Water squirting out #1 head Cummins - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by LOG HAULER, this thread has received 18 replies and been viewed 2793 times.
Old 05-26-2011, 11:34 PM   #1
LOG HAULER
Big Cam Power!!!!!
LOG HAULER's Avatar
Hello finishing up inframe Big Cam Cummins on Amodel ran into this snag when turning over the engine water squirts out from under the head I notice silicone around where the liners sit when we first install the liners the block was cut prior for lpf We installed the 20 thousands shims ,however the mechanic thinks the original silicone came from prior mechanics who maybe shaved too much and use the silicone to make up for it....any takes or recommendations...he is going to tear it back down tomorrow remove head and liners and bead the seat with the silicone.....
Get right before you get left!
91 Taurus SHO 220hp
2005 GS 430 300hp
1985 Freightliner FLC Big Cam 350 No Mods Yet
1979 Kenworth W900 Big Cam 550Hp
If it aint something it's something else!!
LOG HAULER is offline   Reply With Quote
Old 05-27-2011, 03:08 AM   #2
cdwood388
I was having a similar problem and it was a cracked counterbore. Mine was barely leaking just a little, not worthy of a teardown yet. I was told by the mechanic that a counterbore liner would be required at overhaul, but squirting is a different story.
cdwood388 is offline   Reply With Quote
Old 05-27-2011, 09:15 PM   #3
LOG HAULER
Big Cam Power!!!!!
LOG HAULER's Avatar
Mechanic figured out what the problem was the when the block was cut for lpf the liners sat to low so what the previous mechanic did when they inframed it years ago was put a bead of silicone around the the lip and place the 20thousand shim on top of it and it level it out with the head ...so he is going to have to do the same thing. So they tore it all back down again mic every thing this old mechanic has taught me so much in the last week it's been unreal) he really knows his stuff I feel like I'll be able to do my next inframe
91 Taurus SHO 220hp
2005 GS 430 300hp
Old 05-27-2011, 11:03 PM   #4
tc2
I don't see how the silicone will do much when the head is bolted down. LPF liner seal rings are available in 8 sizes from .0195" to 0.0620" to deal with situations like this.
tc2 is offline   Reply With Quote
Old 05-27-2011, 11:27 PM   #5
theakerstwo
Get a different mechanic. Silcone is not the way to go and the shim goes under the liner and who ever install the liners should have checked the liner protrusion.
theakerstwo is offline   Reply With Quote
Old 05-28-2011, 01:41 AM   #6
Flyingpig
Flyingpig's Avatar
The idea of using silicone sounds to me like the liner is going to be working up and down with every stroke of the piston. That will have to lead to a blown head gasket or worse down the road.
Who do you call when the lawmakers ignore the law?
Flyingpig is offline   Reply With Quote
Old 05-28-2011, 02:41 AM   #7
theakerstwo
Silicone was used per cummins under the ledge of the liner years ago untill the waranty was up. The silicone when put under the liner when the countebore was cracked did nothing but seal for a little while. I mean a little while.There is a .004 shim used for awhile on top of the liner of the N14 when the liner protruion was less than .004 when under warranty. This would get the engne out of warranty only.
Old 05-28-2011, 03:49 PM   #8
stillcummin
stillcummin's Avatar
Why put a band-aid on something your goin to keep it won't be if just when it will fail again thats alot work for a patch job!!!
07 CUMMINS 3500 DAULLY
SIX SPEED,LEVELED,STRAIGHT PIPED,GRILLGUARD B&W HITCH,AND MANY MORE THINGS TO COME
stillcummin is offline   Reply With Quote
Old 05-30-2011, 04:16 AM   #9
ynot
The other guy
Replied to PM
ynot is offline   Reply With Quote
Old 06-03-2011, 02:53 AM   #10
LOG HAULER
Big Cam Power!!!!!
LOG HAULER's Avatar
Found the problem company sent the wrong liners they sent standard liners when they supposed have sent 20/40 Liners we got the correct liners and she is purring again
91 Taurus SHO 220hp
2005 GS 430 300hp
04 Cummins Water Pump jaorr 5.9L Cummins (2003-2007.5) 10 03-01-2011 06:05 PM
Head gasket on an 8.3 cummins? Rodney R Heavy Duty 3 04-26-2010 12:02 AM
head gasket or water pump? HELP!!! ladder06 2003-2007 6.0L Power Stroke 17 04-22-2010 10:26 PM
Cummins ISX How much $ for a head job? nceaglene Heavy Duty 4 12-13-2009 03:17 AM
Wanted 06 cummins head Bone stock 99 Dodge parts wanted 0 11-16-2009 12:11 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
