SCT X3 User Adjustments - TheDieselGarage.com
Go Back   TheDieselGarage.com > Ford Diesel & Truck Discussions > 2003-2007 6.0 Tuner Forum
Thread Details Posted by adambomb, this thread has received 10 replies and been viewed 2834 times.
Old 11-28-2010, 05:45 PM   #1
adambomb
adambomb's Avatar
Question SCT X3 User Adjustments
When going through the user adjustments on my custom tunes I am wondering if the "stock value" is what the tuner set your revs per mile to be. I let the tuner know I have 35's and when I look at Revs it says 500 "stock value" and then you can adjust it from there. is that just the pre-set SCT software thing but my Rev's are really set differently through the custom tuning.
I found this by trying to see what number Innovative set my Rev Per Mile to see if I need to make any small adjustments.
Thanks
2005 6.0L F350 Lariat CCLB FX4
*Industrial Injection Hybrid Turbo*90hp DDP Injectors*SCTX3 Custom Innovative/Spartan*ARP Studs/Stocks Head Gaskets*Banks Techni-Cooler*FASS*AFE Intake*4" MBRP Exhaust*AutoMeter PhantomII Boost/Pyro/Trans Gauges*2.5" ICON Suspension*35" Xtreme AT's*18"KMC Monsters*Power Slotted Rotters w/ Ceramic Brake Pads*Pioneer AVIC N3-Nav,Rear View Cam,iPod,Voice Activation*
adambomb is offline   Reply With Quote
Old 11-28-2010, 05:48 PM   #2
adambomb
adambomb's Avatar
I was expecting to see around 580 rev per mile. That's what the calculations came out to be for my 35x12.5R18 procomp X/AT
Old 11-28-2010, 06:22 PM   #3
stroke32
Semper Fi
stroke32's Avatar
You have to set your own axle ratio and revs per mile, atleast this was the case on my sf3 when I got my custom tunes. I'm pretty sure it's no different with the x3.
black 2006 lariat F350 SB CC Dually sunroof 12" Procomp lift dual shocks/resivoirs front and rear, fabtech dirtlogic dual resivoir steering stabilizers (all nitrogen). 4in exhaust TB 22" chrome alcoa 18 wheeler rims on toyo 37" open country. 08-10 tailgate recon blacked out lights all way around. Harley front end (lights bumper grill etc) back up sensors and camera custom blacked out badges. 4 JL 10's in shallow box behind seats 2 thousand watt amps w/ custom 6x9's. 8" kenwood indash 5% tint all way around. powder coated frame and custom diff covers. SCT tuned
2005 f250 CC SB
custom all red truck grille and handles
black leather with carbon fiber face and door plates
IPCW taillights and lowered
stroke32 is offline   Reply With Quote
The Following User Says Thank You to stroke32 For this addition to TDG:
adambomb (11-28-2010)
Old 11-28-2010, 06:34 PM   #4
strokin6L
strokin6L's Avatar
whenever i download a tune i always adjust the revs and axle ratio. When adjusting those parameters it always starts at the lowest figure and you can raise it from there.
2004 F-350 XLT SC 4x4: SCT, AFE stage II, autometer gauges(pyro, boost, tranny, fuel), edge insight, CFM large mouth intake elbow, spearco, snow performance water injection, 5" stacks, ARP's, fluidampr, hypermax fire rings, LIPD regulated return, FASS, fuelab, casserly 190's, 64/71/70 turbo(polished compressor housing)modded FICM(ID), Hellmann's sump, electirc fans
strokin6L is offline   Reply With Quote
The Following User Says Thank You to strokin6L For this addition to TDG:
Old 11-28-2010, 06:50 PM   #5
adambomb
adambomb's Avatar
thanks guys. do you know if the default axle ratio is 3.73? too
Old 11-28-2010, 06:54 PM   #6
stroke32
Semper Fi
stroke32's Avatar
most f250 and f350's prior to 2008 come stock with 3.73 rears. if you going 70mph on highway and your rpms are at 2000rpm then you got 3.73
2005 f250 CC SB
Old 11-28-2010, 06:58 PM   #7
adambomb
adambomb's Avatar
yeah my truck has 3.73 LS. i was just wondering if that's the setting. but i'll check it out when i look at the SCT. thanks tho
Old 12-04-2010, 04:44 PM   #8
ebusa
ebusa's Avatar
What brand tires do you have?
580 seems way low. I have Toyo MT's and doing the rolling measurement put them at 595.
-Evan
2005 F350 Crew Cab LB FX4 Lariat
Loaded-Leather, Sunroof, Chrome Mirrors,Tow hooks
5'' Tuff Country Lift
Toyo 35'' MT's on Race Line Renegade 20's
ARP Studs, EGR Cooler Delete, Coolant Filter
AFE Magnum Force Stage II CAI
MBRP 4'' Exhaust Turbo back, No Cat
SCT X3 Tunes -Strat: VXCF9
Powemax Turbo
PHP FICM tuner
ebusa is offline   Reply With Quote
Old 01-19-2011, 02:22 AM   #9
DesertSands
DesertSands's Avatar
If anyone has this info I would like to check it out! I have an Xcal 2 there are a bunch of setting you can change. I like to run the X-street tune. from the truck in the sig what should I be setting the Xcal too.
Hope that made sense>
Thanks
des
2005 F-350, 6.0, Lariat, 4X4,CC,LB,Torqshift, 8" lift, Toyo 37" O.C. 18" Mazzi Hulk Wheels, Billet Grill, Isspro A-pillar gauges,AFE 4"TB exhaust w/no muff,4:56's, Firestone Air Bags, SCT X-cal2, ARP's
SCT tunes BY Eric. and Viv', WC Motorsports anti-wobble track bar
DesertSands is offline   Reply With Quote
Old 01-20-2011, 12:34 AM   #10
ebusa
ebusa's Avatar
Thanks
des
Your set up will prolly be around 585 or 590. The best way to know for sure is to measure.
Put a mark or piece of tape on the 6 o'clock position of your tire(side of it) and then make a mark on the ground next to it(starting point) , roll the truck forward or back one full turn so the mark is back at the 6 o'clock position again. make another mark on the ground. Now measure how far apart the 2 are in inches.. example 99" from mark to mark
There are 63360" in a mile..so 63360/99 is 640 thats how many revs per mile
Bigger the tire size (measured distance) the lower the number of RPM
-Evan
Powemax Turbo
PHP FICM tuner
The Following User Says Thank You to ebusa For this addition to TDG:
robs97z28 (01-26-2011)
TV cable adjustments 97CumminsTurboDiesel 5.9L Cummins 12 Valve (1994-1998.5) 1 08-12-2010 08:43 PM
6.5L valve adjustments? endsone 6.5L Diesel Engine 4 10-23-2009 02:30 PM
SCT User Adjustments (WOT Speed Shift & Shift Pressure) ebusa 2003-2007 6.0 Tuner Forum 1 04-29-2008 03:23 AM
Head Light Adjustments?? turbo606 5.9L Cummins (2003-2007.5) 1 01-02-2008 04:33 AM
Tailgate adjustments?? Diesel Dog The Detailing, Paint & Bodyshop 9 06-06-2006 02:54 AM
