| Thread Details Posted by Rocketship, this thread has received 4 replies and been viewed 3078 times. |
#1 |
International 4300 HVAC issue
I've got an 05 4300 and the air is only coming out of the vents. I checked all the fuses and breakers in the cab fuse panel and they all check out. I do not think it's the control as the air gets noticably colder when it is turned to AC on a warm day. Has anyone else had this issue and what did you do to rectify it? I really need the defroster for the mornings!
| Sponsored Links | |||
Advertisement | |||
#2 |
sounds like a faulty mode door actuator, pulled the fuse panel cover and the panel right below it, you will have access to the blower motor and actuators now, look on the left side of the blower motor and you should see two actuator motors. the one closest to you is for the blend air door(hot/cold) and the other is the mode door(vent/floor/defrost), with the key on you can can the settings and watch each actuator, if the mode door actuator is bad you will need a t20 socket to remove it, has two gold colored screws, can be a painto replace if the fuse panel wiring is routed right over it, after replaceing the actuator pull the hvac fuses with the key on the reset them and they will self calibrate and it should start working.
#3 |
Try simply unplugging the panel that controls the modes first. That will sometimes reset it and it will start working again. I've done it plenty of times.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. BDP modded IDM. Heim joint clutch linkage. Adrenaline HPOP. LUK SMFW. DIY Elec. Fuel. FS1282, FF5230 fuel filters. |
#4 | ||
Super Moderator
![]() Join Date: Dec 2008
You certainly can remove the control head and unplug it, but I'm all for the fast and simple as oppsed to the sloer and potentially damaging (plastic and cold temps is a bad combination).
'93 F-250 HD, 7.3L IDI, 5spd - FARM TRUCK I Support: Trailer brakes an every axle over the towing vehicle's GVW; CDLs for RVers; Safety inspections for ALL vehicles and 6 axle trucks (97K GVW proposal). Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote - Benjamin Franklin I vote for LIBERTY! |
#5 |
Thanks for the responses guys, it was the mode actuator. The motor is still good but the plastic housing over the shaft broke. At least I was able to move the air down to the floor for now and keep from getting blown in the face.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Brake issue International 4300 2002 (hydraulic) | wave97 | Medium Duty | 6 | 04-12-2009 02:59 PM |
| 2004 International 4300 dt466 | Frankiep02 | Medium Duty | 3 | 01-01-2009 02:31 PM |
| International 4300 Truck Bed? | Bamf947 | Heavy Duty | 2 | 03-08-2008 01:14 PM |
| Isuzu FTR or International 4300 or F-650/6500, etc. | windnsea00 | Heavy Duty | 11 | 11-03-2007 04:36 PM |
| New To Site? | Need Help? | TDG Specials |
