first DIY oil change on the 6.7... - TheDieselGarage.com
Go Back   TheDieselGarage.com > Ford Diesel & Truck Discussions > 2011+ 6.7L Power Stroke Diesel
Thread Details Posted by mudguppy, this thread has received 15 replies and been viewed 10332 times.
Old 09-18-2010, 07:43 PM   #1
mudguppy
Tebow-in'...
mudguppy's Avatar
and it SUCKED!!!!
so i break out the manual and run through the procedure just to make sure i understood about the 1/4 turn drain plug and it was extremely straight-forward.
so i got my 15qt drain pan and ratchet+extension and went in on the creeper. used the ratchet and loosened the plug (which is actually a little more than a 1/4 turn; it says 120 on the plug).
here's where disaster struck: using the extension, i pulled the drain plug all the way out. dude - a solid, 1"+ stream of oil shot out of the pan and over-shot the drain pan by at least a foot. so i quickly grabbed the pan and scoot it under the impact zone of the oil geiser. then i quickly observed the drain pan become totally overwhelmed by the amount of oil input. it isn't that it seemed like the crankcase was under pressure, but that the oil drain opening allows for a huge volume of oil to free-flow out very rapidly.
i had to stick the ratchet w/ plug back into the oil pan to stem the oil flow. i had to keep the plug/ratchet in the oil pan opening to throttle the draining oil to a managable level so it did not continue to overwhelm the drain pan. i was basically covered in oil. it must have looked like i've never changed oil before in my life.
but it gets better - so i loosen the filter, and as i expected, oil starts flowing down the sides of the filter. so i wait. and wait. and wait. finally, i grab the filter and twist if off the few remaining threads. as expected, i dumped the full filter into the drain pan. what i didn't expect, was what seemed like another 1/2 of a quart continued to poor out of the oil filter adapter. i caught it in the drain pan, no biggie, just didn't expect it.
what was aggrivating though is that the oil filter housing continued to drain. and drain. and drain. and basically never stopped draining. so i finally stuck the new filter up there and ran it up snug as quickly as i could. but with all the dripping oil, the out side rim of the new filter was filled up w/ oil - i had to wipe down the new filter several times over the new few minutes to keep the filter clean-ish.
alright, here's the point to my whining: i am extremely disappointed at the oil change process coming from the 6.0, where you could change oil in your Sunday best and stay clean doing it. i feel like FoMoCo really screwed the pooch by straying from International's method in this arena. hopefully i don't have to do this too often with the oil life monitoring.
basically, changing the oil in my truck is now about as elegant as chitting the bed - there really isn't any 'class' involved and you can't do it w/ out getting messy.
just wanted to give you all a heads-up before you get pissed on in your driveway, too.
Travis
2011 F350 SRW CC/SB 4x4 Lariat 6.7 PSD Dark Pearl Metalic
1974 Bob'd Deuce on 16.00-20 XZLs, locked front and rear, hydro steering, front and rear winches, 5.9CTD/nv4500, hydro-boosted disc brakes
Member since Jul 05, Dually Club Member #63, American Club Member #42, FOSP Member #8
mudguppy is offline   Reply With Quote
The Following User Says Thank You to mudguppy For this addition to TDG:
vrsc (09-18-2010)
Old 09-18-2010, 08:11 PM   #2
vrsc
vrsc's Avatar
Images: 47
thanks for the laughs man. Your write up funny as hell. Sorry to hear about your experience. I can agree the the 6.0 oil change procedure was clean and easy, but I found that since my 2011 is lifted 8 inches, I am able to get a 5 gal bucket's mouth to catch the stream of oil. Still wat messier than the 6.0
2011 F250 Golden Bronze/Arizona Beige Fully Loaded King Ranch FX4, Chrome Package, 6.7 PSD, 4x4 E-Locker, 3.55, Color Matched Line-x Bed and toolbox
Icon Vehicle Dynamics/ One Up Offroad Suspension Lift
Icon Vehicle Dynamics 7"-9" Box Kit and Coil Springs
OUO ALA One Up Offroad Adjustable Link Arms
OUO Traction Bars One Up Offroad Adaptable Traction Bars
OUO Traction Block One Up Offroad Traction Block Kit - 8" w/Bump Stops - 5 Degree
OUO Position Adjustable Flex U-bolt Top Plates
OUO U-Bolts One Up Offroad 3/4" U-Bolt Kit
Icon Signature Series Shocks (3M clear film protected)
Icon Vehicle Dynamics Dual Steering Stabilizer Kit(3M clear film protected)
BMF Novakaine 8 Chrome 20x10
Toyo M/T 37x13.50x20
Color matched Brake Calipers, Amp Research Steps
H+S Mini, CAT/DPF/EGR delete, AFE intake
Ford Factory Navigation
JL Audio Clean Sweep, JL Audio HD900/5
Focal 165 KRX2 in front with TNK Tweeters
Focal 165 KR2 in back with TNK Tweeters
JL Audio 13TW5 in an spl2K box behind rear seat
JL Audio 0/Gauge Amp kit, JL Audio 4 channel RCA's
Dynamat Extreme Deadened Front Doors, Rear Wall and Doors
vrsc is offline   Reply With Quote
Old 09-19-2010, 06:14 AM   #3
Levi'sford
Levi'sford's Avatar
I haven't laughed that hard in a while. It's settled then, I will just keep my 6.0 and get new sheets every few weeks.
