low oil pressure at idle after warmed up - TheDieselGarage.com
Go Back   TheDieselGarage.com > GM Diesel & Truck Discussion > Duramax 2001-2004 (LB7)
Thread Details Posted by strokethis03, this thread has received 10 replies and been viewed 16196 times.
Old 11-16-2010, 12:55 AM   #1
strokethis03
Hi i have a lb7 and the oil pressure seems low after it has been warmed up. when you start it up cold it goes to 65 pounds and seems fine. and slowly goes down as the truck warms up. just wonderin if anyone has had this problem. before. thanks. truck has 108000 miles on it.
strokethis03 is offline   Reply With Quote
Old 11-16-2010, 12:59 AM   #2
merlin5577
Gone Fishin...
merlin5577's Avatar
Send a message via AIM to merlin5577 Send a message via Yahoo to merlin5577
What are you seeing as 'low' oil pressure?
As the engine warms up the oil pressure should go down as the oil thins out when it warms.
-Robert.
My Fleet;
2011 Volkswagen Jetta TDI 2.0L 6A
2010 Chevrolet Malibu LT 2.4L 6A
2003 Chevrolet Silverado LS 6.6L 5A
1997 GMC Suburban SLT 5.7L 4A
If you dont stand behind our troops, feel free to stand in front of them.
Thinking of buying a Duramax? You need to click this link;
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline   Reply With Quote
Old 11-16-2010, 01:53 AM   #3
BriteWhiteRam
CRAZY CANUCK
BriteWhiteRam's Avatar
Mine runs below half once its warmed up, runs above half when cold, never really thought anything of it
Aaron the Crazy Canuck
2006 Chevrolet Silverado LT 2500: LBZ - Allison, Greystone Metallic, 4x4,PPE airbox mod, missing muffler/cat, EFILive tuned by Nick at duramaxtuner, MA tie-rod sleeves and Grade C headgaskets
Totalled!! May 2nd 2008-2005 Dodge Ram 3500 laramie: Cummins auto, plain white, rebuilt tranny
1986 Mercury Capri - 5.0L, AOD, shorty headers, acell ignition, Holly street dominator intake, Holly 625 vacuum secondaries carb, Dual glass packs "my little yellow terror"
DURAMAX INDEX; You want a Duramax? you want to click on this >>The Duramax Index
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
Check out the NEW and IMPROVED TDG Truck Poll!
TDG TOTQ
BriteWhiteRam is offline   Reply With Quote
Old 11-16-2010, 03:02 AM   #4
New 0mega
Pardue the Traveler
New 0mega's Avatar
Send a message via Yahoo to New 0mega
I wouldn't worry about it unless it's throwing a code or spewing oil
Smoke!!! Smoke!!!! Are you Smoking yet?
2007.5 Sierra 2500HD SLE 6.6L Duramax Extended Cab Long Box Z71 Fass 150/95, Rare Parts G2 hd tie rods, EFi Live, DSP5 a tune from Duramaxtuner.com, MBRP 4" Downpipe back, Edge CTS Insight, Cognito Idler/Pitman Arm Braces, PPE Deep Transmission pan, deep pan filter, Transgo Jr kit
Canadian Club member #2 http://www.thedieselgarage.com/forum...light=Canadian
Singles Club member #250
http://thedieselgarage.com/forums/image.php?type=sigpic&userid=23125&dateline=124580  0528
For those whom are looking at a Duramax check this thread out.http://www.thedieselgarage.com/forum...ad.php?t=92868
New 0mega is offline   Reply With Quote
Old 11-16-2010, 04:02 AM   #5
strokethis03
found the problem.
figured it out after further investigation found it to be overfull on oil. Turns out i have a cracked injector leaking fuel into oil causing oil to thin out when warm. the pressure was so low it would flash the low oil pressure on the dic. thanks for all the help. it greatly appreciated.
Old 11-16-2010, 04:20 AM   #6
merlin5577
Gone Fishin...
merlin5577's Avatar
Good luck bud. Glad you found your problem.
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
Old 11-16-2010, 05:21 AM   #7
BriteWhiteRam
CRAZY CANUCK
thats chitty, Im sorry we didnt help you pinpoint it, guess we should have suggested checking oil level, but it just seems normal to me to have lower pressure
Thats the one problem with the LB7, bad injectors and they hid them under the valve covers
Ridin Dirty Club #5
TDG TOTQ
Old 11-17-2010, 04:31 AM   #8
M123KT-450
M123KT-450's Avatar
Send a message via AIM to M123KT-450 Send a message via Yahoo to M123KT-450
The D-Max run's low oil pressure ? . . . Normally ?
My 6.5 idled at in gear at 38psi and ran down the road at 58-62psi, which to me seemed low for diesel but about right for a Gasser
My gasser's idle hot at 45ish psi and run about 60ish psi driving hot
The 2 Gen-1 D-Max i test drove ran 50ish idling and 70ish driving . . . which is about what i am used to for a diesel
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline   Reply With Quote
Old 11-18-2010, 02:48 AM   #9
merlin5577
Gone Fishin...
merlin5577's Avatar
My truck (126K miles) will run 30-40psi HOT, 80-90psi COLD, and 60ish psi on the highway. Has since the day I bought it.
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
Old 11-18-2010, 04:48 PM   #10
BriteWhiteRam
CRAZY CANUCK
My gauge is in kpa, but it usually is exactly like roberts, and I run 5w40syn
Ridin Dirty Club #5
TDG TOTQ
No oil pressure at idle? Tray27 1994-2003 7.3L Power Stroke 17 11-11-2010 05:24 AM
low oil pressure when warmed up blizzardplower 2003-2007 6.0L Power Stroke 14 02-07-2009 03:05 PM
Rough Idle When Warmed UP huckleberry97 1994-2003 7.3L Power Stroke 12 03-14-2008 06:27 AM
Is this normal oil pressure at idle? dropped_dually Duramax 2004.5-2005(LLY) 6 12-19-2007 07:42 PM
how much oil pressure at idle when warm? SICKS-O 1994-2003 7.3L Power Stroke 3 06-14-2007 05:15 AM
