68RFE problems??? - TheDieselGarage.com
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 6.7L Cummins (2007.5-2011)
Thread Details Posted by Dodgefarmer, this thread has received 26 replies and been viewed 21729 times.
Old 06-19-2011, 02:27 AM   #1
Dodgefarmer
Dodgefarmer's Avatar
68RFE problems???
Well I'm at 107,000 miles and might have my 1st "real" problem Its been a trouble free truck since day one, now am I joing the club of those who have had issues???
Noticed the other day that the tranny was down shifting 1 and even 2 gears when in 6th with the slightest accleration. Instead of being able to accelerate at 60 to 80mph just using torque with out downshifting all of a sudden it wants to drop down in gears. Two different times when getting up to speed it would only go up to 4th gear, and no higher. When this happened the EB would not work. Now if I stopped, shut off engine when stuck in 4th and restart it would go through the gears and EB would work. But it still wants to down shift a lot more.
BTW, oil and filters were changed several thousand miles ago. Also no codes showing up on dash, overhead or with my code reader.
Any suggestions where to start looking before going to a shop??
Remember not to talk bad about farmers with your mouth full!
2013 6.7 CTD 2500, 800 ft-lbs torque, 4x4 crewcab Larmine Longhorn edition, 6 sp. auto, 2 tone white/gold
--07 6.7CTD 2500 4x4, Quad Cab, Big Horn Pkg. 3.73, airbags, 6sp auto, with Mag-Hytec deep pan.- sold but not forgotten.
--08 36' Jazz 5th wheel,triple slide, 12,000lbs
--28' 22,400# PJ goosneck beaver tail trailer
--95 & 96 5.9CTD 4x4 5sp. ext. cab. 33x12.50x16 front, 33x15.50x16 rear tires. R-1 tread, wheelbase shortened 30". Used as tugs on farm
--81 IH 1800, DT466 210hp, 10 speed,
--95 FL70, 8.3 cummins 275hp, 10speed
--79 GMC 7000, DD 6V53 210 hp, 6sp ally
-- A whole bunch farm equipment, all colors
singles club # 198
WALNUT MEMBER #11(workers aganist lazy non-producers united together)
Dodgefarmer is offline   Reply With Quote
Old 06-19-2011, 04:00 AM   #2
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
Can you test line pressure?
Put the truck in first gear and shift it manually, Make sure each gear is there. I hate to say it Mike but I think it may be shop time. Maybe rebuilt time. but you really cant complain to much since it you make it this far.
"Only accurate rifles are interesting" -Townsend Whelen
2012 Ram 2500 Crew Cab Big Horn
6.7L 68RFE 4wd
Yeah its stock.
Edge Insight CTS / Line-X / Access Bed Cover
B&W Turnover Ball / Companion Hitch
Pac Brake Air Bags
On Board Air
2010 John Deere 2305
2010 Jeep Wrangler JK Unlimited Rubicon
2015 Keystone Impact 311 Toyhauler
9-11-2001 NEVER FORGET
neeltburn is offline   Reply With Quote
Old 06-19-2011, 04:59 AM   #3
Dodgefarmer
Neel, I can manually shift it to each gear with tow/haul both on and off when its not frozen to 4th.
I wonder if its electrical problem since the eb quits working the same time it freezes up in 4th but works normally the rest of the time. I guess if it was electrical a code would show up though.
I will drive it for a few more days and monitor the situation.
singles club # 198
Old 06-19-2011, 02:12 PM   #4
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
Im just going to guess here, but I and wondering if your TCM is failing?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
The Following 2 Users Say Thank You to neeltburn For this addition to TDG:
Dodgefarmer (06-19-2011), Jeremiah (06-25-2011)
Old 06-19-2011, 03:32 PM   #5
dodgefarmer2
dodgefarmer2's Avatar
do you use yours for work a lot? its sounds like it might be whatever controls the tranny. JMO
08 dodge 3500 dually, quad cab, inferno red,6.7, 4x4, 6sp auto, rhino lined bed, b&w gooseneck turnover ball,full length fiberglass running boards (color matching),reese hitch.
MEMBER THE DUALLY CLUB #75
MEMBER THE AMERICAN CLUB #41
10,055,000.00 points approximately
dodgefarmer2 is offline   Reply With Quote
Old 06-19-2011, 06:10 PM   #6
Dodgefarmer
mostly work and daily driver.
singles club # 198
Old 06-21-2011, 03:59 AM   #7
Dodgefarmer
Went by a repair shop today and had them do a scan. Showed Codes P0729 and P0218.
Still thinking its electrical/sticking solenoid.
the P0218 code is for high oil temp reading. Hoping its a electrical issue to because haven't done any towing recently, oil pan temp when stuck in 4th for 20 miles was only ~135* and oil still looks and smells new as it did 7000 miles ago when I changed oil and filters.
Probably be going to shop next week.
singles club # 198
Old 06-21-2011, 04:03 AM   #8
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
Hopefully its an easy fix Mike. Keep us posted.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Old 06-21-2011, 06:09 AM   #9
bullhauler89
bullhauler89's Avatar
stuck
had mine in the shop to check for tsb evidently mine was doin the same thing when i bought it and they did a update just goin off the workup on it...
04.5 dodge 3500 600 cummins, Aem brute force, edge/attitude, south bend, air dog, banks high ram, turbo on its way...
1989 peterbilt 379 exhd 3406b modded by by ynot 15spd od 3.36 rears chrome and lights everywhere.
bullhauler89 is offline   Reply With Quote
Old 06-23-2011, 11:24 PM   #10
Dodgefarmer
Truck at the trans shop and got bad news They got to pull the trans and open it up. This shop does nothing but transmissions and is the only the 2nd 68rfe they seen that needs a rebuild. Lucky Me!
Full rebuild ~$3,800 with a 3 yr, 100,000 mile warrantee. I will get 80,000+ miles in 3 yrs.
When I find out more on exactly what happened I will post it here.
singles club # 198
The Following User Says Thank You to Dodgefarmer For this addition to TDG:
68RFE torque converter Dodgefarmer 6.7L Cummins (2007.5-2011) 2 06-03-2011 04:10 AM
How to make a 68RFE hold 700 hp -lenny- 6.7L Cummins (2007.5-2011) 14 10-11-2009 12:28 PM
6.7 & 68rfe dodgefarmer2 6.7L Cummins (2007.5-2011) 1 01-08-2009 02:54 PM
Is 68RFE limiting tow capacity? jibber 6.7L Cummins (2007.5-2011) 5 02-28-2007 04:37 PM
68rfe ceesor 6.7L Cummins (2007.5-2011) 5 11-13-2006 09:15 PM
