dt466e needs more power - TheDieselGarage.com
Thread Details Posted by josh7, this thread has received 25 replies and been viewed 17565 times.
Old 04-03-2011, 07:47 PM   #1
josh7
hi all,i have a 2001 international 4900, dt466e, 6 speed,3.91 rear end,11r 22.5 tires dealer won,t reflash compurter for more hp so what can i do to get more power? chips, exhaust or do i live with it.the truck has 205000 miles and runs great empty but when u put 10,000 lbs on it she drops 10-15 mph on long grades this seems to be a common complaint on these trucks any help would be great.
't
josh7 is offline   Reply With Quote
Old 04-03-2011, 08:02 PM   #2
josh7
sorry forgot 195 hp
Old 04-03-2011, 11:15 PM   #3
John_G
Super Moderator
John_G's Avatar
The 195 HP is the second lowest offered in the line-up, to get more powr you need more Tq and that includes pistons, turbo and injectors (possibaly the HPOP as well). In fact, you may need a lager CAC and/or radiator as well.
There are lots of ways to FOOL the ECM into injecting more fuel, but this is an engineered SYSTEM and you WILL find the fuse in the driveline (clutch/trans etc).
Cummins, Detroit and CAT don't care because they don't build trucks, only engines and they have zero responsibility for the driveline.
I vote for LIBERTY!
Old 04-04-2011, 12:06 AM   #4
josh7
the build sheet says it has a dt466 ht 195 hp/207 hp peak 2400 gov also came with 295/75r22.5 tires would going back to them instead of 11r22.5 help with pulling hills and what would it do to fuel mileage?this truck is all highway driving and gets 10mpg or just above running 58mph
Old 04-04-2011, 01:08 AM   #5
nevrenufhp
Super Moderator
nevrenufhp's Avatar
10 mpg isnt too bad. There's ways to get more power, but if your setup is a split radiator/aftercooler, then you're in for some more spending. Those modules & stuff really dont add much, especially considering the cost.
Dale
my daily driver:67 F100, 300 4V, cammed, 4 spd.
or, 08 VW R32.
work rigs: 94 IH 4900, DT466(originally 230hp), #0 fuel plate, tighter gov springs, 22* timing
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline   Reply With Quote
Old 04-04-2011, 01:15 AM   #6
josh7
it does have a slit radiator.how much more power would i get by turning up the fuel pressure and a performance muffler like a aero 4040
Old 04-04-2011, 01:20 AM   #7
nevrenufhp
Super Moderator
nevrenufhp's Avatar
I'd say about 5hp at best. The injectors are what's holding it back.
Dale
or, 08 VW R32.
Old 04-04-2011, 01:32 AM   #8
josh7
what would the cost be for getting my injectors done and how hard are they to change?is there a way i could get used injectors and have them done to reduce down time?i have a heavy equip.salvage yard close by they treat me pretty good
Old 04-04-2011, 01:56 AM   #9
nevrenufhp
Super Moderator
nevrenufhp's Avatar
It's a little more involved than swapping injectors on a mechanical engine. Talk with that wrecking yard, and find some as close to your year and hp level as possible. They used so many different injector bodies, that you dont want to be mixing them up. Cost? I've seen from $79 up to $350, per injector.
Dale
or, 08 VW R32.
Old 04-04-2011, 04:29 AM   #10
John_G
Super Moderator
John_G's Avatar
More fuel won't do anything without more air, except waste fuel.....
What RPM does it turn at 60?
I vote for LIBERTY!
Tags
dt466e, more power
dt466e more power cold than warm bquick Medium and Heavy Duty 9 02-28-2012 07:10 PM
DT466E Air in Fuel / Sputtering / No Power fordt Medium and Heavy Duty 14 04-06-2010 02:17 PM
No Power Dt466e PFMTRUCK Medium and Heavy Duty 3 05-03-2008 06:10 PM
DT466e power plug ins worktruck Medium and Heavy Duty 1 01-17-2008 01:48 AM
99 DT466E more power? groceryman Medium and Heavy Duty 5 01-10-2008 12:23 AM
