2003 turbo 10 vane questions - TheDieselGarage.com
Thread Details Posted by ranger518, this thread has received 37 replies and been viewed 13723 times.
Old 02-01-2011, 12:17 AM   #1
ranger518
ranger518's Avatar
Hi i was wondering what made the 2003 turbos so loud is it the 10 vane wheel or is it somthing else. If it is just the wheel could you replace the 13 vane wheel on the newer style turbo for the older 10 vane wheel. Was just wondering what the differance was the made the 2003 turbos whisle so loud.
I think it is great that Cummings service trucks are f-550 with 6.0 and 6.4. They must know somthing?
2006 F-250 lariat FX4
4" turbo back MBRP stainless steel exhaust cat delete
Airaide intake
Homemade coolant filter
Custom oil bypass filter
Quad pillar gauges EOT, ECT, Fuel pressure, and EGT
RCD EGR kit with new up pipe
Blue Ford fuel spring went form 45psi to 68psi part number 3C3Z-9T517-AG
Rancho Rs9000 shocks with my ride controll
Homemade 3" lift
315x70x17 BFG AT's
SCT With custom Innovative tunes
Mobil ELC Cat-1 Coolant
2004 Turbo
Zoodad mod
ranger518 is offline   Reply With Quote
Old 02-01-2011, 02:34 PM   #2
ZIsbell
Here's your sign!
ZIsbell's Avatar
Yea it is the 10 vane wheel it moves a lot more air than the 13 or 15 vane turbos. The wheels can be changed like you are talking about. I prefer the sound of the 10 vane in my 03 over the others.
03 F350 CC LB 2WD Lariat 6.0L Dually
TDG Dually Club #30 :ford
ZIsbell is offline   Reply With Quote
Old 02-01-2011, 06:05 PM   #3
International350
International350's Avatar
If the vanes are changable, what would the part number be and where would I get it?
2004 F-350 CC LB King Ranch. Under the Hood SCT w/Innovative street tunes by Eric, Hot FICM tuned by Power Hungary, custom built 4" intake with huge afe filter, Intake elbow, 3"down pipe to 5" straight piped stack, EGR block off, Zoodad Mod, CCV mod, Complete EGR delete, The Big 3 cable upgrade w/ batts under cab, Autometer pillar guages, Boost, Trans, EGT. APR studs sitting in box ready for install
Suspension 2.5inch leveling kit. Stock King Ranch 18" rims with 33inch Nitto A/T.
Truck is now pushing 134K miles an running strong.
International350 is offline   Reply With Quote
Old 02-01-2011, 06:15 PM   #4
SSpeeDEMONSS
SSpeeDEMONSS's Avatar
Send a message via Yahoo to SSpeeDEMONSS
so you're saying that its the 03 wheel? i was always under the impression that it was the 10 vanes that made it whistle. hence less whistle with 13 and even less with 15.
BRING BACK THE OLD TDG!
oh well, i have a map to the darkside
SSpeeDEMONSS is offline   Reply With Quote
Old 02-01-2011, 07:51 PM   #5
ZIsbell
Here's your sign!
ZIsbell's Avatar
The 2003 model trucks were the only trucks that came out with the 10 vane turbos, when i said 03 in my previous post i was talking about the year model of my truck.
Vanes inside a turbocharger control the acceleration of gases inside the turbo and thus the speed at which the turbocharger itself can accelerate the compressor and produce boost. Tight vanes produce a quick spooling turbo with little lag but one that can quickly choke the engine at higher speeds. This is because the engine is trying to push to much exhaust through the turbo and the vanes are constricting it. Wider spaced vanes can allow a turbo to have more top end capability but at the expense of spool time (otherwise known as turbo lag).
The vanes are not changeable. I mentioned in my previous post 10 vane "wheel" and i didn't mean to call the vanes a wheel.
Old 02-02-2011, 12:46 AM   #6
ranger518
ranger518's Avatar
So is there any down fall of the 10 van turbo other than more lag?
Airaide intake
Homemade 3" lift
315x70x17 BFG AT's
2004 Turbo
Zoodad mod
Old 02-02-2011, 02:36 AM   #7
lilpooh
lilpooh's Avatar
The early '04's with the '03 engine also had 10 blades on the wheel.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ,QT,GH,ID,Gyphon FICM tuner,head studs,II Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,Snow Perf stage II,EGR delete,AD2,4" turbo back straight pipe,K&N intake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Thanks to:JASONS REPAIR AND PERFORMANCE-TELFORD,PA.
"Are diesel pickups hot rods? Yes,they are-perhaps the most versatile hot rods ever made"---Diesel Power Magazine
lilpooh is offline   Reply With Quote
Old 02-02-2011, 11:38 PM   #8
ZIsbell
Here's your sign!
ZIsbell's Avatar
It's not enough lag in my opinion to matter, some say the 10 vane with make a little more power in the top end than the others, but the sound of a 10 vane is priceless.
Old 02-03-2011, 12:10 AM   #9
harry6.0
harry6.0's Avatar
Your exactly right Lilpooh. Don't know why people still get mixed up about the "vanes" and the "blades". I'll say it again for all the members that misunderstand the turbo.
1. Vanes, all the stock 6.0 turbos and even my powermax turbo, have 9-variable vanes or gates that control the flow of the exhaust gasses on the exhaust turbine wheel.
2. Blades, 10-blades, 13-blades, 15-blades, however many blades, they are on the intake compressor wheel.
The whistle is from the intake air flow past the blades.
Harry
Jan 03' built 6.0/F250cc4wd trqsft/SCT-tuned by KEM-Performance/Garrett Powermax vg-turbo/blue spring mod/gauges=egt+boost+fuel+SG2/exhaust/airaid intake/DR 4.5 lift/dual bilsteins/315's/greasable ball joints/powerstop/smittybuilt/kc lights/high idle mod/roll-n-lock/Mobil Delvac1 ESP 5W40 with (Archoil AR9100 in the oil) and (AR6200 in the fuel)http://www.archoilspokane.com/
harry6.0 is offline   Reply With Quote
The Following User Says Thank You to harry6.0 For this addition to TDG:
bootcamp (02-06-2011)
Old 02-03-2011, 02:53 AM   #10
harry6.0
harry6.0's Avatar
2. Blades, 10-blades, 13-blades, 15-blades, however many blades, they are on the exhaust turbine wheel.
The whistle is from the exhaust air flow past the turbine blades.
Harry
I have to correct myself. The blades I was refering to are on the exhaust turbine wheel, not the intake compressor wheel. The whistle is from the exhaust gasses passing the 10 blade exhaust turbine. My bad. Long day. It should read like I've edited above.
Harry
2003 6.0 headgaskets and other questions getusummm 2003-2007 6.0L Power Stroke 24 01-30-2010 12:13 AM
2003 6.0 questions. 250stroke 2003-2007 6.0L Power Stroke 16 01-23-2010 03:19 AM
Turbo Vane Fouling ralphinnj 2003-2007 6.0L Power Stroke 11 07-11-2007 11:57 AM
Few questions about 2003 3500 mxjeepin 5.9L Cummins (2003-2007.5) 8 05-09-2007 11:20 PM
6.0L Variable Vane Turbo fordt 2003-2007 6.0L Power Stroke 34 06-06-2006 02:34 AM
