Cummins L10 wont start. - TheDieselGarage.com
Thread Details Posted by redline3, this thread has received 7 replies and been viewed 5822 times.
Old 10-28-2010, 12:36 AM   #1
redline3
I have a 93' KW with an L10. I parked the truck on a Friday and put the batteries on charge. Monday morning I tried to start it and it wouldn't try to start at all just crank. I have checked all the fuel lines, good pressure goin into the head but it does drain the filter half empty when trying to start. I am leaning towards the ECM being the cause. Any help would be appreciated.
redline3 is offline   Reply With Quote
Old 10-28-2010, 12:53 AM   #2
gunnutbmg
have you checked your fuel shutoff solenoid
had a similar problem with one at work it ended up the solenoid went out
not sure on yours but ours has a manual valve next to the solenoid on top rear of the pump if you screw it in all the way it bypasses the valve and you can start it but you cant shut it down without screwing it back out
gunnutbmg is offline   Reply With Quote
Old 10-28-2010, 12:56 AM   #3
Tosch88
I had an l10 that did the same thing and it was the fuel shutoff solenoid. What he said.
1999 Fl-70 Hot Shot, ISC Cummins, 7 Speed Spicer
1999 Fl-Classic DD60 Series, 10 speed
Tosch88 is offline   Reply With Quote
Old 10-28-2010, 01:16 AM   #4
redline3
It doesn't have a manual bypass. I have lost power to the electrical wire that activates the selenoid, but hot wired it to the battery. Still nothing. Would you get fuel going into the head if the selenoid was closed?
Old 10-28-2010, 01:24 AM   #5
ynot
The other guy
No, and if it's electronic (has an ECM) and you lost the 12V to the solenoid you also have an ECM problem. Check codes if you can, and check power to the ECM
ynot is offline   Reply With Quote
Old 10-28-2010, 03:40 AM   #6
379Longhood
379Longhood's Avatar
I have never seen a pt pump without a manual screw
Click image for larger version
Name:	cummiuns pt drawing.jpg
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline   Reply With Quote
Old 10-28-2010, 03:56 AM   #7
ynot
The other guy
It's electronic (he says), so it just has a big transfer pump but the solenoid is the same. Still has the screw in the front.
Old 10-29-2010, 05:37 AM   #8
Johnp3
When you put the batteries on charge it was a regulated charger?
If you over voltage the ECM you can kill it. Check the power wires to the ECM. and the ground fuse if equipped on the ECM mounting.
1988 ford van fresh overhaul, 1991 nissan pick-up 1993 Caprice 2000 GMC S10 Blaser 2007 nbs 3500 GMC 4x4 crew-cab long box 17 inch single wheels Duramax Alison. BW turnover Ball. Furakawa FL35 loader. Retired, HD mechanic, worked on engines all my life. Fabricator welder. electrician. in the process of finishing my new shop. Live in Rock Creek B.C. Wife has a fruit stand.
Johnp3 is offline   Reply With Quote
wont start southtexasidi 1994-2003 7.3L Power Stroke 4 08-08-2009 04:01 PM
125 wont start sexytrkr ATV, UTV, Dirtbike Forum 5 04-03-2009 03:18 PM
Wont start??? ccoxva 5.9L Cummins (Pre 1994) 1 02-25-2008 02:45 PM
97 F-250 wont start Strokin05 1994-2003 7.3L Power Stroke 18 10-11-2006 09:02 PM
