dt 466 fuel issue - TheDieselGarage.com
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Medium Duty
Thread Details Posted by yellow5, this thread has received 4 replies and been viewed 1017 times.
Old 09-19-2010, 07:26 PM   #1
yellow5
dt 466 fuel issue
hey guys just purchased a 1995 ih with dt466 that has gave me some problems soon after getting it, ran fine from the start then would run for around 10min. or so then like it was running outta fuel so changed all filters fuel,air,oil etc.. same problem thought it may be sucking air somehow checked for any leaks in lines wet spots etc. nothing.it will start back when it dies but rather hard to start,let the truck set for half an hour or so it will start as soon as you touch key,my injector pump repair guys are saying the rail is going bad in the pump is this true? and how do you go about locking the pump for removal are they like cummins need to be locked before removal? all help will be greatly app. times are hard trying to save all i can thanks in advance
yellow5 is offline   Reply With Quote
Old 09-19-2010, 10:37 PM   #2
379Longhood
379Longhood's Avatar
your description sounds more like a collapsed fuel line to me or a water seperator that you might have missed
I would also like a definition for the rail in an inline mechanical pump
Some 466 pumps have an oil pressure saftey interlock
Never enough of JohnG should be along soon with a better answer
most times 466 question get answered faster on the MD forum http://www.thedieselgarage.com/forum...sprune=-1&f=65
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline   Reply With Quote
Old 09-19-2010, 11:00 PM   #3
Dodgefarmer
Dodgefarmer's Avatar
It could be there is dirt/debris floating in the fuel tank and when it gets suck up against the fuel line going out of the tank it plugs the line. After engine stops awhile the dirt floats away from the line since there is no suction holding it and the line is opened again. Then the process starts all over again: I have seen this happen many times. Drain the tank and make sure its clean.
Remember not to talk bad about farmers with your mouth full!
2013 6.7 CTD 2500, 800 ft-lbs torque, 4x4 crewcab Larmine Longhorn edition, 6 sp. auto, 2 tone white/gold
--07 6.7CTD 2500 4x4, Quad Cab, Big Horn Pkg. 3.73, airbags, 6sp auto, with Mag-Hytec deep pan.- sold but not forgotten.
--08 36' Jazz 5th wheel,triple slide, 12,000lbs
--28' 22,400# PJ goosneck beaver tail trailer
--95 & 96 5.9CTD 4x4 5sp. ext. cab. 33x12.50x16 front, 33x15.50x16 rear tires. R-1 tread, wheelbase shortened 30". Used as tugs on farm
--81 IH 1800, DT466 210hp, 10 speed,
--95 FL70, 8.3 cummins 275hp, 10speed
--79 GMC 7000, DD 6V53 210 hp, 6sp ally
-- A whole bunch farm equipment, all colors
singles club # 198
WALNUT MEMBER #11(workers aganist lazy non-producers united together)
Dodgefarmer is offline   Reply With Quote
Old 09-19-2010, 11:09 PM   #4
379Longhood
Duh why didn't I mention that , I had a detriot with an intermitant fuel issue , it had wood shavings in the dip tube, and the would intermitantly plug the elbow, blew the line back several times but they stayed in the tube, if I had drained the tank and blown it back it prolly would have worked
Long story longer took a bunch of crap off to get the tube out of the tank (was checking the fuel lines for restriction at this point using a vaccum pump and guage ) and found the restriction in the tube. usually the simplest answer is the solution
JD 820 black dash
Old 09-29-2010, 08:13 PM   #5
Victor
Senior diesel friend
Victor's Avatar
FUEL TANK
It's 95, means 15 years old. When I getting this old truck - fuel tank comes out before I have registration.
If it's not diesel - it's my chainsaw.
Victor is offline   Reply With Quote
fuel gauge issue cummins81888 5.9L Cummins (1998.5-2002) 4 03-03-2010 02:33 PM
fuel issue or is it??? colorado7.3 7.3L and 6.9 IDI (Pre 1994) 2 03-27-2008 02:23 AM
Fuel issue TheDiesel 7.3L and 6.9 IDI (Pre 1994) 4 07-27-2007 04:59 AM
fuel filter issue imported_not4mud Duramax 2001-2004 (LB7) 4 06-25-2007 12:59 PM
98.5 fuel issue huntingman270 5.9L Cummins (1998.5-2002) 20 01-21-2007 04:43 PM
