Cummins n14 fuel check valve - TheDieselGarage.com
Thread Details Posted by BSouth, this thread has received 1 replies and been viewed 7786 times.
Old 01-01-2011, 10:25 PM   #1
BSouth
Dump Truckin SOB
BSouth's Avatar
I've been having a problem with a hard start lately on my truck. Its a 370hp n14 in a 96 Freightliner FLD. Sometimes it will fire right up but sometimes it has to crank a little bit to get started. Was wondering where the check valve was on this truck. I took the line off the front side of the ecm where it comes out of the block. There was a 90 degree fitting coming out of it but nothing inside it. Is there suppose to be one there or is it somewheres else? I just switched my filter head over from the upside down filter with the clear canister to a baldwin filter head running a 1259 baldwin filter. Any info is appreciated.
Brian
BSouth is offline   Reply With Quote
Old 01-04-2011, 12:22 AM   #2
mrdevildog
mrdevildog's Avatar
i've seen where a check valve was never installed, it should be connected to the fuel line going from fuel filter head to ecm cooling plate screwing into the ecm cooling plate,if you have a gauge you can check your fuel pressure and see if its in spec. can also check the metal screen in the top of the fuel pump for crud, its on top of the pump to the left of the metal line, will need a 9/16 wrench of big flat tip screw driver to remove the cap.
mrdevildog is offline   Reply With Quote
Need jegs part # for fuel 90 check valve fittings PiRiPi 2003-2007 6.0L Power Stroke 2 12-05-2009 11:53 PM
Fuel Line Check Valve Location... MrDanB 7.3L and 6.9 IDI (Pre 1994) 2 03-29-2009 11:46 PM
stock cummins 12 valve fuel injectors NSXnTruckguy Whats Been Sold 1 07-02-2007 12:16 AM
cummins 60 lbs valve springs 12 valve imported_machine2 Whats Been Sold 0 05-07-2007 11:58 PM
Check valve in fuel line Extended Power 2003-2007 6.0L Power Stroke 16 09-18-2006 03:34 PM
