Heater not working??? - TheDieselGarage.com
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins (1998.5-2002)
Thread Details Posted by JUMPSTER93, this thread has received 6 replies and been viewed 1725 times.
Old 12-07-2010, 01:08 AM   #1
JUMPSTER93
Just bought a 2000 Ram 3500 about 6 months ago and the heater has never worked. Anybody have any suggestions on where to start looking for a problem? Thanks
JUMPSTER93 is offline   Reply With Quote
Old 12-07-2010, 02:37 AM   #2
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
Flush the cooling system. Sounds like your heater core is done, but try flushing the cooling system and see what happens. The truck does run in the operation range for coolant temp?
"Only accurate rifles are interesting" -Townsend Whelen
2012 Ram 2500 Crew Cab Big Horn
6.7L 68RFE 4wd
Yeah its stock.
Edge Insight CTS / Line-X / Access Bed Cover
B&W Turnover Ball / Companion Hitch
Pac Brake Air Bags
On Board Air
2010 John Deere 2305
2010 Jeep Wrangler JK Unlimited Rubicon/ Tuned with some toys.
2015 Keystone Impact 311 Toyhauler
9-11-2001 NEVER FORGET
neeltburn is offline   Reply With Quote
Old 12-07-2010, 10:43 AM   #3
smokndiesel7588
Singles Club #2
smokndiesel7588's Avatar
Send a message via AIM to smokndiesel7588
You might also want to try just flushing the heater core. We did a full system flush on my buds truck once, and it improved the heating performance. Once we just disconnected the heater core hoses and flushed that only, it reached its full potential once again.
Greg
My Truck- '02 Dodge Ram 2500 QCLB...ISSPRO Gauges...110hp DDP Injectors...Smarty..TST Comp..Pro52 turbo..BHAF...4" Turbo back to single 8" mitre...converted to NV5600 with SB Street DD
Bro's Trucks- 97 Dodge Ram 2500 5spd 12V...DDP 90hp Injectors...Half-Cut DV's..0 Plate...starwheel turned..kdp & 5th gear fix...17.5deg timing...SB Feramic 13" clutch
96 Dodge Ram 2500 12V XCLB...auto...2wd...SOLD
smokndiesel7588 is offline   Reply With Quote
Old 12-16-2010, 06:49 PM   #4
KATOOM
Before you do anything, with the engine at full temp, touch both heater core hoses coming from the firewall. If the heater core is fine then they both will be hot. If only ones hot then the core is plugged. If they're both hot but you're still not getting heat then check the blend door for the heater under the dash. With the key in the ON position (truck not running), when you change the heater temp knob from warm to cool, listen down by the passenger floor and you should lightly hear the blend doors electric motor running as it swings the door one way or another.
'01 Dodge Ram 2500 4x4 5spd Sport, EZ, Straight piped, aFe intake, Rancho 9000x's, 285's, Pac Brake, 2 lo kit, Dakota FP and Isspro boost/EGT gauges on the pillar, Raptor with 1/2" big line kit.
KATOOM is offline   Reply With Quote
Old 02-04-2011, 10:54 PM   #5
paulo100
also chek your thermostad
paulo100 is offline   Reply With Quote
Old 02-24-2011, 03:16 AM   #6
JUMPSTER93
Replaced the heater core and it is working fine now. Thanks for the help.
Old 02-25-2011, 05:59 PM   #7
Johnp3
If you did not flush the cooling system multiple times so it is clean the new heater core will collect the crud in the system.
1988 ford van fresh overhaul, 1991 nissan pick-up 1993 Caprice 2000 GMC S10 Blaser 2007 nbs 3500 GMC 4x4 crew-cab long box 17 inch single wheels Duramax Alison. BW turnover Ball. Furakawa FL35 loader. Retired, HD mechanic, worked on engines all my life. Fabricator welder. electrician. in the process of finishing my new shop. Live in Rock Creek B.C. Wife has a fruit stand.
Johnp3 is offline   Reply With Quote
Radiator Leaks & heater not working trac 2008-2010 6.4L Power Stroke 1 01-13-2008 05:08 PM
block heater not working? daturbosix 2003-2007 6.0L Power Stroke 20 12-08-2007 12:31 PM
Heater Grid not working..... maninblack2k 5.9L Cummins (Pre 1994) 3 11-23-2007 04:18 PM
how to tell if the block heater is working littlebigrig6.0 2003-2007 6.0L Power Stroke 6 11-12-2007 09:00 PM
