What is normal battery voltage? - TheDieselGarage.com
Thread Details Posted by zman, this thread has received 12 replies and been viewed 20972 times.
Old 11-05-2011, 11:45 PM   #1
zman
zman's Avatar
I'm curious if my batt voltage is considered normal or little low.
11.6 cold start glow plugs on, 12.7 KOEO after running, 14.2 running voltage (Alt charging)
I have a pair of 850 CCA.
2012 F350 6.7L 4x4 Lariat Ultimate FX4, Chrome package, KR, Nav, SRW, CC, LB, 11.5K GVWR, 3.55 ELA
Traded: 2006 F350 6.0L 4x4 Lariat, SRW CC LB
Traded: 2007 1500 Ram Hemi
2010 Keystone Outback 5er
United States Navy Combat Veteran
zman is offline   Reply With Quote
Old 11-06-2011, 12:21 PM   #2
harry6.0
harry6.0's Avatar
Thats what mine reads off of my ScanGauge2 mounted inside the cab, exactly the same numbers as yours.
Harry
Jan 03' built 6.0/F250cc4wd trqsft/SCT-tuned by KEM-Performance/Garrett Powermax vg-turbo/blue spring mod/gauges=egt+boost+fuel+SG2/exhaust/airaid intake/DR 4.5 lift/dual bilsteins/315's/greasable ball joints/powerstop/smittybuilt/kc lights/high idle mod/roll-n-lock/Mobil Delvac1 ESP 5W40 with (Archoil AR9100 in the oil) and (AR6200 in the fuel)http://www.archoilspokane.com/
harry6.0 is offline   Reply With Quote
Old 11-07-2011, 01:14 AM   #3
zman
zman's Avatar
Great, I feel much better now!
Old 11-09-2011, 05:22 PM   #4
boobin
Ditto what Harry said. Nothing out of the ordinary with your numbers.
2004 6.0L F350 Lariat Auto 4x4 CC/LB/DRW - sold
Sumimoto 255/70/22.5 on American Force Classic 22.5 wheels, 4.88 w/Truetrac rear, Mag-Hytec front/rear covers, Mag-Hytec 5R110W trans pan and '08 improved filter, custom front/rear springs from National Spring, Bilstein shocks, Bilstein dual stabilizer shocks, 4" stainless turbo back to a FTE single 6" stack, ARB Snorkel intake, Dfuser coolant filter kit, CFM++ Large Mouth, Doug's custom intake manifold, Powermax turbo w/batmowheel, Warren 175/75 injectors, ARP studded, custom CCV reroute, fan shroud removed, Diehard Platinum PM-1 batteries relocated, permanently installed battery tender with front/rear plug in access, HD250 amp alternator w/remote rectifiers, (9) ISSPRO Performax gauges, Nathan K5s, Warn hidden winch bumper kit, Warn 16.5k winch, Reflexxion steel hood, Jimmijammers, Britebox, Retro Solutions, ATTA 50gal Bed tank/tool box combo, Titan 67gal main tank..Hellman sumped, custom regulated return w/Fuelab pump, 6.4 oil filter canister, AMP steps, F650 lower dash w/nine switch panel , Carling switches, SCT X2 and stuff
boobin is offline   Reply With Quote
Old 11-09-2011, 07:01 PM   #5
pstrang
Slightly off topic, but my running voltage is typically 13.6 down to 13.2. My gauge is a DMM (digital multimeter). I've never had mine run at 14V for any length of time.
Does the alternator/charging logic adjust the running voltage if the batteries don't need charged much? Or should it *always* be 14V? Mine will start higher, then drop down as time moves on. When I plug in my trailer, It runs closer to 13.2 for most of the haul. All the batteries are charged before trips.
Thanks.
2005-6L/PSD F-250 Lariat CC/SB/4x4:
- MBRP 4" turbo back, Dieselsite coolant bypass filter, Frantz oil bypass filter, X-monitor, Fluidampr, fuel x-over line, intake elbow, EGR cooler delete, wrapped headers and turbo, ARP studs, OEM gaskets, ported heads and manifolds to match, Hot FICM w/ ID Flash, 08+ tranny pan/filter.
pstrang is offline   Reply With Quote
Old 11-09-2011, 07:17 PM   #6
Johnp3
A battery needs 13.8 volts to charge.
