CUMMINS BIG CAM IV OVERHEATING. . - TheDieselGarage.com
Thread Details Posted by knox, this thread has received 5 replies and been viewed 3552 times.
Old 09-08-2010, 09:02 AM   #1
knox
I am running a 1987 big came iv low flow cooling and is currently giving me a headache. .Its overheating whenever it exceeds 40km/hr laden or unladen.Have changed water pump,locked the clutch fan to engine speed,redone radiator and got thermostats removed by the mechanic and never replaced.Now the truck is overheating above 40km/hr.what could be wrong???
knox is offline   Reply With Quote
Old 09-08-2010, 09:30 AM   #2
SledMan
SledMan's Avatar
Not sure what you mean about 'never replaced".....did he replace them or what?
I would put money on the baffle being broken in the bottom of the radiator. There's a small baffle that the low-flow system uses...that's known to come loose and cause heating problems. Ask a reputable truck radiator shop.
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks:1980 KW Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. 2003 Pete EXHD. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3025 squirts. 800 cam. Acert twins via custom mount. ARP head bolts.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline   Reply With Quote
Old 09-09-2010, 01:20 PM   #3
mrdevildog
mrdevildog's Avatar
AND CHANGE THE THERMOSTATS-its a cheap repair to prevent a big problem.
mrdevildog is offline   Reply With Quote
Old 09-09-2010, 04:54 PM   #4
Johnp3
If you have an infrared temp gun you can usually measure the radiator temperatures and tell if the coolant is flowing properly threw it.
You can test the thermostats for proper operation at the same time with the temp gun.
1988 ford van fresh overhaul, 1991 nissan pick-up 1993 Caprice 2000 GMC S10 Blaser 2007 nbs 3500 GMC 4x4 crew-cab long box 17 inch single wheels Duramax Alison. BW turnover Ball. Furakawa FL35 loader. Retired, HD mechanic, worked on engines all my life. Fabricator welder. electrician. in the process of finishing my new shop. Live in Rock Creek B.C. Wife has a fruit stand.
Johnp3 is offline   Reply With Quote
Old 09-09-2010, 05:53 PM   #5
knox
By tommorow I should have an update.Thanx all
Old 09-11-2010, 04:08 PM   #6
knox
Guess what. . after replacing the thermostats it began to run normal.
Many thanx all.
overheating 6LBoss 2003-2007 6.0L Power Stroke 3 07-02-2010 05:10 AM
overheating...? gon2sea 5.9L Cummins (Pre 1994) 8 06-06-2010 10:16 PM
overheating rverrcer Duramax 2001-2004 (LB7) 5 02-15-2010 04:24 PM
F-350 Overheating F350MX 2003-2007 6.0L Power Stroke 16 07-23-2009 10:46 PM
Still OVERheating Marvin Medium and Heavy Duty 18 07-08-2007 02:28 AM
