Diesel Filter - Water Trap - TheDieselGarage.com
Go Back   TheDieselGarage.com > Other Vehicles And Accessories > General Parts and Accessories
Thread Details Posted by Edmon, this thread has received 8 replies and been viewed 2952 times.
Old 11-02-2010, 01:18 PM   #1
Edmon
I am searching for a diesel filter with a water trap. But the water must self drain. The usage is for trucks and earthmoving equipment in Africa where there are no mechanics available. The fuel is also high in sulphur and easily contaminated. My aim is prevention of pump and injector damage.
Edmon is offline   Reply With Quote
Old 11-02-2010, 01:29 PM   #2
bushpilot
bushpilot's Avatar
you need to be more specific, what make model & year do you need this filter for ?
Ive never seen an automatic drain, fuel / water separating filter...when draining
these filters you need to be able to catch the drained fluid.
some filters have a built in drain (to drain off the water), if your fuel is DIRTY
youll need to change the filters more often.
Don R.
'04 350 4WD Lariat Crew Longbed (built 05.04)
Gear Vendors Dbl Overdrive Install w/ Pics.
135 Amp Alternator Upgrade/Replacement
50 Gal. Aux Tank; Pump, Filter, Wiring
Truck Audio,
CUSTOM Valentine One Install - LINK
$10 Grill Mod. (protects the coolers) !
Block Heater Cord (Rear Mounted w/ Timer) - LINK
REALTIME -CURRENT DIESEL Pricing <HERE>
bushpilot is offline   Reply With Quote
Old 11-02-2010, 01:39 PM   #3
Edmon
The filter is for universal heavy duty applications. The problem in Africa is once the truck sets off there will be no service until it returns. The truck can end up crossing 3 or 4 borders into other countries. If the fuel system breaks down that is where it stands for several days before a mechanic can attend to it. So I am looking for a solution where the truck can travel 5000 miles in harsh conditions and self drain any water that accumulates in the water trap. Another container or device can be used to capture the water and diesel mix as it drains. The drivers have no ability to drain water traps manually despite training.
Old 11-02-2010, 01:49 PM   #4
fordt
Administrator
fordt's Avatar
Images: 5
I have never seen a fuel/water seperator that self drains.
-Wayne
2007 Chevy LBZ 6.6L Classic
Age is a hell of a price to pay for maturity.
fordt is offline   Reply With Quote
Old 11-02-2010, 01:54 PM   #5
Edmon
I was at Scania Trucks and they had run a test on a self draining filter. It worked but had to hang lower then the tank. It was not practical in this market so never implemented. The problem is the guy who invented it cant be traced as that was a couple of years ago.
I am thinking of developing a secondary device with a water sensor that pumps fresh diesel into the water trap and displaces the water causing it to drain out. This would work better when the vehicle is stationery prior to start up or after shut down.
Old 12-28-2010, 09:14 PM   #6
boobin
The only fuel/water separator that even comes close is the Dahl ( Baldwin ). It is advertised to capture 100% water from the fuel. You can view it in the clear sump bowl or have a water sensor light up to tell you. To drain is just a valve at the bottom of the bowl. The filters come in different micron ratings too....2...10...30.
2004 6.0L F350 Lariat Auto 4x4 CC/LB/DRW - sold
Sumimoto 255/70/22.5 on American Force Classic 22.5 wheels, 4.88 w/Truetrac rear, Mag-Hytec front/rear covers, Mag-Hytec 5R110W trans pan and '08 improved filter, custom front/rear springs from National Spring, Bilstein shocks, Bilstein dual stabilizer shocks, 4" stainless turbo back to a FTE single 6" stack, ARB Snorkel intake, Dfuser coolant filter kit, CFM++ Large Mouth, Doug's custom intake manifold, Powermax turbo w/batmowheel, Warren 175/75 injectors, ARP studded, custom CCV reroute, fan shroud removed, Diehard Platinum PM-1 batteries relocated, permanently installed battery tender with front/rear plug in access, HD250 amp alternator w/remote rectifiers, (9) ISSPRO Performax gauges, Nathan K5s, Warn hidden winch bumper kit, Warn 16.5k winch, Reflexxion steel hood, Jimmijammers, Britebox, Retro Solutions, ATTA 50gal Bed tank/tool box combo, Titan 67gal main tank..Hellman sumped, custom regulated return w/Fuelab pump, 6.4 oil filter canister, AMP steps, F650 lower dash w/nine switch panel , Carling switches, SCT X2 and stuff
boobin is offline   Reply With Quote
Old 12-28-2010, 09:33 PM   #7
big_rooster
TDG Single Club Member#14
big_rooster's Avatar
Send a message via MSN to big_rooster
The baldwin ones with the clear bottom are the best that i've used. Never heard of an automatic draining filter.
2003 F-250 6.0 liter crew cab lariat 4x4 short bed, S&B intake, MBRP 4" turbo back straight piped jones, SCT livewire, : 2 jl audio 12W3V3's with jl audio 500/1, autometer sport comp gauges, 6.5 inch pro comp lift, 37x13.5 Super Swamper M16's
http://s192.photobucket.com/albums/z319/big_rooster69/
big_rooster is offline   Reply With Quote
Old 12-29-2010, 02:06 AM   #8
Johnp3
Davco has a site with a video that shows how the system works I believe they make the filter housings for Fleetguard, Dahl, everybody that use the system with the bowel on the top. It is the very best system by far. If you Google Davco 233 it will give you the video, and all the selections.
1988 ford van fresh overhaul, 1991 nissan pick-up 1993 Caprice 2000 GMC S10 Blaser 2007 nbs 3500 GMC 4x4 crew-cab long box 17 inch single wheels Duramax Alison. BW turnover Ball. Furakawa FL35 loader. Retired, HD mechanic, worked on engines all my life. Fabricator welder. electrician. in the process of finishing my new shop. Live in Rock Creek B.C. Wife has a fruit stand.
Johnp3 is offline   Reply With Quote
Old 12-30-2010, 06:38 AM   #9
Edmon
I have discovered that automatic drains filters did exist but the water and diesel mix was dumped onto the road causing pollution. Therefore further development by filter manufactures was stopped. I have seen the Dahl filter from Baldwins and guess it may be the best option.
Tags
diesel, filter, water in fuel, water trap
Speed trap Spike 64 The Parking Lot 10 09-19-2009 01:07 PM
what should my 1/4 mile time be with trap of 96.57 EJ Krueger 2003-2007 6.0 Tuner Forum 23 07-23-2009 11:22 AM
Water in Air Filter 08wstroke 2008-2010 6.4L Power Stroke 6 05-09-2009 07:57 PM
heres why you want a pre-filter/water separator imported_diesel71 2003-2007 6.0L Power Stroke 43 01-02-2008 10:04 PM
fuel/water filter robertjohnson44 Introductions 5 04-25-2007 03:42 AM
