peterbilt speedometer and odometer Quit? - TheDieselGarage.com
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by mlentsch, this thread has received 4 replies and been viewed 7791 times.
Old 03-28-2011, 12:34 AM   #1
mlentsch
1998 379 peterbilt speedometer and odometer quit. The transmission has one sensor on the tailshaft that I pulled out and cleaned up then reinstalled, nothing changed anyone know where to go next or how to test the sensor?
Thanks for any help!!
mlentsch is offline   Reply With Quote
Old 03-28-2011, 01:00 AM   #2
mslashbar
I've got a 90 and had lots of problems with the plugs going into the back of the gauges. You might try opening up the dash and wiggling the connectors around to make sure you have a good connection.
mslashbar is offline   Reply With Quote
Old 03-28-2011, 02:43 AM   #3
379Longhood
379Longhood's Avatar
there is a link in the handy links sticky, supermiller, has schematics for petes.
But a quick trouble check is with a multi meter check for power to one of the wires going to the trans sensor, if you have power there , check for power across the plug it won't be 12V more like 3 or 4 if you have that check for resistance across the sensor if none sensor is prolly bad, if you have no power to the plug check fuses , then check schematic tio find wire number, sometimes they change going thru a plug. trace till you find an open .
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline   Reply With Quote
Old 03-28-2011, 02:44 AM   #4
theakerstwo
See if this dont help you http://www.ametekdixson.com/technical/index.cfm
theakerstwo is online now   Reply With Quote
Old 04-06-2011, 03:01 AM   #5
mlentsch
Thanks for all the help!!!
odometer bigswede Heavy Duty 1 03-20-2011 11:40 PM
odometer sinclair 2003-2007 6.0L Power Stroke 6 01-27-2010 08:28 PM
no speedometer, odometer, overdrive, or cruise control on 91 2500 zag 5.9L Cummins (Pre 1994) 2 01-14-2010 08:11 AM
NO ODometer or speedometer and the cops on my tail whitelightning 1994-2003 7.3L Power Stroke 1 06-14-2009 01:10 AM
Accu Pro Speedometer and Odometer Calibrator CumminsPower Whats Been Sold 2 09-06-2007 06:24 PM
