hard starting cold 03 6.0 L - TheDieselGarage.com
Thread Details Posted by cdooguy, this thread has received 5 replies and been viewed 4744 times.
Old 10-24-2010, 06:18 PM   #1
cdooguy
jet ski racer
Hi Guys,
My truck has been having some hard starting issues when cold over the last little bit. it cranks over and seams like it is going to start then dies off. When it does finely start it puffs a little black smoke then turns white for 30 seconds or so then clears up mostly. There is a oil leak from the back of the motor (looks like rear main) which I think is the ICP.
I took it to a shop, not a dealership and they said they had no problems starting however they say the turbo is shot? Their test on the turbo is to load it up when hot and see how bad it smokes. They said that it smoked heavy at about 2200 RPM. I realy feel that it does not need a turbo, if there is an issue with the turbo I would say it is the variable vains sticking.
The truck has 250,000 Km on the truck and has been a basket case since I bought it use @ 30,000 km. last issue I had repaired by Ford under warranty @ 150,000 km was the head gaskets.
Any thoughts on what is wrong? Im thinking ICP or glow pulg related. I want to plug the truck in and see it that helps. The truck starts good when it is warm.
03 F350 Centennial
Mods: BFG 285/75/16 AT KO,Removed factory running boards,All windows tinted,Zoodad mod,Harpooned, Cobalts gauges:0-60 boost, Trany,
EGT
Pull
05 37 KZ Sportsman Sportster
World Champs 04 Kawasaki SXR 800 ltd ski. :evil:
get into "thedieselgarage.com"
Can you keep up?
cdooguy is offline   Reply With Quote
Old 10-24-2010, 07:40 PM   #2
cdooguy
jet ski racer
OK I went out and started my truck just now and it smoked white for more then 30 seconds it was more like 5 min. almost till it started getting some warmth to it.
03 F350 Centennial
EGT
Pull
Can you keep up?
Old 10-24-2010, 07:55 PM   #3
jdydiesel
Dually Club #3
jdydiesel's Avatar
What does the exhaust smell like when it is smoking white. If it smell moist like coolant then you might have a bad EGR or HGs. If it smells like diesel then you might have some bad injectors. Also I would agree on the turbo vaines are stuck. A good cleaning could fix that.
Jason
02 Excursion 4x4 Limited 7.3l. Banks Stinger Plus system
06 F-350 4x4 CC LB Tow Boss Lariat 6.0l auto. Banks PowerPDA, Banks SpeedBrake, FICM Atlas 40 Tune, ARP Studs, PowerMax GT3788VA turbo, Homemade coolant filter, EGR valve delete spool, Monster Exhaust, K&N Cold air intake, Husky mudflaps, Line-X bed liner, Recon lights, TUNED BY DFUSER.
72 F-250 Gasser.Looking for an 05-07 6.0l, 5R100 and Dana 80 to install
jdydiesel is offline   Reply With Quote
Old 10-24-2010, 10:08 PM   #4
06F450
Dually Club Member #96
06F450's Avatar
Just got my truck back from more warranty work, i took it in for hard starting. my truck needed dummy plug seals, when the oil pressure is low, the fuel injectors wont work right. your engine might have an internal oil leak.
2006 F450
SCT X3 Tuner (with EGR Off), A.R.P. Studs, AiRaid Drop In Filter, AutoMeter Pyro, Zoodad Mod, CCV Reroute, Hollowed & Piped Kitty, 4" Kitty Back Blown Coal in Front Of Rear Wheel, F550 Brakes, Splicer Rear End W/ 4:30 Gears, High Idle Mod, 12'x8' Harbor Contractor Combo Bed, More To Come After Economy Picks up. 13k All Day... Everyday
WARRANTY WORK :
(2) Altenators, (2) Batteries, (6) Sensors, (1) Turbo, (1) Full Engine Harness, (1) E.G.R. Cooler, (3) E.G.R. Valves, (1) I.C.P. Sensor... Hopefully thats it??? UPDATE10,2010; All Dummy Plug Seals, 2 fuel injectors, ECM, Both Silicon Boost Hoses, Clean Turbo... im sure theres more to come
7-2011 E.G.R. Cooler, Oil Cooler, Gaskets, Clamp, Filters, Fluid, Other BS... $1000 Work Done In Garage.
11-2-2011 Head Gaskets, degas bottle with cap, ring for turbo, egr cooler, temp sending sensor, radiator, thermostat, ficm, glowplug module, fluids, filters, and other gaskets... Material, tax, labor at dealer... $5900
A.R.P. studs... $466
11-15-11; Egr valve, and crank position sensor
06F450 is offline   Reply With Quote
Old 10-25-2010, 11:46 PM   #5
cdooguy
jet ski racer
So I plug my truck in last night to see how it would start and it started great this morning. Glowplugs or glowplug relay, do you think that is the problem?
03 F350 Centennial
EGT
Pull
Can you keep up?
Old 10-26-2010, 01:42 AM   #6
06F450
06F450's Avatar
Ya glow plugs and thier module could make a differance when its cold. And vyou would think the cel would come on, but all the warranty work ive have done, ive yet to see the cel on my truck(other than start up).
2006 F450
WARRANTY WORK :
Tags
6.0 l, cold, hard start, turbo, white smoke
No Starting and hard starting carchris 2003-2007 6.0L Power Stroke 3 04-11-2010 01:09 AM
DT466 hard cold starting idea TurboRedneck Medium Duty 3 01-12-2010 02:52 AM
Hard starting when cold. DirtyMJ 5.9L Cummins 12 Valve (1994-1998.5) 11 04-01-2008 05:33 PM
Hard to start when cold...blue smoke after starting... Stinger23 1994-2003 7.3L Power Stroke 11 03-29-2008 04:26 PM
hard starting and not starting fender 5.9L Cummins (2003-2007.5) 2 01-07-2006 07:27 AM
