DT466 fuel system question - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Medium Duty
Thread Details Posted by bpogue, this thread has received 6 replies and been viewed 1850 times.
Old 09-06-2011, 05:05 PM   #1
bpogue
bpogue's Avatar
Up until recently my truck has always started up just as soon as you hit the starter. Now most days it will start up then die immediately. After about 30 seconds of cranking it will start up and then run fine. This happens almost every time it sits for more than a couple hours. I assume it is losing prime somewhere. Does anyone know of a check valve that may be leaking back or anything else that would be a likely place to start?
1996 Int 4700, 175hp DT466, 5 speed, 2x rear end, service body
2001 F350 SRW flatbed, 4x4, crew cab
1978 International F2275 Dump Truck
1996 NH LX665, steel tracks on foam filled tires
2005 Tackeuchi TB145
2003 Takeuchi TL150
Case 850B Highlight, 4 way bucket
bpogue is offline   Reply With Quote
Old 09-07-2011, 03:14 AM   #2
nevrenufhp
Super Moderator
nevrenufhp's Avatar
the bleeder is one place, or possibly the filter itself. You could pressurize the tank with 3-5 pounds of air. That would generally expose leaks.
Dale
my daily driver:67 F100, 300 4V, 4 spd.
work rigs: 94 IH 4900, DT466(originally 230hp), #0 fuel plate, tighter gov springs, 22* timing
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline   Reply With Quote
The Following User Says Thank You to nevrenufhp For this addition to TDG:
bpogue (09-08-2011)
Old 09-10-2011, 02:32 AM   #3
John_G
Super Moderator
John_G's Avatar
There is a check valve under the plastic cover behind the fuel filter, above the fuel strainer and between the filter and fuel connection. Remove the cap, looks like "+" and is pretty easy to remove. There must be a round plastic ball in there that is really round. If missing or deformed, replace it.
I vote for LIBERTY!
Old 09-12-2011, 12:17 AM   #4
bpogue
bpogue's Avatar
Thanks. I'll check it tomorrow when I get to the shop.
2003 Takeuchi TL150
Old 09-16-2011, 01:24 AM   #5
bpogue
bpogue's Avatar
On the rear of the filter assembly I see a tube about the size of a quarter and about 2 1/2" tall. It looks like it screws into the filter base. It has vertical ribs on it. I have tried to turn it, but am afraid to give it a good turn because it is plastic. Is this the right thing I am looking at? Does it unthread, or turn a little bit to unlock it and then drop out? Or is the check valve on top? There is steel tube sticking up with a rubber cap on it.
2003 Takeuchi TL150
Old 09-16-2011, 09:58 AM   #6
mrdevildog
mrdevildog's Avatar
look on top for the check ball-under the "+" cap, youll see it, loosen the cap and the check ball is under it, will need a pick or something to get it out, the tube you are talking about should be the "rock catch", you can un screw it and clean it out also, it catchs a lot of debris, should be catched at every service also, it has a screen in it that goes in the same way it comes out.
mrdevildog is offline   Reply With Quote
Old 09-17-2011, 01:38 AM   #7
bpogue
bpogue's Avatar
Thanks. I'll check them tomorrow morning.
2003 Takeuchi TL150
Fuel System Question Burner718 1994-2003 7.3L Power Stroke 3 01-22-2008 07:20 PM
More Fuel System Question Mlhaynes8302 2003-2007 6.0L Power Stroke 3 11-07-2007 04:49 PM
Fuel System Question Racing41 5.9L Cummins (2003-2007.5) 5 09-22-2007 03:02 PM
Fuel system question cobrat03 2003-2007 6.0L Power Stroke 10 08-29-2006 10:59 PM
Fuel System Question swingintree 2003-2007 6.0L Power Stroke 9 11-24-2005 03:03 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
