LB7 Injector Sleeves - TheDieselGarage.com
Go Back   TheDieselGarage.com > GM Diesel & Truck Discussion > Duramax 2001-2004 (LB7)
Thread Details Posted by Vintage, this thread has received 15 replies and been viewed 3982 times.
Old 11-19-2010, 08:44 PM   #1
Vintage
I'm playing Diesel Mechanic and I just removed the 4 injectors on the passenger side because I was told that I have coolant leaking into my #7 cylinder (hopefully not a head gasket leak). So I pulled #7 injector to reseal the sleeve and then decided to pull the other 3 injectors to see how they looked. Does pulling the injectors compromise the seal under the sleeve? Should I pull all the sleeves and reseal? Truck was running fine except for white smoke. 122K miles, out of 7 yr warranty, injectors changed twice. Should I take injectors in to be cleaned and bench tested?
Tom
2004 LB7 3500, Edge, Volant, 4" Exhaust
Tow 40' Toybox
Vintage is offline   Reply With Quote
Old 11-20-2010, 03:27 AM   #2
BriteWhiteRam
CRAZY CANUCK
BriteWhiteRam's Avatar
Truck shouldn't be out of warranty yet, should have a year left and its to 200k miles
Aaron the Crazy Canuck
2006 Chevrolet Silverado LT 2500: LBZ - Allison, Greystone Metallic, 4x4,PPE airbox mod, missing muffler/cat, EFILive tuned by Nick at duramaxtuner, MA tie-rod sleeves and Grade C headgaskets
Totalled!! May 2nd 2008-2005 Dodge Ram 3500 laramie: Cummins auto, plain white, rebuilt tranny
1986 Mercury Capri - 5.0L, AOD, shorty headers, acell ignition, Holly street dominator intake, Holly 625 vacuum secondaries carb, Dual glass packs "my little yellow terror"
DURAMAX INDEX; You want a Duramax? you want to click on this >>The Duramax Index
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
Check out the NEW and IMPROVED TDG Truck Poll!
TDG TOTQ
BriteWhiteRam is offline   Reply With Quote
Old 11-20-2010, 03:46 PM   #3
Vintage
My first call when I noticed white smoke was to my "friendly" dealer who I've been loyal to and who quickly advised me that I was 2 months past the 7yr warranty and there was nothing that he could do. So there goes any Chevy truck in my future.
Any suggestions on my sleeves or injector testing?
Thanks for the response!
Old 11-20-2010, 04:09 PM   #4
merlin5577
Gone Fishin...
merlin5577's Avatar
Send a message via AIM to merlin5577 Send a message via Yahoo to merlin5577
Originally Posted by Vintage View Post
Does pulling the injectors compromise the seal under the sleeve? Sometimes. Depends on what caused the injectors to fail.
Should I pull all the sleeves and reseal? Yes. Better safe then sorry.
Truck was running fine except for white smoke. 122K miles, out of 7 yr warranty, injectors changed twice. Should I take injectors in to be cleaned and bench tested? The ones you are not replacing I would suggested having tested.
Response are underlined above.
As for your warranty. Its 7 years from the date it was put in service. I would post the vin in the vin check section and see when that was. Good luck.
-Robert.
My Fleet;
2011 Volkswagen Jetta TDI 2.0L 6A
2010 Chevrolet Malibu LT 2.4L 6A
2003 Chevrolet Silverado LS 6.6L 5A
1997 GMC Suburban SLT 5.7L 4A
If you dont stand behind our troops, feel free to stand in front of them.
Thinking of buying a Duramax? You need to click this link;
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline   Reply With Quote
Old 11-20-2010, 04:44 PM   #5
Vintage
After my "friendly" dealer stated that I was out of warranty I checked my Purchase Contract and sure enough I took delivery 7yrs and 2 months from the date that I contacted them about the problem. I'm playing mechanic because I know this will happen again and I refuse to pay retail/shop $ for GM's experiment. Any mechanical advice or direction to web instructions would be appreciated, I want to do it right. I've been rebuilding autos and motorcycles for 30 yrs, I have experience and tools, just need a little diesel direction. Thanks for responding!
Old 11-20-2010, 05:01 PM   #6
merlin5577
Gone Fishin...
merlin5577's Avatar
Vintage, I've sent you a PM.
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
Old 11-20-2010, 05:03 PM   #7
Vintage
Thanks Merlin
I appreciate the help, a few more questions if you don't mind,
1) Sleeve puller tool supplier (not factory item).
2) Latest and greatest material for sealant under sleeves?
3) Reputable supplier for "Injector Intallation Kit"? Copper washer, O-
rings, etc.
4) Websites with helpful instructions/recommendations?
Thanks All
Old 11-20-2010, 07:21 PM   #8
BriteWhiteRam
CRAZY CANUCK
I would get into contact with merchant automotive, www.merchantautomotive.com
Ridin Dirty Club #5
TDG TOTQ
Old 11-20-2010, 09:31 PM   #9
Vintage
Crazy Canuck
I found Merchant on the internet awhile ago along with a number of diesel guys recommending. Looks like a great source, I'll probably use unless I can find a shop here in Inland Empire (SOCAL) that I can walk into and talk to somebody.
Thanks for the help! Any info is appreciated, please keep it coming.
Old 11-21-2010, 02:56 AM   #10
Vintage
Merlin
Thanks for the PM, great help.
injector diagram?? looking for #2 injector possition AlexMichaud 2003-2007 6.0L Power Stroke 3 10-16-2010 09:03 PM
can u re-o ring an injector without replacing injector? bigswede Medium and Heavy Duty 1 06-15-2009 02:01 AM
Tie-rod sleeves mckey73 General GM Truck Forum 11 02-28-2007 10:50 PM
Sleeves or not bus driver 1994-2003 7.3L Power Stroke 3 02-11-2007 04:37 PM
EFILive+SD Sleeves+Free Tune = $695 Kat Supporting Vendors Forum 2 09-16-2006 11:23 PM
