overheating when towing uphill - TheDieselGarage.com
Thread Details Posted by BigBird, this thread has received 27 replies and been viewed 9383 times.
Old 07-07-2011, 08:38 PM   #1
BigBird
My 06 with 78000 miles just started overheating over the weekend, but only towing 8000lb going up hill. On the inclines it would downshift pull 28-30lbs of boost at 2200-2500 rpms and the temperature would just rise and set of the temp alarm and peg the gauge with a huge loss of power. It would cool down pretty quick once I got over the steep inclines. Also about the time it would overheat a load whineing could be heard coming from under the hood (Turbo?). Running on level land the truck runs fine with no overheating. It did this on the way out there runing my SCT with the Spartan tow tune. On the way back i went back to stock programing and it still did it. Each trip I had to add 2 gallons of water as it seemed to be puking out the take.
I have been running these tunes since 07 and have put 60000 miles on the truck since i got the programmer so tunes are good. Never was an issue before as i make the trip about 10 times a year and run 85-90 the whole trip not leting the hills slow me down.
Just want to know what i'm looking at before it goes to the dealer. EGR, HG, etc.
2006 F250 CC SWB 4X4 6.0 AMARILLO
6in lift running 36's
BigBird is offline   Reply With Quote
Old 07-07-2011, 08:51 PM   #2
bootcamp
bootcamp's Avatar
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline   Reply With Quote
Old 07-07-2011, 08:55 PM   #3
smokersteve
Are you still under warranty?
Are you losing coolant?
Do you have white smoke out the tail pipe?
When you drive off the line does your turbo respond properly?
Are you on stock bolts?
What modifications do you have?
What has the dealer done in the past?
Do you have any leaks? beside the coolant cap.
06 F350 79,000
smokersteve is offline   Reply With Quote
Old 07-07-2011, 09:08 PM   #4
BigBird
Originally Posted by smokersteve View Post
Are you still under warranty? no
Are you losing coolant? loss 2 gallons each way
Do you have white smoke out the tail pipe? Can't Tell
When you drive off the line does your turbo respond properly? yes
Are you on stock bolts? yes
What modifications do you have? air filter, 4 in exhaust, tunner
What has the dealer done in the past? egr, injectors, alternator
Do you have any leaks? beside the coolant cap. none that i can find
answers in red
Old 07-07-2011, 10:49 PM   #5
NYC F-350
NYC F-350's Avatar
No gauges? You SERIOUSLY need gauges with a 6.0
You must monitor engine coolant temp and engine oil temp if you want your truck to last.
Check out this link to a post on a different forum about longevity. It explains what you need and why. Clear ten minutes off the schedule, get a nice cold one out of the fridge, kick back relax and read up on it. <LINK>
Once you have read that, and understand the why you will know what to look for.
I am thinking that your EGR cooler has failed due to a plugged oil cooler.
In extreme cases, you can blow head gaskets.
06 F-350 FX4 4X4 Extra cab Short box
updated stuff: turbo oil supply, fuel pressure spring
deleted stuff: stock oil cooler, egr cooler, next up is the kitty
added stuff: BPD oil cooler system w/cold weather package, Insight, FP, OP and boost gauges
Replace your own EGR cooler and OIL cooler. Files and notes
Comprehensive Flushing Technique
6.0 Owners should know......
NYC F-350 is offline   Reply With Quote
Old 07-07-2011, 10:55 PM   #6
NYC F-350
NYC F-350's Avatar
If it has progressed to head gasket failure, I will assume you going to stud it.
Don't buy the hype on the Black onyx head gaskets. They are not holding up as well as the stock ones do when studding.
When the heads are removed, have them checked at a qualified machine shop for straight/flat, and magnafluxed for cracking. Do this step yourself. It falls under "if you want a job done right, do it yourself" category. And you do want it done right, and done once.
If they must machine the surface, they can not remove more than 0.07" or you will need new heads.
Old 07-08-2011, 03:34 AM   #7
Smoker
Smoker's Avatar
[quote=NYC F-350;1084052] get a nice cold one out of the fridge, kick back relax and read up on it. <LINK>
Mmmm Good.
2006 SD250CC 4WD Lariat, CAT Delete, Coolant Filter, Fuel Crossover, SCT TSX, ARP Studded, Custom Flow tailgate, SCT EGT sensor, Autometer fuel pressure gauge, Bulley Dog bed steps, '08 diff cover with Amsoil 75w140, Blue spring mod, Stempede hood protector, CCV mod, full EGR cooler removal/delete, Rhino bed liner
Smoker is offline   Reply With Quote
Old 07-08-2011, 04:15 AM   #8
BigBird
I think I will have the heads studded, replace both coolers, and install the coolent filter. NYC gauges will get install also. Anything else I should do while its apart. Plan on keeping it for another 5yrs since Ford isn't putting out a bright yellow truck at the moment so I don't mind spending the money.
Old 07-08-2011, 06:15 AM   #9
AmarilloSD
AmarilloSD's Avatar
sounds like gaskets to me, try towing with no tune, when mine were toast i could tow stock but with any tune even a 20hp tune it would overheat/blow coolant etc, also post up some pics, i have an amarillo as well and would like to see what your truck looks like with lift and tire size, im thinking of going down in tire size
2006 f350 C.C.SB Amarillo Edition- Afe Stage 2 intake, SCT, mbrp 5" turbo back with 6" tip, 7" icon lift,325/50/22 dynapro atms on 22x11 black XD diesels, keystone heat extractor hood, 4.30 gears, 03 turbo DR/icon traction bars, Hd Heads, Painted front and rear bumpers, arp head studs, Welded EGR
wish list/coming soon-banks ic, regulated return fuel system, Tuned FICM, but not if i do a CR cummins first!
AmarilloSD is offline   Reply With Quote
Old 07-08-2011, 02:14 PM   #10
harry6.0
harry6.0's Avatar
I have to agree with the above, head gaskets are likely toast, and in most cases a chain reaction that started with a clogged oil cooler. The only other thing is to make sure your engine fan is working properly. The loud whinning you were hearing was hopefully your engine fan and not the degas tank cap whining from overpressurization.
Harry
Jan 03' built 6.0/F250cc4wd trqsft/SCT-tuned by KEM-Performance/Garrett Powermax vg-turbo/blue spring mod/gauges=egt+boost+fuel+SG2/exhaust/airaid intake/DR 4.5 lift/dual bilsteins/315's/greasable ball joints/powerstop/smittybuilt/kc lights/high idle mod/roll-n-lock/T5-Rotella 10w30 with (Archoil AR9100 in the oil) and (AR6200 in the fuel)http://www.archoilspokane.com/
harry6.0 is offline   Reply With Quote
a neverending uphill battle! FFemt5287 1994-2003 7.3L Power Stroke 7 12-11-2007 08:18 AM
Need help with overheating when towing. Sauramen 7.3L and 6.9 IDI (Pre 1994) 3 08-03-2007 06:58 AM
Overheating HorsepowerII 7.3L and 6.9 IDI (Pre 1994) 2 07-14-2007 01:46 AM
Turbo Boost Question going uphill norcuron 2003-2007 6.0L Power Stroke 7 05-14-2007 02:23 AM
NHL Headlines Hurricanes face uphill battle as series shifts to Montreal RSS Feeder The Parking Lot 0 04-28-2006 08:00 AM
