Cummins Diagnostics Tools/Scanners? - TheDieselGarage.com
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins (2003-2007.5)
Thread Details Posted by jat99, this thread has received 4 replies and been viewed 7396 times.
Old 11-06-2010, 11:17 PM   #1
jat99
Hello, got a question for you Cummins/Dodge guys. What is used on the Dodge/Cummins for diagnostic purposes? Ford uses the NGS and IDS scan tools and such and curious what is used on the Cummins at the dealers?
Also, I assume some of the aftermmarket scan tools will work also like Snap On and such?
Main goal would be datalogging capabilities. The Ford NGS and IDS will datalog certain parameters like ICP, IPR Duty cycle, Injection pulsewidth, injector balance test, cylinder contribution tests and on and on and on.
What is available to do this with the Cummins?
Thanks in advance guys!
99.5 F250 SD Lariat SuperCab PSD LB 4x4
Hybrids, Bean's Modified H2E, DP-Tuner
Precision TC with pump mods
DI Fuel System, ITP Regulated return
Full Engine rebuild- cryoed, ceramic coated, shot peened, blah, blah, blah
Webshots
483.1hp, 975.0tq #2 Dyno sheet
Dunbar's Dyno 1.04 CF
jat99 is offline   Reply With Quote
Old 11-07-2010, 01:05 AM   #2
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
The OBDII tool that dodge uses in called the StarScan.
StarScan
"Only accurate rifles are interesting" -Townsend Whelen
2012 Ram 2500 Crew Cab Big Horn
6.7L 68RFE 4wd
Yeah its stock.
Edge Insight CTS / Line-X / Access Bed Cover
B&W Turnover Ball / Companion Hitch
Pac Brake Air Bags
On Board Air
2010 John Deere 2305
2010 Jeep Wrangler JK Unlimited Rubicon/ Tuned with some toys.
2015 Keystone Impact 311 Toyhauler
9-11-2001 NEVER FORGET
neeltburn is offline   Reply With Quote
Old 11-07-2010, 02:32 AM   #3
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
StarScan
I should have added I have AutoEnginuity and am very happy with it!
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Old 11-12-2010, 02:24 AM   #4
jat99
Thank you for the info.
Webshots
Old 11-19-2010, 04:45 PM   #5
LilFroger
Cummins also directly sells the Quick Check systems via their site. For owners it's a bit much ... but for a shop purpose it's handy
http://www.bdasites.com/Cummins/Store/Browse/CUMNELE
'06 3500 CTD
Big Horn Edition
Jake Brake
S & B Intake
5" straight pipe
LilFroger is offline   Reply With Quote
Code scanners Big Stroker PSD 1994-2003 7.3L Power Stroke 2 02-28-2010 07:13 PM
Code Reader/Scanners dtb5599 2003-2007 6.0L Power Stroke 6 12-02-2009 04:35 PM
Police Scanners fordt General Parts and Accessories 11 05-11-2007 03:12 PM
Radar Detectors or Scanners? Hybrid_4x4_Superduty The Parking Lot 22 02-02-2006 12:21 PM
