Loss of boost if EGR valve is unplugged - TheDieselGarage.com
Thread Details Posted by maladosteo35, this thread has received 22 replies and been viewed 12409 times.
Old 11-14-2010, 03:12 AM   #1
maladosteo35
maladosteo35's Avatar
Images: 2
I have done a lot of reading on different threads about unplugging the EGR valve as a short/ cheap fix to help prevent problems with recirculating exhaust gases back to the intake. In my '05, i didn't have any CEL show, but I did notice that i was not able to get more than 20lbs of boost from the turbo. I plugged in back in after noticing it, and the next time i stood on it i got over 30lbs. anyone know why? thanks..
2005 F-250 Lariat CC FX4 4WD, Atlas 40 FICM, 200 amp Alt, 5th Wheel hitch, 5 inch Turbo back Cat/ Muffler delete, IPR EGR Delete, IPR Up=pipe, '08 banjo bolt mod, Blue Spring mod, AMSOIL oil bypass filter, Dieselsite Coolant bypass filter, Zoodad mod, High idle mod, CCV mod, Rotella T6 5w-40, Recon Blacked out third brake light/ side mirror turn signals, 7in Screen Double Din AM/FM/CD/DVD/ iPod ctrl/ NTSC TV eBay special, Rear 56" 5 way light bar
maladosteo35 is offline   Reply With Quote
Old 11-14-2010, 04:48 AM   #2
lilpooh
lilpooh's Avatar
With certain stradegies and year trucks, unplugging the EGR valve can set the truck into a limp mode. From my understanding, this is a fairly new find. Othe symptoms that may occur is, the VGT not cycling when at idel, and the clutch fan not reaching full RPM.
As far as what year trucks and stradegies are effected, nobody knows. You noticed less boost, myself and another member noticed that the VGT was not cycling. Without putting the truck on a diagnostic scanner, you wouldn't be able to tell if the clutch fan is reaching full RPM. Now I wonder how may guys have there EGR valve unplugged, and don't realize that there clutch fan is not working properly?!?!?!?
2004 F350 CC DRW King Ranch
X-3 tunes by DJ,QT,GH,ID,Gyphon FICM tuner,head studs,II Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,Snow Perf stage II,EGR delete,AD2,4" turbo back straight pipe,K&N intake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Thanks to:JASONS REPAIR AND PERFORMANCE-TELFORD,PA.
"Are diesel pickups hot rods? Yes,they are-perhaps the most versatile hot rods ever made"---Diesel Power Magazine
lilpooh is offline   Reply With Quote
The Following User Says Thank You to lilpooh For this addition to TDG:
maladosteo35 (11-14-2010)
Old 11-14-2010, 04:53 AM   #3
lilpooh
lilpooh's Avatar
Just to clear things up, did you unplug the valve when the truck was off?
Old 11-14-2010, 05:37 AM   #4
smokersteve
It does not matter when you unplug it. The EGR valve is spring load closed and needs a current to keep it open.
If you not not have any issues, you WILL see lower psi from the system because the system is more efficient with its operations.
06 F350 79,000
smokersteve is offline   Reply With Quote
The Following User Says Thank You to smokersteve For this addition to TDG:
Old 11-14-2010, 06:12 AM   #5
Trip
Trip's Avatar
I have my EGR taken out but still plugged in ( got a spool in the opening for the valve) you will have a lower boost pressure, as some have said it can be because it runs more efficiently, some say because your not adding used, burned, usless air back into your cyl it A) dosent need to push as much air (i would think it would still spool up to 30 then back back down to where it would be most efficent B) others say its because your not adding boosted air flow back into the system from exhaust it wont build as much...
At any rate of repeating, I have been running mine plugged at manifold and connected at harness and laying on top of motor for nearly a year with no ill side affect due to it, still runs great! but holds soft codes in computer.
Even with your egr unplugged it can still leak exhaust gas past the valve from what I have read.
03 F-250 Lariat 4X4 6.0L- NEW ID PROGRAMED FICM 105,000 (sitting on shelf while I figure out whats going on with the turd...furd) wheel berring 103,000 Dfuser coolant filter104,000, EGR plug104,000mi, y-pipe109,800mi,bootlegged 3.5" straight pipe110,000, rotors and pads on all 4 points 110,400mi, 35X12.50R17 Toyo M/T@ 111,300 ICP sensor 115,000
taken over at 103,000mi June-2009
WALNUT (anti-ACORN) member#23
Trip is offline   Reply With Quote
Old 11-14-2010, 02:01 PM   #6
maladosteo35
Images: 2
I did unplug the EGR with the truck off. I plugged it back in after noticing the boost was limited to 20lbs. I'm not a diesel tech, but it seems that the computer is limiting the boost somehow. For now, i'm leaving it plugged in. I have a bypass coolant filter and a bypass oil filter installed to help prevent the problems with the EGR cooler itself. I have seen EGR delete/ bypass kits for sale from $150-400. are they worth it? thanks
Old 11-14-2010, 02:02 PM   #7
John_G
Super Moderator
John_G's Avatar
Let's remember that boost is a measure of "back pressure", how hard the turbo is pushing air into the engine but NOT a measure of how much clean air is entering the engine!
If the turbo is moving 60#/min of clean air, and the EGR is adding 10# of EGR to the intake, where "boost" is measured, what do you think will happen when you remove that 10#/min of EGR but don't alter anything else? Measured boost will go down but clean airflow did not change.
If you want to know if you are getting more air into your engine, look NOT at boost but at the MAF signal in # of Intake air/minute!
I vote for LIBERTY!
The Following User Says Thank You to John_G For this addition to TDG:
Old 11-14-2010, 02:07 PM   #8
maladosteo35
Images: 2
John G, how do you measure the MAF? ok, more important, what is MAF?
Old 11-14-2010, 03:21 PM   #9
05PSD
05PSD's Avatar
This is what happened on my 05 (no MAF). As John said, boost is a function of backpressure, my truck felt twice as strong at 20lbs as it did at 27lbs. What I did was bolt the valve to the alternator bracket and left it plugged in. No soft codes and boost is normal. My truck doesn't have a MAF so I'm not sure how "MAFFED" truck would react.
05 F350 CC SB Lariat, Silverline exhaust, SCT tuned by Spartan,Inaccurate QZ Commander, deleted EGR, coolant filter, blown headgaskets
05PSD is offline   Reply With Quote
The Following User Says Thank You to 05PSD For this addition to TDG:
Old 11-14-2010, 03:45 PM   #10
maladosteo35
Images: 2
It does feel "stronger" at 20 lbs with the EGR unplugged, but i have no way of quantifying that feeling. I assumed that 27-30 is better than 20....
it may seem strange, but i also notice the transmission shifts differently, tends to wind out more with the EGR plugged in...
rattle and loss of boost ewales 1994-2003 7.3L Power Stroke 2 07-18-2009 01:00 PM
Loss of boost and rattle ewales 1994-2003 7.3L Power Stroke 1 07-12-2009 12:40 PM
boost loss TSGS69400 1994-2003 7.3L Power Stroke 10 05-26-2009 02:14 AM
loss of boost stroke250 1994-2003 7.3L Power Stroke 6 05-10-2006 07:37 PM
Loss of boost! I need help! Rockaholic 2003-2007 6.0L Power Stroke 1 03-17-2006 03:13 AM
