Dt466 oil/water light - TheDieselGarage.com
Thread Details Posted by idigdirt, this thread has received 3 replies and been viewed 2330 times.
Old 11-11-2011, 09:02 PM   #1
idigdirt
idigdirt's Avatar
I have a 94 international 4800 with a Dt466. The oil/water light and buzzer keeps coming on and after 30 seconds to a minute the engine shuts down. The light has come on in the past and I had added about 6 oz of collant and it would go out. Today however I can't get it to go out and I oerfilled the radiator with collant. It appears someone has messed with some of the wires from kysor box as they have butt connectors on them. So is it harmful to have to much coolant? Is the oil/water light just for the levels of those fluids? Can it detect if there is oil IN the water? Coolant is very clean and the oil is not milky or foamy. Just black like normal. No white smoke or any smoke out of the exhaust. Do those kysor boxes go bad? Should I start with the sensor on the coolant tank? There are wires that go from the kysor box to a senson on the top front of the engine. What sensor does what. Thanks for any help or advise.
1994 International 4800 bucket truck,14k Fabco front axle,Fabco t case,5.38's,Braden winch,Allison MT643 trans with a 37k gvw
IH 4X4 club member #3
idigdirt is offline   Reply With Quote
Old 11-11-2011, 09:50 PM   #2
mathura
mathura's Avatar
That is an indication that water level or oil level is low. Could be a faulty connection to these sensors or the sensor itself is bad.
mathura is offline   Reply With Quote
The Following User Says Thank You to mathura For this addition to TDG:
idigdirt (11-11-2011)
Old 11-11-2011, 10:44 PM   #3
idigdirt
idigdirt's Avatar
If I disconnect the wire to the sensor would that tell me if the sensor is bad? I guess I should start with the one on the tank?
Old 11-12-2011, 11:14 PM   #4
idigdirt
idigdirt's Avatar
I may have fixed it today. The connection was a little loose. The wire that goes to the connector had a bare spot due to rubbing the radiator support rod. The light is off now. It's leaking antifreeze out of the overflow tube now because I put so much in
water light yadaddy99 2003-2007 6.0L Power Stroke 5 08-09-2009 06:25 PM
oil/water light flashing on dt466 BossHogg Medium and Heavy Duty 5 04-29-2008 06:32 AM
water in the fuel light on fleedog 2003-2007 6.0L Power Stroke 7 04-07-2007 02:15 AM
oil/water light blinking DT466 Duke Medium and Heavy Duty 20 06-12-2006 12:54 AM
