FORD A/C on 5.9 - Page 3 - TheDieselGarage.com
Go Back   TheDieselGarage.com > Diesel Conversion > Cummins in Fords
Thread Details Posted by fordtrucknut, this thread has received 30 replies and been viewed 13361 times.
Old 04-27-2011, 02:30 AM   #21
char1355
Cummins ac brackets
The ac bracket generally referred to as the high mount was used on Ford and Freightliner medium dutys. The cummins part number for the mount is 3930822. The upper alternator mount is 3920862 and the lower one is 3930820. The lower water inlet on the Fords usually turns straight down. This generally won't work on a GM. There is one that goes straight out that will clear on those. The upper water outlet points straight up. The hose goes up and over the alternator arm. The ac compressor for this bracket can be found on ebay listing for Ford/Sterling ac compressor. The alternator bracket is designed for a 21si or 22si J180 style unit. These were used on virtually every medium duty truck. These alternators are 1 wire and have an output terminal for your charge light and one for a tach. You can use a Dakota Digital interace to link to your factory tach. There is also a cummins bracket that mounts an ac compressor on the top drivers side beside#1 valve cover. This one is found on Case tractors and uses an accessory V belt pulley mounted on the fan hub. I priced this set up once and it was between $400 and $500 just for the bracket, pulley and belt. You could probably have one custom made cheaper.The guys at GOS Performance have custom ac brackets. The high mount bracket can be found on virtually every Ford/Cummins medium duty application including school buses. Many times you will see the bracket without an ac compressor but has an ac delete pulley in its place. That way the belt length is the same with or without ac. Hope this info helps. I plan to use a high mount bracket but am putting my Ford vacuum pump in the ac spot. That will put it in exactly the same area as original.
char1355 is offline   Reply With Quote
Old 04-27-2011, 04:47 AM   #22
fordtrucknut
NOOB
fordtrucknut's Avatar
char1355...you don't happen to have any of those brackets and water necks kicking around do ya?? I'd LOVE to buy em if you do!!!
fordtrucknut is offline   Reply With Quote
Old 04-29-2011, 02:37 PM   #23
04lariatfx4crewcab
04lariatfx4crewcab's Avatar
trucknut, I got to looking at that ac mounting bracket and the bottom part that mounts to the block is cracked very bad crack too. I could not tell because it was caked with oil and such. they tightend it so much that the part that was attached to it left an indention half as deep as this bracket is thick. It is bearly hanging on. Let me know if you still want the rest of this stuff. Sorry I have been working on other stuff lately.
Jakob
2004 5.9L/47rh Lariat FX4 Crew Cab Short bed. 213K miles 18" dbacks with nitto A/T grapplers, Zoodad mod, and 2000 turn signal mod. Limited Excursion bumpers front and back. Chrome grill, EGR delete, FICM delete, glow plug delete, HPOP delete, 2 cylinders delete, and 20 valves deleted
97 12v/47rh built by Garmon's
04lariatfx4crewcab is offline   Reply With Quote
Old 04-29-2011, 03:14 PM   #24
fordtrucknut
NOOB
I'm still interested....is the v belt pulley removable that runs it as well by chance?
Old 04-29-2011, 11:49 PM   #25
char1355
ac brackets
Trucknut, sorry I don't have any spare brackets. In fact I just bought a complete set up from an F700 Ford. The guy was putting it in a Dodge and didn't need any of the Ford parts. They are out there. Just have to be patient. Took me over a year to find one. You can get all the parts from Cummins but they ain't very cheap. If there are any HD truck salvage yards around you may find the set up there. The set up using the auxilary V belt is almost impossible to find used. Not too many Case tractors around with ac. The pulley bolts onto the front of the fan hub and use bolts that are a little longer. Cummins and Ford used this set up to mount a vacuum pump beside the #1 valve cover. See these for sale sometimes. Most guys who put the ac compressor there make their own bracket. All the accessory pulleys I've seen are 4 bolt. There may be a 6 bolt one as well. I have attached a photo of a brand new cummins 6bta with the pulley and the top bracket. Don't we wish ours could be that nice. If you need a photo of the other style set up I'll get you one.
Click image for larger version
Name:	cummins photo.jpg
Old 04-30-2011, 12:38 AM   #26
04lariatfx4crewcab
Yes the v belt pulley is removeable but because the bolts are so long and there is quite a large spacer that goes between the serp belt fan pulley and the V belt pulley I was going to just keep it on there unused as a spacer. I think I can use the Freightliner fan, but I am not sure if I can use a dodge fan or not. What fan do you have maybe we could trade parts?
Jakob
Old 04-30-2011, 09:01 AM   #27
fordtrucknut
NOOB
It's the stock Dodge fan..but the fan itself is a bit bent up...fan clutch and that is fine tho.
Old 04-30-2011, 03:21 PM   #28
char1355
Here is a set up a guy in Michigan is using on a 4bt going into a Ford pickup. He top mounted the Ford compressor and is using a reverse rotation pulley. Although he made his own pulley I plan to use the one from a CR 5.9 which is already rev rotation. This way you only have one belt to deal with.
Old 07-12-2011, 11:42 PM   #29
hayjayhorses
hayjayhorses's Avatar
Originally Posted by strawboss View Post
This is the best I can do
what did that thermostat housing come off of?
any chance you might have an engine serial # so I can get one threw cummins.
you can't buy a gum ball from Cummins North East in Springfeild Mass without a serial #.
Jay Noone
413-222-8286
I got hay
abolish the Federal Reserve, they are the real problem
Vote Ron Paul 2012
hayjayhorses is offline   Reply With Quote
Old 07-13-2011, 05:43 AM   #30
fordtrucknut
NOOB
I FINALLY managed to locate the high mount A/C Bracket locally...I have the idler bracket being made by a friend (FREE)...but don't have that yet...here is a pic of what I have so far
ford 10.25 and 10.5 the same? brad's-powerstroked General Ford Truck and Excursion 6 07-16-2010 04:04 PM
Ford on Ford crime ToddPSD Road Kill, Bench Racing 19 07-25-2007 10:36 PM
NEED HELP! 91 ford dsl to 94 ford dsl motor tireguy Diesel Conversion 4 01-30-2007 12:10 AM
Bill Ford out as CEO of FORD fordt The Parking Lot 6 09-06-2006 02:08 AM
Screaming Ford Becomes Ford Double Dually King of Obsolete Medium and Heavy Duty 22 08-24-2006 01:48 AM
