cold start problems - TheDieselGarage.com
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins (2003-2007.5)
Thread Details Posted by colgate372, this thread has received 18 replies and been viewed 9496 times.
Old 10-19-2010, 09:34 PM   #1
colgate372
cold start problems
I have a 04 and last year I didnot plug it in the temp overnight was 30*. My truck would crank all day till we ran the battery down, but no start. I pluged it in for about an hour and it fired right up. this has happen a few time at varying temps all below 50* and unless I plug it in it will not start. Not only is this embarrising, but it also p#$#% me off. I am going to try a differant oil 15W40+50 john deere and see if it will help.
colgate372 is offline   Reply With Quote
Old 10-20-2010, 02:57 AM   #2
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
What oil are you running? I run Valvoline Premium Blue 15W40 and never have cold start issues? I would check your fuse for your grid heater and the check to see if you have power to your grid heater. just my 0.02s
"Only accurate rifles are interesting" -Townsend Whelen
2012 Ram 2500 Crew Cab Big Horn
6.7L 68RFE 4wd
Yeah its stock.
Edge Insight CTS / Line-X / Access Bed Cover
B&W Turnover Ball / Companion Hitch
Pac Brake Air Bags
On Board Air
2010 John Deere 2305
2010 Jeep Wrangler JK Unlimited Rubicon
2015 Keystone Impact 311 Toyhauler
9-11-2001 NEVER FORGET
neeltburn is offline   Reply With Quote
Old 10-20-2010, 02:49 PM   #3
colgate372
I am running 15W40 rottella I check the fuse and go from there to the battery connection and heater connection
thx
Old 10-20-2010, 11:46 PM   #4
MART5.9
MART5.9's Avatar
Around 30F type of oil does`nt matter at all. It`s not close to cold enought to do a difference. Trust me i live way up in Canada and you can feel a difference between syntec and mineral oil around 15F on cold start.If it does`nt get any lower than that frequently where you live at no need for syntec oil. Also your truck should easyly start without being plugged as low as 0 F if your batteries are good. There`s nothing to plug my truck at the shop and it often get down to -22F and it starts like a gaser after sitting for 14 hours or more.
2006 3500 mega cab SLT auto.
Diamond eye turbo back, S&B cold air intake,62mm turbo, billet tranny, smartyJR....
Proud to now participate to global warming
EGR and DPF are the worst CRAP ever and the worst is still to come.....UREA !
MART5.9 is offline   Reply With Quote
Old 10-24-2010, 02:42 PM   #5
colgate372
cold start problems
Well here we go, worked on the truck all day trying to get the heaters to work in the intake, hoping this would solve the issue. Tried starting it at 40* this morning, turned on the heater with switch in the cab watch the volts drop on the batteries. Still nothing now I will plug it in for the next hour and try again. As long as this truck is plugged n it will start. I know I should not have to do this. Suggestion
Old 10-25-2010, 12:17 AM   #6
patriot2500
Born in the USA
patriot2500's Avatar
Send a message via AIM to patriot2500
Is it possible the block heater is bad? I don't know if I am way off here, just trying to help out.
Tom
2004.5 Dodge 2500 QC/LB - Goerand 48RE, 4.10's, AFE Stage II, Magnaflow 5" TBE w/6" tip, Smarty TNT/REVO, PacBrake, ATS Manifold, ATS Triple Lok Commander, ISSPRO EGT, Trans, Boost on the pillar, FASS 150, 35X12.50 Toyo M/T's on '06 wheels, Mag/Hytec front/rear diff covers and trans pan, Full Recon Lighting, Prodigy Brake Controller, Silverstars, WeatherGuard Toolbox, BackRack, Kenwood Radio w/ 2 MTX Thunder 4500 subs, Sirius, CompuStar Alarm/Remote Start, Husky Floormats
Thanks to Kenny @ KTPerformance.net
2007 Honda Foreman 500 ES - Rack bag, gun racks, trailer hitch, Cycle Country plow, 27" ITP's on ITP Delta Steel Wheels
patriot2500 is offline   Reply With Quote
Old 10-25-2010, 01:40 PM   #7
colgate372
Block heater is doing something right because it will start when it is plugged in. It is when I don't plug it in and the temp is below 60 over night it will not start. The intake heater is now working manually with a switch in the cab. I tried it 2 days ago and all it managed to do was run the battery down. I live in cheyenne Wy the temperature is not getting any better.
Old 10-26-2010, 12:17 AM   #8
MART5.9
MART5.9's Avatar
that means your grid heater is working well. It has to be something else but I`m lost. Does`nt make any sense if the truck is plug or not at 40F, it should even start without the grid heater working at this temperature It means your problem comes from something else than your block heater or grid heater. Don`t know if these truck have a cold start switch or other electronic sensor for cold start
Old 11-03-2010, 01:46 AM   #9
BriteWhiteRam
CRAZY CANUCK
BriteWhiteRam's Avatar
here's a wacky idea, im curious about your IAT sensor, I've heard tell of ECM's doing strange things if the intake air temp sensor is dammaged or malfunctioning, if the ecm is getting bad signals from the sensor it will try to compensate for it.... and make the truck run like a pile of crap
Aaron the Crazy Canuck
2006 Chevrolet Silverado LT 2500: LBZ - Allison, Greystone Metallic, 4x4,PPE airbox mod, missing muffler/cat, EFILive tuned by Nick at duramaxtuner, MA tie-rod sleeves and Grade C headgaskets
Totalled!! May 2nd 2008-2005 Dodge Ram 3500 laramie: Cummins auto, plain white, rebuilt tranny
1986 Mercury Capri - 5.0L, AOD, shorty headers, acell ignition, Holly street dominator intake, Holly 625 vacuum secondaries carb, Dual glass packs "my little yellow terror"
DURAMAX INDEX; You want a Duramax? you want to click on this >>The Duramax Index
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
Check out the NEW and IMPROVED TDG Truck Poll!
TDG TOTQ
BriteWhiteRam is offline   Reply With Quote
Old 11-03-2010, 02:20 AM   #10
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Cold Start Problems smryan3326 5.9L Cummins (2003-2007.5) 11 10-27-2010 06:51 PM
LB7 Cold Start Problems. HELP PLEASE 2500HD03 Duramax 2001-2004 (LB7) 13 10-21-2009 01:08 AM
cold start problems stacks 2003-2007 6.0L Power Stroke 16 03-25-2009 02:44 AM
cold start problems!! 1100hpfox 7.3L and 6.9 IDI (Pre 1994) 2 01-02-2008 02:13 PM
Cold start problems imported_whitelightning 1994-2003 7.3L Power Stroke 8 10-21-2006 01:19 AM
