running mechanical truck we pull with, but the guy with the very hot E model makes us look stupid.
Cody.
79 KW W900A 3406B, Holset HC5 turbo, RTO12513,
4.11 SQHP rockwells
79 KW K100C 400BC1, Holset HT4B hybrid, custom
injectors, RTO12513, 4.33 eaton DS380s
00 Freightliner Classic XL C15
83 KW K100C 400BC3
SmokinCAT is online now   Reply With Quote
Old 10-12-2010, 07:24 AM   #84
Pope54x
The reason I was saying that is because the guy who said cat get owned has two big cams and he is in no position to say that considering a big cam is probably the biggest pos i have ever owned. I love how yall think the KTA is great greatest thing ever. Cat built the world while cummins built the anchors to hold it down!
Old 10-12-2010, 09:38 AM   #85
SmokinCAT
SmokinCAT's Avatar
Pretty harsh words against one of the most reliable motors built up until cummins screwed it up with STC, for the people still running mechanical motors they are a good option for cheap parts and good fuel mileage.
As Haney said you havent been around too many KTs, or your opinion would be different, they are in a class of their own these days, to me they are built more in the mind of a caterpillar, they are extremely overbuilt for a stock application.
Then there is the old saying there is no replacment for displacement.
Cody.
4.11 SQHP rockwells
83 KW K100C 400BC3
Old 10-12-2010, 09:58 PM   #86
snowman_w900
snowman_w900's Avatar
whats poor white trash got to do with a big cam cummins.......
and i'd say the reason yours were all junk is because you didnt know how to work on them. codys right, stc were crap in alot of ways, but a fixed timing bigcam, cant beat them if ya know what your doin. cheap and easy...
snowman_w900 is offline   Reply With Quote
Old 10-12-2010, 11:06 PM   #87
Hotrodx199
Well my dads friend has a 2001 KW KTA-600 (more like 850) and he was pulling a lowboy and on a hill he passed a greyhound bus. The people on the bus were shocked to see a semi truck up shifting gears (10+4 transmission) on a hill, AND passing a greyhound bus with a lowboy.
Hotrodx199 is offline   Reply With Quote
Old 10-12-2010, 11:13 PM   #88
SmokinCAT
SmokinCAT's Avatar
Unless he did alot of work it's not a KT in a 2001 model truck. They haven been put in trucks since the early 80s same thing on the 3408.
Cody.
4.11 SQHP rockwells
83 KW K100C 400BC3
Old 10-13-2010, 01:40 AM   #89
BLACKKW
If it rele is a 10+4 trans as you say it may have a KT that was transplanted into it other wise it woud be an SIGNATURE ISX cm570 600 horse. if it rele is a KT i think that we all want 2 see pictures of it
BLACKKW is offline   Reply With Quote
Old 10-13-2010, 02:59 PM   #90
xxxxxV8Lenny
I don't know much about Cats but if I understand right 3408 has same 11mm plungers in the pump as 3406 and I know how much fuel they can deliver in an inline pump, no matter if there is Cat or Bosch printed in the housing. Max 750-800 hp, a little bit more with all out smoke and sky high EGTs that burns your engine in 15 seconds. Cummins has 9.5mm unit pumps and they are good to at least 900 hp without smoke in 10 litre engine with stock injector travel. So without changing to 13mm Bosch pump it seems like 3408 gets owned.
And 1693 Cat, wasn't that some ancient pre-chamber engine?
xxxxxV8Lenny is offline   Reply With Quote
Cat 1676 and 3408 Gillig8V71 Medium and Heavy Duty 1 01-24-2010 02:35 AM
3408 dita oldpetedude Medium and Heavy Duty 37 05-12-2009 03:14 PM
Cat 1676 and 3408 Gillig8V71 Medium and Heavy Duty 8 03-16-2008 10:18 PM
cat 3408 McDiesel Medium and Heavy Duty 23 10-14-2006 01:35 AM
