Updated front engine cover - TheDieselGarage.com
Go Back   TheDieselGarage.com > Ford Diesel & Truck Discussions > 2008-2010 6.4L Power Stroke
Thread Details Posted by jeffro, this thread has received 25 replies and been viewed 15844 times.
Old 01-08-2011, 03:26 AM   #1
jeffro
Thought you guys would like to see this. Today at work I installed a new updated front engine cover on a customer's 6.4L. The new design is to hopefully stop the water cavitation issues that are causing front cover failures. We are still waiting for a thermostat fix. There is a new radiator design in the works also I am told.
Old cover with damage.
Click image for larger version
Updated new cover.
jeffro is offline   Reply With Quote
Old 01-08-2011, 03:16 PM   #2
Quantum
just curious, what cause cavitation?? how many miles on the truck??
F-350 SRW 4X4 crew-cab lariat, 6.4 PSD, Banks ram air+ spartan dpf delete pipe, flo-pro 4'' straipipe.Mag-Hytec tranny oil pan.ELITE head stud +new gasket installed$$$$ coolant filter,
F-350 DRW crew cab KING RANCH 2007,6.0 powerstroke,ARP head stud, Bulletproof EGR cooler,coolant filter,SCT x3with innovative tune,
Quantum is offline   Reply With Quote
Old 01-09-2011, 03:24 AM   #3
wp6529
Very interesting. It would seem that there is/was a design flaw causing areas prone to cavitation. I wonder if they will ultimately issue a recall / TSB on this.
wp6529 is offline   Reply With Quote
Old 01-10-2011, 12:03 PM   #4
jeffro
Not sure what causes the cavitation issue. I think it has to do with water pump speed. It usually is found on the 450/550 trucks. Probably due to the lower gear in the rear end causing the engine to turn more RPM while driving. Some trucks have 30k, some trucks have 120k. We have a fleet company that some of their trucks go through covers in about every 12k. Hope the new cover is the fix.....
Old 01-10-2011, 03:38 PM   #5
budtoh3zo
hopefully that solves the issue keep us posted
2008 F-350 Lariet 6.4L 170,000 km spartan tuned 275 daily
2006 yamaha Vmax
2003 F-350 XLT 6.0L just bought 215,000 km all stock for now.
2003 suzuki 1000 GSX-R
1993 F-250 460
1978 F-150 stock waiting for a paint job
Near GP alberta.
CC#58
budtoh3zo is offline   Reply With Quote
Old 01-10-2011, 04:36 PM   #6
wp6529
The tab they added will certainly change the fluid flow, presumably eliminating areas of low pressure prone to cavitation. I would hope they issue a recall / TSB on this so we can all get the new covers prior to a cavitation eat through and the collateral damage that causes.
Old 01-10-2011, 04:53 PM   #7
cartmanea
Where does the cavitation cause coolant to leak to? Out of the front of the cover, or into the engine?
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline   Reply With Quote
Old 01-10-2011, 05:35 PM   #8
wp6529
Oil leaks out into the coolant when the engine is running, since the oil pressure is higher than the coolant pressure. When the engine is off and both pressures drop to zero some coolant leaks back into the engine. It makes a heck of a mess and can do a lot of damage.
Old 01-10-2011, 05:37 PM   #9
cartmanea
Yikes...
Old 01-10-2011, 09:42 PM   #10
jeffro
Usually coolant goes into engine crankcase. The hole ends up right in front of camshaft area. Cooling system pressure is higher than crankcase pressure. If you add water then you will fill engine with water. I have had some customers add up to 8 gallons of water trying to fill system. Some oil does make it into coolant though. I have also seen a hole in the bottom causing an external leak.
05-07 front engine cover rdr99 Ford Parts wanted 0 10-26-2009 04:58 PM
Swamps 7.3L Front engine cover OffKilter 1994-2003 7.3L Power Stroke 12 08-10-2009 10:29 PM
6.0 Front cover IGotIt Ford Parts wanted 0 07-19-2009 09:31 PM
changing front main and front cover gasket, need advice SSpeeDEMONSS 5.9L Cummins 12 Valve (1994-1998.5) 30 07-17-2009 03:21 AM
Help-cat 3406b Fuel Inj-pump Removal From Engine Front Drve Cover omarcano5 Medium and Heavy Duty 4 03-04-2007 01:47 AM
