No Boost, No Power, And No RPM's over 1100 - TheDieselGarage.com
Thread Details Posted by bigtex76, this thread has received 25 replies and been viewed 2426 times.
Old 02-10-2011, 02:11 PM   #1
bigtex76
Question No Boost, No Power, And No RPM's over 1100
Lets start with I have a 2004 Excursion with 145,000 on the clock. Its has been running fine... after egr cooler, oil cooler, water pump and IPR replaced (luckily under warranty). On friday i was headed home, and suddenly, at the stoplight, i lost all power. The engine is still running, but i have no power, could hardly get it to pull into the parking lot. The engine is running smooth, but there is no wistle from the turbo. I shut it down, and made some calls, Friend says its prob. the MAP sensor. After about 15 min, it started up, and ran fine back to the house. I changed the MAP sensor, and went for a drive... Same thing... lost power once it warmed up. When it does this, you can hear the turbo intermitantly.. just an occasional whistle. Someone plaese HELP!!
04' Excursion Limited 6.0l,
Volant Cold air,
Accufab Intake Elbow,
Dieselsite Coolant Filter,
Silverline 4" cat delete exhaust,
Pro-Comp lift,
35/12.5x20 Pro-Comp Extreme
bigtex76 is offline   Reply With Quote
Old 02-10-2011, 04:07 PM   #2
lenzhotrod
Don't throw parts at it. I would look for any codes, then for any loose wires. What is your fuel pressure like? Possible throttle control. Test,verify,repair.
lenzhotrod is offline   Reply With Quote
Old 02-10-2011, 06:37 PM   #3
bigtex76
I had a code scanner hooked up, and no codes, but it wasn't a full diagnostic from a dealer... It doesn't blow black, its blowing out grey smoke.. all unburnt fuel.. I havent checked all the boots, but the ones up top are still in place. I pulled the EGR valve last night, cleaned it, and put new o-rings on. Haven't checked fuel pressure yet... not sure how! I haven't driven it yet to see if that helped... its been cold, and it seems to only do it when its warmed up.I will check it out when i get home
Volant Cold air,
Pro-Comp lift,
Old 02-10-2011, 07:00 PM   #4
kidn1980
kidn1980's Avatar
lenzhotrod will guide you through he guided me through my i am now a strong believer in TEST,VERIFY,REPAIR...
05 PSD
12" FABTECH
4" TURBO STRAIGHT PIPE
20" CUSTOM DIAMO RIMS
40" NITTO MUD GRAPPLERS
DIXIE LAND HORN
SUPERCHIPS PROGRAM
S&B INTAKE
SINISTER VALVE/COOLER DELETE
101ST AIRBORNE DIVISION
kidn1980 is offline   Reply With Quote
Old 02-10-2011, 07:12 PM   #5
bigtex76
I am open to all sugestions... it sux having a rig that you cant drive for more than a week at a time. I will listen and learn...
Volant Cold air,
Pro-Comp lift,
Old 02-10-2011, 09:41 PM   #6
ranger518
ranger518's Avatar
If you have no boost and no power you may have stuck vanes on your turbo and it may need to be cleaned with 145K on it if it has never been done it sure would not heart.
This is how you can do it if you want to give it a try
http://www.forddoctorsdts.com/articl...icle-06-05.php
I think it is great that Cummings service trucks are f-550 with 6.0 and 6.4. They must know somthing?
2006 F-250 lariat FX4
4" turbo back MBRP stainless steel exhaust cat delete
Airaide intake
Homemade coolant filter
Custom oil bypass filter
Quad pillar gauges EOT, ECT, Fuel pressure, and EGT
RCD EGR kit with new up pipe
Blue Ford fuel spring went form 45psi to 68psi part number 3C3Z-9T517-AG
Rancho Rs9000 shocks with my ride controll
Homemade 3" lift
315x70x17 BFG AT's
SCT With custom Innovative tunes
Mobil ELC Cat-1 Coolant
2004 Turbo
Zoodad mod
ranger518 is offline   Reply With Quote
Old 02-10-2011, 10:29 PM   #7
bigtex76
I have been reading some of the other forums about doing that. On mine, when it loses power, there is no whistle from the turbo at all, then occasionally, you will hear it do a quick whistle, and stop...
Volant Cold air,
Pro-Comp lift,
Old 02-10-2011, 11:47 PM   #8
offroadinginaz
I Bleed BLUE!
Was there carbon in you EGR valve keeping it from closing?
A few Fords
offroadinginaz is offline   Reply With Quote
Old 02-12-2011, 12:18 AM   #9
bigtex76
The egr was pretty nasty, but it cleaned up. Then, last night, I found that my exhaust had come loose at the down pipe. Could this have caused the ebp sensor to think something was wrong?
Volant Cold air,
Pro-Comp lift,
Old 02-17-2011, 10:14 AM   #10
tmoriarty19
Tyler
if theres no whisle id check your low pressure oil feed to the top of the turbo. you can try to unbolt it a little bit while its running to make sure oil comes out. a bit messy tho. but if by chance the turbo is coked up with oil inside then verifying there is oil at the supply line wouldnt really help.
tmoriarty19 is offline   Reply With Quote
Can you get more power at low end RPM's ??? ChrisSheerman 2003-2007 6.0 Tuner Forum 27 05-28-2009 12:46 AM
Fix for my low power low boost thefatkid 2003-2007 6.0L Power Stroke 2 04-10-2007 03:11 PM
Low boost, no power gasco Duramax 2001-2004 (LB7) 5 01-26-2007 01:28 AM
1100 hp 12v.. blackcloudCTD95 5.9L Cummins 12 Valve (1994-1998.5) 40 01-01-2007 07:19 PM
Power from idle to about 1800 rpm's??? Motown Fire 2003-2007 6.0 Tuner Forum 3 07-11-2006 02:02 AM
