Cat Bridge Engine? - TheDieselGarage.com
Thread Details Posted by unforgiven76, this thread has received 22 replies and been viewed 15045 times.
Old 09-23-2010, 12:09 AM   #1
unforgiven76
Cat Bridge Engine?
From what I have been in 2004 Cat made what was referred to as bridge engine and noone has any nice words to say about them. Were all 2004 trucks equiped with these engines? What was wrong with them and is there anyway of correcting them and making them worth having? I seem to come across a lot of clean 2004 trucks for sale but I always walk away if not run. So look forward to your responses. Thanks.
unforgiven76 is offline   Reply With Quote
Old 09-23-2010, 12:28 AM   #2
KenworthKen
The truck I used to have had a 525 bridge engine in it. In stock form not a very good engine. Didn't pull any better then a 475 and the EGT's ran at 1200 to 1300 degrees. Then I put a 100 ohm resister on the fuel sensor and a 10 ohm resister on the air sensor and I also put code 6999 on the injectors. What a difference that made. Gained 10 - 12 km/h on the hills and the EGT's cooled down to 1000 - 1100 degrees. It even idled a lot smoother.
KenworthKen is offline   Reply With Quote
The Following 2 Users Say Thank You to KenworthKen For this addition to TDG:
Rogerstar1 (10-25-2012), unforgiven76 (09-24-2010)
Old 09-23-2010, 12:35 AM   #3
SMN
SMN's Avatar
They are the cat motors with the serial number prefix MBN. They were in '03 and '04 model trucks. I believe the later '03's, and earlier '04's. Some '04's will be acerts. I think a few guys here run that MBN motor, and have done work to better their performance. I am sure they will comment and give you a lot more info.
SMN is offline   Reply With Quote
The Following 2 Users Say Thank You to SMN For this addition to TDG:
Rogerstar1 (09-23-2010), unforgiven76 (09-24-2010)
Old 09-23-2010, 01:02 AM   #4
ynot
The other guy
MBN's are 6NZ's with AdemIV 32 bit processors and 1000 inj's (and low cam). They suk. Computer tweeking, as mentioned, and it's a good motor. 58 injectors (+/- cam) and it's a horse
ynot is offline   Reply With Quote
The Following 3 Users Say Thank You to ynot For this addition to TDG:
kenw007 (09-23-2010), Rogerstar1 (09-23-2010), unforgiven76 (09-24-2010)
Old 09-23-2010, 01:09 AM   #5
unforgiven76
Are there any mechanical weaknesses in these motors or is it just programming and injectors? Thanks for your responses.
Old 09-23-2010, 01:32 AM   #6
ynot
The other guy
Not per say. Just another yellow motor
The Following User Says Thank You to ynot For this addition to TDG:
Old 09-23-2010, 01:53 AM   #7
TN-DiEseLjunKy
I have one. Stock it was sucky. I put a nonwastegated borg warner turbo on it, and flashed it to some older 6NZ files, plus a fuel temp wire now it's a great motor. Putting 6NZ injectors and camshaft, or PDI injectors with 800hp marine cam would make mine better but it does good now. On the rollers stock form MBN 475 flash it put 421hp down we estimated it almost puts 500 down now. Pulls like a champ. Egt's never over 900* now. In stock form would go to 1200* easily or higher. I have about $2500 in ecm flash, turbo upgrade, and fuel temp wire to make it right. I would not hesitate to buy a well maintained stock MBN but would definitely do some tweaking to it to make it good. When negotiating price on an MBN truck use the fact that bridge motors are not so great from the research you have done to get the selling price down even lower. Tell them you have been looking at a similar '02 6NZ truck or something along those lines. Get a W900 or 379 with an MBN so you wont have any cooling issues. I have a T600 and right now dont have any problems but I belive I'm at the limit of how high I can go performacewise without first putting a 4 core radiator in.
Chris
2007 Ram 2500, SLT Big Horn, Mineral Grey, 4WD, 5.9L, BMK11 oil bypass, G56, 285/70/17 Toyo AT,
Gear Vendors overdrive, Dynatrac manual hubs, Smarty Jr, 6" intake, 4" turboback
2003 Kenworth T600, Black, MBN C-15, 13 speed Eaton trans, 3:70 Eaton rears, AG380 suspension, 11R 22.5's, full gauges: Unbridged Cat - Borg Warner non-waste gated turbo - fuel temp wire - 6NZ 550hp/1850tq 2300rpm Brakesaver ecm flash, Thanks Mr. Haney!
TN-DiEseLjunKy is offline   Reply With Quote
The Following 3 Users Say Thank You to TN-DiEseLjunKy For this addition to TDG:
kenw007 (09-23-2010), Rogerstar1 (10-25-2012), unforgiven76 (09-24-2010)
Old 09-23-2010, 03:29 AM   #8
OTT
PDI will tell you to put at least a stage 1 turbo and tune with there manifold on to make it run good. To really make them a horse you need injectors and a cam then you pretty much have a 6nz. We have 3 of them in our fleet and they are all right. I will tell you they are better then are isx cummins.
2011 389 c-16 stage 2 tune stage 2 injectors stage 3 cam stage 3 turbo Coming soon Twin turbos!
07 379x 625 mxs, stage1 pdi tune,pdi manifold
07 chevy 2500, efi tuned by the master Idaho Rob, 5" exhaust,Tranny built by myself with stage 4 suncoast parts tc1056
PDI dealer in Nebraska
"If I wanted a 7cz tune file I would buy a 7cz"!
The Name Is Dusty AKA Mr.Young Dealer
OTT is offline   Reply With Quote
The Following User Says Thank You to OTT For this addition to TDG:
Old 09-23-2010, 04:12 AM   #9
bmoeller
bmoeller's Avatar
No coolant temp issues with the MBN and the W9. Tony put a fresh set of injectors in for me last month. No more haze at idle in the summer and running pretty good. Mileage is back up closer to where it used to be. Up from the 4.7-4.9 range to 5-5.3, and gonna get the fuel temp wire back on. Pick up .3-.4mpg with that and more power. Has the 525hp uprate, but we didn't take the time to see what the other ECM settings it might have done to it as well. Pulls hard and don't get passed very often. Stays in the ol' Monfort lane pretty good.
"Obama = Hoax and Chains"
Old 09-23-2010, 08:05 AM   #10
TN-DiEseLjunKy
The turbo I have is the same turbo PDI calls a stage 1 they sell them for $2400 I paid $1683 for mine from turbo exchange. The cheapest way to fix an MBN is to flash it 6NZ then disable the stock turbo's wastegate. That'll give you a 550 motor that will run better than most every newer 500+ truck on the road. Since I've done my upgrades I havent run across a truck yet that can hang with mine. I'd like to have a radiator, cam, and injector upgrade with a 7CZ flash though. Right now I'm averaging 5.9mpg
Chris
The Following 2 Users Say Thank You to TN-DiEseLjunKy For this addition to TDG:
valve bridge direction??? archibald tuttle 2003-2007 6.0L Power Stroke 2 01-23-2010 10:58 PM
how strong is that bridge? Rcannon The Parking Lot 12 07-06-2009 09:18 AM
The Bridge OOWeaver68 The Parking Lot 6 01-20-2009 07:49 PM
How Tall Was That Bridge ???? fordt The Parking Lot 30 03-01-2006 04:15 PM
Yall ever get skeered when you go over a big bridge jponder The Parking Lot 24 06-24-2005 04:05 AM