2006 F350 Lariat FX4, 6.0L, Auto, 3.73LS, 295/65 20 Nitto Trail Grappler on stock 08' wheels powder coated black w/ leveling kit, Line X bed liner, Ride Rite Air Bags, B&W Turnover Ball, Weather Guard Tool Box, MBRP 4" stainless turbo back exhaust, Gearhead Tuned SCT x3 and Atlas40 FCIM, Powermax Turbo w/ billet Wicked Wheel 2, ARP studs w/ machined heads, Ford gaskets, updated SCT fittings, Bullet Proof Diesel EGR, Oil Cooler, 58v 6 phase FCIM, DC Power 185 Alt., BPD water pump, S&B Intake, Coolant Filter, Air Dog II, Strictly Diesel Regulated Return, Edge CTS monitor, WPE ported intake, Mishimoto Intercooler and Radiator, Custom Royalty Core Grill. Ranch Hand bull nose front bumper, Legend rear bumper, wheel to wheel running boards, Rigid Lights on front and rear. , ARCHOIL in fuel and oil. Also use RevX Winter during cold months. Out of money for now!
Levi'sford is offline   Reply With Quote
Old 09-19-2010, 07:20 AM   #4
Trip
Trip's Avatar
Well come on now they had to do something to let someone complain somewhere. you cant have it all! now I want the pics of all this. there has to be a better way of accomplishing this maybe like a Camry or rx7 you need to puncture the filter housing allowing it to drain to the pan before you remove the filter? I dont see a ford tech getting P($$ed on by these trucks all day.
03 F-250 Lariat 4X4 6.0L- NEW ID PROGRAMED FICM 105,000 (sitting on shelf while I figure out whats going on with the turd...furd) wheel berring 103,000 Dfuser coolant filter104,000, EGR plug104,000mi, y-pipe109,800mi,bootlegged 3.5" straight pipe110,000, rotors and pads on all 4 points 110,400mi, 35X12.50R17 Toyo M/T@ 111,300 ICP sensor 115,000
taken over at 103,000mi June-2009
WALNUT (anti-ACORN) member#23
Trip is offline   Reply With Quote
Old 09-19-2010, 01:36 PM   #5
GUTTS
GUTTS's Avatar
i think a video would be awesome then Ford can watch it and we can laugh but that's just a bonus
GUTTS is offline   Reply With Quote
Old 09-19-2010, 11:19 PM   #6
EpicCowlick
EpicCowlick's Avatar
I posted this video on another forum but not here. Guppy, maybe it would have helped. Sorry dude.
11 SD 6.7L CC SWB White Platinum Lariat Ultimate
2" Auto Spring leveling kit (required caster correction)
315/60/20 Toyo MT's
Line-X Bedliner/Door Seal Mod
DDM Tuning HI/Low HID's (H13, 55W, Color 5,000K)
Titan 50 gallon tank
EpicCowlick is offline   Reply With Quote
Old 09-20-2010, 01:02 AM   #7
strokin 64
i knocked a hole in the bottom of the oil filter with a screw driver to try to control some of the mess but it still had a lot left when i took it off. i guess just have a hand full rags cause your gonna get messy! the 5gal bucket helps to
2011 f-350 crew cab sw
8" pro comp lift
22" KMC with 37" toyo
strokin 64 is offline   Reply With Quote
Old 09-20-2010, 04:14 AM   #8
Jcard
Jcard's Avatar
I did the oil mess on the filter side too. Have to revert back to punching a hole like the good ole 7.3 oil change days.
Jcard is offline   Reply With Quote
Old 09-20-2010, 02:45 PM   #9
mudguppy
Tebow-in'...
mudguppy's Avatar
Originally Posted by EpicCowlick View Post
... Guppy, maybe it would have helped. ...
yes. yes, it would have.
i blame you.
Travis
Old 09-20-2010, 02:57 PM   #10
EpicCowlick
i blame you.
. Just being proactive now but here's another one on how to refill the DEF.
315/60/20 Toyo MT's
What else to change bigtrxs 2003-2007 6.0L Power Stroke 5 01-25-2008 02:48 AM
Oil Change Nolafishr Duramax 07.5-2010 (LMM) 2 01-02-2008 05:48 PM
My first oil change...? D-Man 1994-2003 7.3L Power Stroke 5 01-11-2007 08:42 AM
Can you Change an SCT pgm yourself GreenMule 2003-2007 6.0 Tuner Forum 3 01-01-2007 11:42 AM
first oil change and fuel filter change? chvylac 2003-2007 6.0L Power Stroke 10 12-03-2006 09:26 AM
