Best Glow plugs? - TheDieselGarage.com
Thread Details Posted by RLU_tech, this thread has received 7 replies and been viewed 9337 times.
Old 10-26-2010, 01:36 AM   #1
RLU_tech
Best Glow plugs?
Who makes the best glow plugs and glow plug wiring harness for a '97? How much does it roughly cost to do this project?
1997 F-250 Super cab/Short bed 4x4 XLT
7.3L PowerStroke Diesel/ZF-5 Standard Trans.
DiamondEye 4" turboback exhaust/6" tip (no muff or cat)
RLU_tech is offline   Reply With Quote
Old 10-26-2010, 01:59 AM   #2
F350-6
F350-6's Avatar
Stick with the Ford or International glow plugs stamped BERU. Autolite's tend to swell up in the head.
Do you know the glow plug harness is bad? What about the pass thru connectors on the valve cover gaskets? GPR working? Don't forget to check that too.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 380,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350-6 is offline   Reply With Quote
Old 10-26-2010, 02:19 AM   #3
RLU_tech
Don't know for sure that the harnesses are bad. Are the pass thru connectors part of the valve cover gaskets?
Old 10-26-2010, 02:29 AM   #4
jdydiesel
Dually Club #3
jdydiesel's Avatar
Yes the pass through connector is part of the gasket. Give Dfuser a call for all the parts. You can find his number in the vendor tab at the top. He sells the good plugs and harness.
Jason
02 Excursion 4x4 Limited 7.3l. Banks Stinger Plus system
06 F-350 4x4 CC LB Tow Boss Lariat 6.0l auto. Banks PowerPDA, Banks SpeedBrake, FICM Atlas 40 Tune, ARP Studs, PowerMax GT3788VA turbo, Homemade coolant filter, EGR valve delete spool, Monster Exhaust, K&N Cold air intake, Husky mudflaps, Line-X bed liner, Recon lights, TUNED BY DFUSER.
72 F-250 Gasser.Looking for an 05-07 6.0l, 5R100 and Dana 80 to install
jdydiesel is offline   Reply With Quote
Old 10-27-2010, 11:58 PM   #5
RLU_tech
So no aftermarket glow plug is decent?
Old 10-28-2010, 02:48 AM   #6
F350-6
F350-6's Avatar
Depends on how you feel about pulling a head to remove them. The Motorcraft aren't any more expensive, and you can get them at the local parts store, so why are you so worried?
Chris
Old 10-28-2010, 03:39 AM   #7
jdydiesel
Dually Club #3
jdydiesel's Avatar
In one very short word.....NO
Jason
Old 10-29-2010, 11:59 AM   #8
just visiting
go with the OEM part on GPs !!!!!!!!!!!!!! dunno where your located but if your in ohio, Ky or Indiana, go to your local KOI auto parts, $11 each, thats as cheap as you will find and thats for OEM motorcraft. everywhere else your looking at 20-30 ea
2007 Dodge Ram 2500 lonestar 5.9 CRD, 6-Speed
full MBRP 5" turboback, S&B intake, FASS, ISSPRO gages, BD Diesel steering stabilizer, Tough country leveling kit, Air lift Rear leveling, Southbend clutch, XD Hoss 18" wheels, Nitto Trail grapplers, Satellite radio, LED tailights
1997 ford f-250 POWERSTROKIN auto ex cab LB, homemade intake, superchips programmer, trans, egt, boost gages, tripple a pillar pod (daily driver)
2005 dodge SRT-4 2.4turbo ED hard pipes, aem short ram, MPx 3" turboback, HKS SSQ BOV, AEM wideband, Motegi Mr7 18"rims custom painted (weekend racer) 13.89@ 107
2001 suzuki GSX-R600 K&N, Two bros. exhaust, neons, polished frame, (sumertime DD, and track toy)
11.000 @ 127
2006 raptor 700R blue dirt toy
2006 raptor 700R white dirt toy
just visiting is offline   Reply With Quote
glow plugs blackcloudCTD95 Duramax 2004.5-2005(LLY) 1 02-12-2010 10:52 PM
Where are the Glow Plugs??? stevenryals 1994-2003 7.3L Power Stroke 31 12-21-2007 11:16 PM
Glow Plugs or Glow Plug Relay BillsFan 1994-2003 7.3L Power Stroke 6 12-19-2007 12:51 AM
glow plugs smoker420 7.3L and 6.9 IDI (Pre 1994) 1 12-02-2007 05:09 PM
Q's about glow plugs imported_99powerstroke 1994-2003 7.3L Power Stroke 3 05-13-2006 03:15 AM
