Why you need a coolant filter!!! - TheDieselGarage.com
Thread Details Posted by bootcamp, this thread has received 5 replies and been viewed 2040 times.
Old 01-23-2011, 08:44 PM   #1
bootcamp
bootcamp's Avatar
I have 98k on my truck and I am on my 5 coolant filter change. This is what poured out of the filter. I figured at this point of being on my fifth filter change that most of the trash would have been cleaned up by now, but have was mistaken. One of these days I wil open one of these filters up and see just how bad it really is. But this picture is for those that dont have a coolant filter on their truck yet. This was money well spent.
Click image for larger version
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline   Reply With Quote
Old 01-23-2011, 08:57 PM   #2
2 stroker
Have a look at this one running over on the DieselStop and it was just flushed at a Ford dealer good old Ford Gold Cxxp
http://www.thedieselstop.com/forums/...7/#post2013609
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge CTS Expandable Pyro,AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Coolant Filtration System Delo ELC
Pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline   Reply With Quote
Old 01-23-2011, 11:31 PM   #3
lilpooh
lilpooh's Avatar
Attachment 27962
Just wait until you do cut one open, you'll find alot more crap inside!!!
2004 F350 CC DRW King Ranch
X-3 tunes by DJ,QT,GH,ID,Gyphon FICM tuner,head studs,II Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,Snow Perf stage II,EGR delete,AD2,4" turbo back straight pipe,K&N intake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Thanks to:JASONS REPAIR AND PERFORMANCE-TELFORD,PA.
"Are diesel pickups hot rods? Yes,they are-perhaps the most versatile hot rods ever made"---Diesel Power Magazine
lilpooh is offline   Reply With Quote
Old 01-24-2011, 01:09 AM   #4
Bigrigs
Bigrigs's Avatar
Yikes, I remember those filters/days....As long as you keep the OEM coolant in, you won't see the day that crap stops building! Do yourself a HUGE favor, flush all that fancy gold crap out of your engine, and refill with CAT-Ec1 rated red coolant, definitely keep the filter system, then you'll reach the days where that crap will stop building and the filtration system will stay simple and keep things clean as apposed to trying to constantly clean out the system.
-SOLD-04 F350 CC DRW 6.0PSD...ARP studded & Elite full delete : DieselSite coolant filter : RED ELC SCT X3 by Innovative & Gearhead : Custom built all Billet 5R110 : Diamond Eye 4" duals : zoodad & ccv mod : guages and more gauges
Bigrigs is offline   Reply With Quote
Old 01-30-2011, 10:36 PM   #5
maladosteo35
maladosteo35's Avatar
Images: 2
Just opened up my bypass coolant filter....
bootcamp, i just swapped out the first coolant filter (Dieselsite) after @10,000 miles. the filter element/ media was covered in this light brown slime. there was alot of sandy grit on the bottom part and sides of the filter canister. i am still running the stock gold coolant. i can see now that i need to change it out. what kind of coolant works best on the 6.0?
here are the pics...
ID:	28081   Click image for larger version
2005 F-250 Lariat CC FX4 4WD, Atlas 40 FICM, 200 amp Alt, 5th Wheel hitch, 5 inch Turbo back Cat/ Muffler delete, IPR EGR Delete, IPR Up=pipe, '08 banjo bolt mod, Blue Spring mod, AMSOIL oil bypass filter, Dieselsite Coolant bypass filter, Zoodad mod, High idle mod, CCV mod, Rotella T6 5w-40, Recon Blacked out third brake light/ side mirror turn signals, 7in Screen Double Din AM/FM/CD/DVD/ iPod ctrl/ NTSC TV eBay special, Rear 56" 5 way light bar
maladosteo35 is offline   Reply With Quote
Old 01-30-2011, 11:29 PM   #6
bootcamp
bootcamp's Avatar
Dude take a look back at some earlier post and there are several threads on what coolant and how to do a complete flush. Alot of guys use the CAT-EC1 red coolant and Restore to do the flush with. I am in the same boat and need to do a flush myself. I want that ford gold out cause it is more like ford rust..... If this stuff is coming out of the coolant filter, I wounder what my oil cooler likes????
Run your next filter for about 500 miles and the next one for 1000 miles these were the recomendations here on the site. I am on al least my 6 filter and I am still seeing this type of crap come out of the filter.
USMC 87-90 MOTOR-T
oil bypass filter and coolant filter where does everbody mount them ranger518 2003-2007 6.0 Tuner Forum 29 08-21-2011 05:55 AM
Coolant Filter Kit? Fantom3993 2003-2007 6.0L Power Stroke 6 03-19-2010 08:14 PM
Coolant filter??? imported_DieselKid 2003-2007 6.0L Power Stroke 11 09-04-2007 01:29 PM
coolant filter? 04-F350 2003-2007 6.0L Power Stroke 7 12-27-2006 02:39 AM
a better coolant filter! _CH_ 2003-2007 6.0L Power Stroke 20 10-23-2005 11:51 PM
