freightliner fld starter relay.... - TheDieselGarage.com
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by snowman_w900, this thread has received 11 replies and been viewed 10268 times.
Old 01-04-2011, 12:29 AM   #1
snowman_w900
snowman_w900's Avatar
i dont know how many of you had this happen, but today i went out to start my old freightliner fld, and it cranked kinda slow and plus it was cold out, it didnt start right away so i let off the button, and what do ya know! the starter stayed engaged! i even shut the key off and it kept cranking. By the time i got to the batterys, the starter was junked out. anyways.....not sure what caused this, but i figuer since i am gonna replace the starter and clean all the cable ends, i might as well put a new relay on.
my question is, is there only the one relay on the drivers side firewall under the wiper motor? anyone know what part number or better relay would be. i have a feeling this might have been what caused it. just curious if there is a better or updated relay......thanks guys.
snowman_w900 is offline   Reply With Quote
Old 01-04-2011, 12:47 AM   #2
5.7diesel
common up here in the north. mostly on ag tractors if the batteries are not fully charged and starter needs a lot of amps it will fry the button in the starter soleniod to the input post. if it is super cold you should have a disconnect or a wrench to unhook the cables. have fryed a few starters up here. dale
5.7diesel is offline   Reply With Quote
Old 01-04-2011, 01:37 AM   #3
Les2
Should have hammered the starter that would've stopped it...
The relay you're talking about is the only one and it most likely wasn't what caused the problem. When them go bad they stop working.
In the 13+ years I've owned mine, I've replaced that relay more than twice but less than 6 times...lol
Les2 is offline   Reply With Quote
The Following User Says Thank You to Les2 For this addition to TDG:
snowman_w900 (01-04-2011)
Old 01-04-2011, 01:50 AM   #4
Johnp3
There are two magnetic switches that could stick there is the low amperage one on the firewall and there is the mag switch on the starter. You can test them if you disconnected the battery's, or if the starer is truly fried you just replace the complete set up. Starter and mag switch.
I could see smashing the mag switch on the firewall but hitting the starter, that can cost you a core. Also it will not release welded contacts.
1988 ford van fresh overhaul, 1991 nissan pick-up 1993 Caprice 2000 GMC S10 Blaser 2007 nbs 3500 GMC 4x4 crew-cab long box 17 inch single wheels Duramax Alison. BW turnover Ball. Furakawa FL35 loader. Retired, HD mechanic, worked on engines all my life. Fabricator welder. electrician. in the process of finishing my new shop. Live in Rock Creek B.C. Wife has a fruit stand.
Johnp3 is offline   Reply With Quote
Old 01-04-2011, 01:52 AM   #5
snowman_w900
i hear ya les. I was waiting for ya to weight in on this cause i know ya run a fld and i knew ya had for a while. this is the only one i have ever had, so i am not up to date on all the little details about the wiring on these freightliners.
so what do ya think. solenoid on the starter then. id say the ol starter was on its way out. i believe it was the original one. Thanks for the info LES!!!
Old 01-04-2011, 02:07 AM   #6
jbstar62
jbstar62's Avatar
If you take the solenoid apart you will see that the copper washer is welded to contact from low voltage
jbstar62 is offline   Reply With Quote
Old 01-04-2011, 02:54 AM   #7
snowman_w900
thanks for the info JOHN. yeah i had the starter tested, its drawing alot of amps, so its time for a new one anyways i guess.....i am gonna replace the solenoid on the firewall too just to get it out of the way so i know what i got being that winter is here.
jbstar, what do ya think on the low voltage to the starter or solenoid situation. what would normally cause this to happen. i guess after hearing all this, i better check all my wiring coming up to the engine from the batt. box. Is there anyway the solenoid on the fire wall could have caused it, or just bad connection at the main starter wires or what?
Old 01-04-2011, 03:29 AM   #8
Red Diesel
O'Skool Member
Red Diesel's Avatar
Delco Remy site used to have lots of info to fix most any starter or battery or wiring problems if you have the right tools.
You have 42MT I assume.
Red Diesel is offline   Reply With Quote
Old 01-04-2011, 04:09 AM   #9
Johnp3
I spent 13.5 years working in Edmonton, While you have the batteries disconnected put each one separately on a regulated charger, clean all connections, grounds, cab leg ground especially. Test the batteries separately, How did I do jbstar.
When you get it together test the cables, and connections, with a voltage drop test. after it has run for a while test that you have at least 13.8 volts at each battery. I use to run an extra ground cable from the right frame rail to the alternator. #8 works #4 is better. Just a thought!
Old 01-04-2011, 11:51 PM   #10
5.7diesel
it is always a good idea if it is below 0* farenheit and you are going to try and start anything with any kind of delco starter is to have a disconnect plan thought out ahead of time. it is more common than you think to have a starter stick and keep spinning if the motor doesn't fire. have burnt up more than a few starters. dale
GMC T6500 starter relay Victor Medium Duty 1 02-03-2010 04:32 AM
What would cause the starter bolts to break and the starter to break in half? Rgdl 2003-2007 6.0L Power Stroke 15 06-20-2009 02:18 AM
starter or starter selnoid? 96 stroker 1994-2003 7.3L Power Stroke 6 01-31-2008 04:23 PM
starter switch relay problems...volvo, N-14 centerline Heavy Duty 4 10-03-2007 01:46 AM
SD starter relay part # Ggg 1994-2003 7.3L Power Stroke 8 07-17-2005 01:43 AM
