3406E oil pressure flutter - TheDieselGarage.com
Thread Details Posted by AaronF, this thread has received 4 replies and been viewed 2937 times.
Old 03-09-2011, 08:25 PM   #1
AaronF
Ok, 1996 5Ek 3406E. Oil pressure cold is 60psi, hot it is 35psi.
When cruising 1400-up the oil pressure holds 58 psi.
When hauling/pulling/lugging the oil pressure fluctuates slightly from 53-55 psi.
I noticed three times today that when idling hot the oil pressure was fluttering between 35-40 psi. I have done some searching on the net and the only thing that I could come up with was either a worn oil pump, or debri in the releif valve.
Any other thoughts? Is this normal for an "E" model. I have very little experience with them. Almost all of my experience is with 3406b's or those POS 2005 465 Volvo motors.
Would getting the "upgraded" relief valve for the pump be worthwhile?
On a side note, the motor seems to pound while running down the road, atleast compared to a "B" model. I just don't know what to expect from this thing due to my lack of experience with them. Damned thing just sounds to tinny.
On a different note, the motor seems to pound when running down the road, atleast compared to a "B" model. I just don't know what these should run/sound/act like due to my lack of experience with them. Damned thing just sounds so tinny.
AaronF is offline   Reply With Quote
Old 03-09-2011, 11:17 PM   #2
SledMan
SledMan's Avatar
I had 2 5EK's, and one of my customers had 4 that when hot, idled at 25, and only made 45-50 on the highway. The factory pump had aluminum back plates in which all were grooved up. A new pump with the cast iron plate fixed the problems on all of them. Idle at 40-42 and 60-65 on highway.
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks: 1979 Kenworth W900A reg hood, 1980 Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3026 squirts. 800 cam. Acert twins via custom mount. ARP head bolts. 856 to the tires via Antrim Dyno.. with the tuned file.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline   Reply With Quote
The Following User Says Thank You to SledMan For this addition to TDG:
AaronF (03-10-2011)
Old 03-10-2011, 08:17 AM   #3
AaronF
What about the fluttering pressuree though? Is that the pump, or the relief valve?
Old 03-10-2011, 12:22 PM   #4
josh G
It's the pump because the worn end plate is letting the oil bypass from the pressure side of the pump to the suction side thus causing the pressure fluctuation. As sled said they updated the pumps with cast iron end plates.
josh G is offline   Reply With Quote
Old 03-10-2011, 07:17 PM   #5
Johnp3
Lots of gauges need a restrictor to remove the pulsations from the line.
I would be installing a manual oil filled gauge in the system to be looking, It is a gear pump and is just a continual flow of pulses.
I would put in a manual gauge oil filled to see. If it is leakage past the end plates it would be continual leakage not going up and down, A two pound fluctuation is not a problem, Cat in the C15 manual says a fluctuation of 10 lbs should be looked at below that they are not worried. The ones I can remember that had oil pressure fluctuations most were a lot better when the oil filter was changed.
The minimum pressure above 1200 RPM loaded is 40. and 15 at Idle.
If you have access to a program the last line on the Parameters is the oil pan level.
Just a thought!
1988 ford van fresh overhaul, 1991 nissan pick-up 1993 Caprice 2000 GMC S10 Blaser 2007 nbs 3500 GMC 4x4 crew-cab long box 17 inch single wheels Duramax Alison. BW turnover Ball. Furakawa FL35 loader. Retired, HD mechanic, worked on engines all my life. Fabricator welder. electrician. in the process of finishing my new shop. Live in Rock Creek B.C. Wife has a fruit stand.
Johnp3 is offline   Reply With Quote
Turbo Flutter... midnight2004 2003-2007 6.0L Power Stroke 1 05-20-2010 07:16 PM
3406e cylinder pressure bluewater0650 Medium and Heavy Duty 4 10-09-2009 03:05 AM
Turbo Flutter DUK 2008-2010 6.4L Power Stroke 2 06-10-2009 12:20 PM
Turbo Flutter hawthorne 5.9L Cummins 12 Valve (1994-1998.5) 15 02-05-2008 04:06 PM
turbo flutter biscuit_ford 1994-2003 7.3L Power Stroke 3 11-27-2007 01:23 PM