What I do to test a battery, is after sitting overnight, it should have 12.6 volts.
Then I connect a multimeter, with a min max selection on voltage. go threw the cycle, and start it and the voltage should not go below 9.6 volts if it does the battery is week.
If you have driven the vehicle for a while, and the battery voltage with the engine running is above 14.0 volts, shut down the engine and turn on the lights for 5 minutes, start the engine monitoring the voltage, it is warm and the voltage should not go below 9.6 if it does the battery is junk. After it starts monitor the voltage, If it goes up above 14 volts real quick the battery is sulfated.
1988 ford van fresh overhaul, 1991 nissan pick-up 1993 Caprice 2000 GMC S10 Blaser 2007 nbs 3500 GMC 4x4 crew-cab long box 17 inch single wheels Duramax Alison. BW turnover Ball. Furakawa FL35 loader. Retired, HD mechanic, worked on engines all my life. Fabricator welder. electrician. in the process of finishing my new shop. Live in Rock Creek B.C. Wife has a fruit stand.
Johnp3 is offline   Reply With Quote
Old 11-10-2011, 02:10 PM   #7
pstrang
So is the alternator voltage regulator *smart*? IOW, does it adjust its output voltage based on battery condition? Or should it always be 14V?
Thanks.
Old 11-10-2011, 05:33 PM   #8
Johnp3
The alternator in My Duramax does increase the voltage when it is charging then goes back to 14.0 volts. Most alternators in automotive, put out 15 volts, in class eights they put out in the 14.2 area. When the battery is sulfated it does not get a full charge, and will come up to full voltage easily.
Charging systems, can be compromised by dirty connections, very easily. If the connections have a resistance of .3 volts on each connection that is .6 so a system set to 14.2 is only getting 13.6 actual voltage to the battery, and it will not be fully charged. Also when you want to start the battery is working off 12 volts or lower instead of 12.6.
A voltage drop test will help but a side post battery is difficult to get accurate reading.
Clean soldered connections, and then protected with Die-electric grease, that works.
The Following User Says Thank You to Johnp3 For this addition to TDG:
pstrang (11-10-2011)
Old 11-14-2011, 12:48 PM   #9
TooManyToys
Curmudgeon
TooManyToys's Avatar
Thanks.
Despite a lot of people stating that our alternators adjust voltage through smart technology, the truth is the voltage drops due to the self contained unit getting hot. Not an abnormal condition. And once it does it's normal for the voltage output to be about 13.6 vdc, down from the typical 14.2 vdc when cold.
Another word of caution is to check any meter you have against a few others to make sure it reading is correct. We had one well brand (Fluke) at work that was down a few decimals. I've bought an eBay power port reader that showed 0.5 vdc below correct.
Jack -
Formerly FMTRVT, Manager of Vehicle Testing - Brakes
2003 F-350SC Lariat 4x4 6.0L Auto
Truck Modifications as below in Pictorials on Facebook. Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
TooManyToys is online now   Reply With Quote
The Following User Says Thank You to TooManyToys For this addition to TDG:
pstrang (11-15-2011)
Old 11-23-2011, 11:17 AM   #10
indiana lineman
indiana lineman's Avatar
What about the batteries being connected together? I tested mine the other day, key off , and they showed good. Then isolated one ground and they dropped to marginal
indiana lineman is offline   Reply With Quote
voltage mshannon 1994-2003 7.3L Power Stroke 0 08-28-2010 01:42 PM
$29 Battery Maintainers (battery tenders) bushpilot General Diesel 4 12-29-2009 01:19 PM
Low battery voltage bknee 5.9L Cummins (2003-2007.5) 1 11-03-2009 02:00 AM
RPM and Voltage box. Taco XL 1994-2003 7.3L Power Stroke 11 12-03-2007 08:02 PM
05-5-7 Low Battery Voltage - Snow Plow Equipped Vehicles - 6.0l Diesel With Single Ge Squatch Ford Oasis requests 0 03-23-2007 11:47 AM
